Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: Does anyone here offer recovery service for Hitachi HDS72101
PostPosted: October 8th, 2015, 5:08
HDS721010CLA332
Drive is not detected on bootup nor in Bios. Drive is making beeping sounds and I suspect a drive head problem.
I'm looking for someone who can help recover the data. There is 1 tb of media files. Do let me know how much you charge too. I'm open to services from any country, I can ship the drive over.
Thank you.
 Post subject: Re: Does anyone here offer recovery service for Hitachi HDS7
PostPosted: October 8th, 2015, 6:56
You can see http://300dollardatarecovery.com/
He offer Data recovery service in your country
Expect, the Unexpected
PostPosted: October 8th, 2015, 7:48
This is a decent company so I hear, but I don't believe he does cleanroom work which WILL be required in this case.
PostPosted: October 8th, 2015, 7:58
You can also try contacting www.data-medics.com or www.datasaversllc.com.
PostPosted: October 8th, 2015, 13:59
Yes, you are right $300 guy doesn't do clean room work and if it's beeping like that it likely needs read/write head replacement.
If you want to send it in to us the cost would be either:
$450 - if we can stabilize it and extract the data without replacing the read/write heads
$650 + Parts - if we need to replace the read/write heads (likely scenario in your case).
We guarantee that if we can't recover the data you don't pay the recovery charge, only the parts cost you would be out. If you post a picture of the drive label I can provide an estimate of what the parts would cost.
PostPosted: October 8th, 2015, 15:41
I could do it for $300. I have clean room, parts, tools, experience with this model and this type of problem. PM me. If I can't recover data - you pay nothing.
PostPosted: October 8th, 2015, 15:55
With only two posts on this forum? I'd expect a pro to have more activity than that.... care to elaborate about what company you represent?
PostPosted: October 8th, 2015, 16:01
As you can see, I just came to this forum.
PostPosted: October 8th, 2015, 16:07
You'd really recover a physically damaged 1Tb Hitachi "ARM" drive for $300 all-in?
With no parts fee and "no-fix no-fee"?
That sounds like a fantastic deal!! :-)
PostPosted: October 8th, 2015, 16:44
Yes, for this guy - I could do it. And only If I am first who will play with this drive.
PostPosted: October 9th, 2015, 2:11
You shall not "play" with any drives...
http://www.rescue-it.se
PostPosted: October 9th, 2015, 4:03
Hello Sean ,
How Are You :) .Well Just To Give You All a Typical Datarecovery Pricing Quote in India .
Logical Work
1 : Simple Logical Work Rs :750/-
2 :Complex Logical Data Recovery @ Rs :1500/-
Semi Physical Work :
1 : Recovery From a BAD Sector Drive Rs :2500/- + Logical After That Rs :1,500/-
2 : Recovery From Logic Card Failure @ Rs :3500/- + Logical After That Rs :1,500/-
3 : Firmware Issues @ Rs :4800/- [ Less Then 250GB ] , Rs :7200/- [ 250GB HDD ] , Rs :7800/- [ 320GB HDD ] , Rs :8400/- [ 500GB HDD ] , Rs :10,800/- [ 1TB ]
4 : Head/Platter Replacement Cases @ Double The Rates Quoted For Firmware Work
PS : This is The Reason That To Buy a Good Professional Tool In India You Spend Quite a Portion of Your Lifespan .I Think Its Same For Pakistan .I would suggest that the thread creator should send the drive to a pro in his country only .Although Jared is a ACE Professional he being in Australia [ Correct me if i am wrong ] .I sense a Motor jam or head stuck issue that would require a clean room for sure
PostPosted: October 9th, 2015, 4:15
sorry man but you are wrong, mr. jared AKA data-medics is located in RI, USA or if you want it's Rhode Island, united states of america
PS if you want the street too, just check it out in is website here
PostPosted: October 9th, 2015, 4:32
Thanks ,
I Already Said [ I Was Not Sure ] , Thanks For Clarification Brother .You Have Many American Professionals On HDDGURU .The customer Can Take His Decision Thanks For Clarification Again
PostPosted: October 9th, 2015, 12:03
Do not tell me what I should and What I shouldn't. I could start ARM hitachi and start read user area even if drive has not system modules in system area at all.
PostPosted: October 9th, 2015, 12:29
Our standard Price Is 330usd including one donor hdd.
60$ non-refundable if unsuccessful as a cost of donor.
India/pakistan/Bangladesh - This Is normal Price for us for dealing such cases.
I recommend data-medics for the localized service.
We have no idea about drHDD, So its better not judging with just 2 posts, need sometime for us to see
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: October 10th, 2015, 1:16
Well,
In That Case i Offer You USD 10,000/- For Demonstration Only .And Then i Will Place You in the Leagues of Pepe And Drkiev .
PostPosted: October 10th, 2015, 1:37
I'll vouch for the guy.
I hope my number of posts is convincing for the people :)
Although I suspect that since the drive is "beeping" the problem is much harder then just heads.
PostPosted: October 10th, 2015, 6:30
Well,
How About This " I could start ARM hitachi and start read user area even if drive has not system modules in system area at all. " .Do You Vouch For This Also ?.
PostPosted: October 10th, 2015, 8:56
Amarbir wrote:
Well,
It's not exactly like you might imagine but it is possible
Are you ready to pay those 10k?
Users browsing this forum: No registered users and 85 guests
