 Post subject: About DONOR DRIVE criteria for heads assembly
PostPosted: September 29th, 2015, 9:32
I have 2 HDD drives (WD20NMVW-11EDZS2 and WD20NMVW-11AV3S2) bought from the same shop in the same periode.
The have the Same DCM (except 1 character) and a close date but only the first part of the MDL.
Can the 2 drives have a compatible heads assembly?
What is the reliability of information about donor drive criteria on DonorDrive.com and other websites? are theses creteria a MUST in order to have a compatible heads assembly?
kind regards,
 Post subject: Re: About DONOR DRIVE criteria for heads assembly
PostPosted: September 29th, 2015, 11:53
The blue drive is rather fresh, e.g. I think it could happen that we haven't got our hands on it yet. Probably many others here as well, so you can make an experiment.
sosrecup wrote:
a close date
These are the recent models, so even with a few days delta in production dates heads may be different.
PostPosted: September 29th, 2015, 12:19
As Dmitry implied, someone has to be the first to try. So, swap them out and let us know your result.
PostPosted: September 29th, 2015, 12:54
The blue one is the donor.
Even if the HDD Model is not the same or as recommendation is some websites like donordrives:
anyway, I'll try to swap to see the result.
PostPosted: September 29th, 2015, 13:00
sosrecup,
WD20NMVW-11AV3S2 - Shrek LT family
WD20NMVW-11EDZS2 - ?????
Image from the PCB show.
PostPosted: September 30th, 2015, 4:45
WD20NMVW-11EDZS2 is Shrek LT family too.
The PCB code on the working hdd (WD20NMVW-11EDZS2) is 2060-771961-001 rev B
The PCB code on the non-working hdd (WD20NMVW-11AV3S2) is 2060-771961-001 rev A
Kind regards,
PostPosted: September 30th, 2015, 5:19
I have swapped these and they work. If preamp vendor and rev matches, you should be good to go.
However, I'm a little concerned that your patient has a small dent of the lid, near where the platter surfaces begin...
PostPosted: October 9th, 2015, 5:22
I confirm,
I swapped the heads between these HDDs, and it worked for me.
PostPosted: October 9th, 2015, 5:40
thanks for sharing.
These drives are not encrypted anymore, am wondering whether WD has change the policy ? anyone have any idea on it ?
RAID/Server Recovery
PostPosted: October 10th, 2015, 8:09
chinopk,
The new version of PC3000 can access data on WD drives even if they are encrypted.
Regards,
Users browsing this forum: No registered users and 52 guests
