 Post subject: Strange HDD noise after failure
PostPosted: August 27th, 2015, 19:01
Here is the noise (I did two trials because the sound occurred at random intervals before shutting down the drive):
Trial 1:
https://www.dropbox.com/s/nw63vwqlic4kz ... 1.mp4?dl=0
Trial 2:
https://www.dropbox.com/s/acbmhtxjtdj0j ... 2.mp4?dl=0
Thanks!
 Post subject: Re: Strange HDD noise after failure
PostPosted: August 28th, 2015, 4:03
What is the question?
This is an opened drive.
PostPosted: August 28th, 2015, 11:14
The question is will this drive work under any circumstances? This drive is probably screwed, but is there any way to make it work if even for a moment. There's a 1MB file that I really need from it. I have indeed taken it apart in an attempt to fix it.
PostPosted: August 28th, 2015, 14:53
Maybe, but not by you. This is way beyond DIY I'm afraid :-(
