Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2  Next
 Post subject: Marvell PCB Alternatives
PostPosted: January 4th, 2012, 6:34
Some times you can't find the same pcb number for WD so you can use one of these alternates :idea:
Notes: all these alternatives pcb are tested
1-701590 you can use 701537
2-771590 you can use 701590
3-701267 you can use 701266 rom swap needed
4-701567 you can use 701537.
5-701596 you can use 701590 or can use 701537
6-701477 you can use 701444
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
 Post subject: Re: Marvell PCB Alternatives
PostPosted: January 4th, 2012, 16:52
Helpful
PostPosted: January 4th, 2012, 17:32
tawfeek_mokhtar, thank you!
How about xx1622 (Mars)?
PostPosted: January 4th, 2012, 21:39
Does this mean that 701537, 701590, 771590, 701567, and 701596 are all interchangeable?
PostPosted: January 5th, 2012, 3:09
@fzabkar
yes
PostPosted: January 5th, 2012, 4:06
yes it's all the same and you can chang every one with another
Tawfeek Mokhtar
PostPosted: January 5th, 2012, 4:09
nothing yet about this pcb .i will inform you with any new news
Tawfeek Mokhtar
PostPosted: January 5th, 2012, 6:35
Thanks, good job.
PostPosted: January 5th, 2012, 8:00
701635 usb interface , you can use 701572
701508 you can us 701494
Tawfeek Mokhtar
PostPosted: January 6th, 2012, 9:01
Very good. Thanks for the Info.
ACELab partner
PostPosted: January 7th, 2012, 4:35
thanks
i hope every one found an alternative pcb for any model "from the work experience" to share it here.
Tawfeek Mokhtar
PostPosted: January 7th, 2012, 4:40
Well Done...
PostPosted: January 8th, 2012, 5:00
701292 you can use 701293
701130 you can use 701252
PostPosted: January 8th, 2012, 5:20
thank you for sharing your knowledge
PostPosted: January 8th, 2012, 9:58
Unfortunately, not all the informations given here are true
This two PCBs are NOT compatible (interchangeable)
In another way are wired the signals in the connector J1
701537 -> J1 pin 1 is connected to GND
701567 -> J1 pin 2 is connected to GND
These two PCBs are interchangeable only in very few cases !!!
Not all versions of the ROMs are suitable for both PCBs
Mikippp
PostPosted: January 9th, 2012, 5:13
Mikippp
I'm very sure that 701567 you can use 701537
I'm very very sure that 701590 you can use 701537. it's the same but with memory chip i use tht in ALL CASES
you can try first and then kindly report here
Tawfeek Mokhtar
PostPosted: January 9th, 2012, 14:15
Take a multimeter and see where on the connector J1 is GND at 701567 and at 701537 !!!
Or maybe you meant about 701577 and not 701567
Yes, they are versions of the ROM that will work both on 88i8846-TFJ2 MCU and on 88i8845D-BHG2 MCU
For example - Atlantis ROM 05APE_04AD
There are also versions of the ROM which saved to the PCB equipped with another model of the MCU kills PCB (works only j-tag and tiny console)
For example - Pinnacle ROM 052JA_0427 written to the PCB with MCU 88i8846-TFJ2 kills PCBs
PS Even not all models of the 701590 PCBs are compatible
2060-701590-000 REV A - MCU 88i8846-TFJ2 (internal ROM) and
2060-701590-001 REV A - MCU 88i8846E-TFJ2 (external ROM)
are completely incompatible with each other
Mikippp
PostPosted: January 9th, 2012, 15:52
i have got 701615 (usb interface) possible replace with a SATA one (?)
PostPosted: January 10th, 2012, 5:48
You can use as example 701499, from Denali series.
PostPosted: January 10th, 2012, 6:16
Mikippp
MR.Mikippp
i Know exactly what are you talking about and from work experience let me say again
you can use 2060-701590-000 REV A - MCU 88i8846-TFJ2 (internal ROM) instead of 2060-701590-001 REV A - MCU 88i8846E-TFJ2 (external ROM)
and moreover you can use 1537 instead of them both . just try it as pcb swap and i'm more than sure that i do that every day
Tawfeek Mokhtar
Users browsing this forum: Majestic-12 [Bot], NoobiusPip and 74 guests
