 Post subject: 7200.12 Revival Plan
PostPosted: September 24th, 2015, 2:08
Dear Friends I want your suggestion for this case -
Model - ST 3100524AS FW JC48 7200.12 1 TB Desktop
When Disk came to me it was spinning normally but no detection I am using Pc3000 Udma for which TS is not taken this year
I have only erased smart & disk has got detection , I have taken FW backup. Disk is giving read errors.
I suspect typical issue - high reallocated count , pending defects etc.
I don't want to take chances and experimentation with customers disk / data.
At the same time I am confused by translator related commands , like which and when to use.
(so many commands which varies from family to family and issue to issue , like translator recovery / regeneration etc)
even m0, 6.,, has so many variant.
What are sage steps I can take now to revive disk ?
Thank you in advance.
 Post subject: Re: 7200.12 Revival Plan
PostPosted: September 24th, 2015, 2:30
"I am using Pc3000 Udma for which TS is not taken this year"
With respect, I suggest you take a TS with Ace :-)
They can help you a lot more than the guys on here, and connect remotely to help you. They have a couple of real good Seagate guys there.
PostPosted: September 24th, 2015, 3:37
Hi Sean Thanks for suggestion. yes I am going for that option but presently I don't have TS active.
PostPosted: September 24th, 2015, 9:48
So a lot of ts renewal is coming with a new PC3K software release :)
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: September 24th, 2015, 13:18
Yep, it's all about timing to get your money's worth!
Users browsing this forum: Google [Bot] and 58 guests
