 Post subject: Toshiba MQ01ABD100 - Which parameters match for head swap?
PostPosted: September 24th, 2015, 5:31
Given two 2.5'' Toshiba drives of the same model (MQ01ABD100), which parameters should be matched for heads replacement?
(Drive revision ?, Country ?, Date ?)
I read that the DRIVE REV is the firmware, but I assume that the firmware version could be only some digits of the DRIVE REV.<
For instance, what is the difference between a :
AZA AA00/AX001U
and a
AZA AA00/AX001A
Thanks.
Users browsing this forum: Google [Bot] and 57 guests
