My Western Digital Passport Usb Not Re
May 13th, 2012, 2:32
Hello
Every Time I,m Connect Western Digital 2.5" My Passport Essential External Display This Error :
And I,m Needed Data On This Hark Disk , How Can i Fix This Problem Or Connect Sata Port For Extract Data ON This Hard Disk , I,m Not Found E71,E72,E73 Connector For Sata Connected .
All Parts Picture :
Thank You For Every Thing .
And Excuse Me For My Bad Write Text , My English Language Is Very Bad . :oops: :(
Re: My Western Digital Passport Usb Not Re
May 13th, 2012, 5:40
get pro. help for this specific drive DIY will kill it (if not dead already)
May 13th, 2012, 5:58
Firstly connecting a sata connection to the pcb will allow you to image the drive but the image / data will be encrypted still as you will be bypassing the encryption chip so this really wont help you too much.
Anyway for info the capacitors you would need to remove are c90, c91, c92 & c93
What you need to do is find & fit a compatible usb pcb & solder the rom at u12 from your old pcb to the donor pcb.
Match the 2060-771737-000 on the back pcb. Try contacting donordrives.com or eric_lee8341@hotmail.com to see if they have one in stock.
Remember DIY comes with risks
Loki
May 14th, 2012, 8:45
Thanks to great managers do to help me in solving this problem ?
Thank You .
May 14th, 2012, 23:40
if you are able to get the sata pins & the drive imaged to decrypt you need another symwave board
similar to
http://www.ebay.com/itm/connector-board-replacement-4061-705089-001-for-WD-MY-BOOK-USB3-0-Hard-Drive-/300697275819?pt=LH_DefaultDomain_0&hash=item4602f44dab
this, also a make sure to hpa the desitnation drive to have the same lba's this should decrypt your board since its has the same symwave chip for the usb controller
May 15th, 2012, 2:11
How does Microsoft's UVCView utility see the external drive?
http://www.users.on.net/~fzabkar/USB_ID ... ew.x86.exe
Does the drive behave any differently if you use a USB 2.0 cable instead of USB 3.0?
May 15th, 2012, 2:37
Obviously USB converter circuit there is a problem, the circuit board 771 692 SATA model substitution
May 15th, 2012, 5:59
loki wrote:Hi,
Loki
Heres some links to get a 2060-771737-000 REV A PCB
Dont forget to swap the U12 from your old PCB to the donor.
http://pcb-hdd.com/wd10tmvw-11zsms5-206 ... -1003.html
http://www.hdd-donor.com/buy/pcb/western-digital/554
October 8th, 2013, 5:53
what is the SATA pinout for 771737 PCB?
& capacitors to remove?
October 8th, 2013, 17:37
The capacitors are C90-C93, and there are 4 plated thruholes on the MCU side of the capacitors.
October 9th, 2013, 6:58
thx fzabkar, can u pls mark the sata pinout for the pcb please?
here is the link of the pcb...
I also need Sata Pinout for 173761 PCB
October 9th, 2013, 15:43
I can't be sure of the SATA pinout, but it stands to reason that the traces would most likely go directly to the SATA connector without crossing over each other. So just imagine placing a SATA data connector across the Tx/Rx traces ...
Alternatively, locate a SATA PCB with the same MCU chip and follow its SATA traces from MCU to SATA connector. You could apply the same principles to every PCB.
October 12th, 2013, 5:43
Anyone have experience for SATA conversion for 771737 PCB?
If not interested publicly I would like to get into PM please
October 12th, 2013, 19:31
http://www.google.com/search?q=%222060-173761%22
No results found for "2060-173761"
October 12th, 2013, 19:42
shahij wrote:Anyone have experience for SATA conversion for 771737 PCB?
See the SATA Tx/Rx pairs for the following board:
http://pcb-hdd.com/images/WD7500BPVT-60 ... V%20P1.JPG
It has the same MCU as the 771737 PCB. Now follow the same Tx/Rx pairs from the MCU on your PCB to the 4 capacitors near the bridge IC.
October 13th, 2015, 18:25
This may help you.
