 Post subject: Toshiba MK3259GSXP failed to initate - Possibly ATA password
PostPosted: October 19th, 2015, 8:03
Forementioned disk: Toshiba MK3259GSXP 320GB taken out of TANDBERG DATA RDX quikstor
After connecting hard drive to a computer it fails to initiate both in Windows and via Boot CD's.
It returns "I/O Error".
HDDScan says the drive is ATA Password Protected.
Diagnostic tools fail to recognize the drive (e.g. MHDD) or are unable to ckeck it and usualy give out "I/O or Read error" I used the following programs:
DiskGenius, Partition Magic Pro, Fujitsu Diagnostic Tool, HDAT, chkdsk, DiskCheck and a few more.
Only LifeGuard Diagnostic from Western Digital tested the drive with successfull result but it says the drive is 0 bytes.
_
after searching through Google i tried the following to disable the protection:
- Formatting the drive using: Active KillDisk, Darik’s BOOT and Nuke, HDDErase, HDShredder, LifeGuard Diagnostics, GParted, HDD Low level Format Tool, fdisk. There was even a try on unsing Windows 7 installation disk)
- Clearing the attributes in "CMD/DISKPART"
HD has no pins which could be used to physically lock it.
I tried yelling at the drive, changing drivers. I even searched for firmware update (I failed).
Nothing helps.
Maybe you guys have another idea because I'm lost?
Best regards.
 Post subject: Re: Toshiba MK3259GSXP failed to initate - Possibly ATA pass
PostPosted: October 19th, 2015, 8:10
you don't say anything about the history of it. Possibly has media damage and/or head issues and is just not in good condition. there is some software written by a forum member, Moltke. It is called "ZU" I believe. I have never used it but may be worth a look. Otherwise a dr pro might be able to do it at a reasonable price with their firmware tools (if that's whats required)
PostPosted: October 19th, 2015, 8:23
"ZU" doesn't work on my computer.
The drive is pulled out of RDX QUIKSTOR (by TANDBERG DATA) where it does work.
Thank you for your reply.
PostPosted: October 19th, 2015, 8:27
what are you trying to achieve ?
judging by the tools you have used
hub93 wrote:
-Formatting the drive using: Active KillDisk, Darik’s BOOT and Nuke, HDDErase, HDShredder, LifeGuard Diagnostics, GParted, HDD Low level Format Tool, fdisk. There was even a try on unsing Windows 7 installation disk)
I doubt that you need the data, so... ?
PostPosted: October 19th, 2015, 8:30
I'm trying to make the disk work again.
PostPosted: October 19th, 2015, 8:59
? *edit* sorry I missed this part about the RDX in the original post... This is quite important info :-)
These have different firmware, and I don't think I've seen any reports of them being enabled to use as a regular drive.
I am sure there is a thread on here from some time ago talking about these. One of my servers came with a backup solution and a heap of these RD1000 cartridges and I assumed I could rip the HDDs out. at the time I didn't find a solution and lost interest. maybe do a search on here for RDX
http://forum.hddguru.com/viewtopic.php?f=1&t=27522&p=188564&hilit=RDX#p188564
this post mentions RDX, though I don't know how much of it is relevant or if there was a solution http://forum.hddguru.com/viewtopic.php?f=1&t=8374&p=185385&hilit=RDX#p185385
PostPosted: October 20th, 2015, 8:18
Thank you very much. You've been very helpful with this!
It appears to be impossible to unlock this drive though.
I'll post here if I find a solution.
Cheers!
PostPosted: October 20th, 2015, 8:27
Www.sediv.net
PostPosted: October 20th, 2015, 16:57
ZU is a DOS tool. You need to boot to real DOS. You cannot run ZU in a Windows DOS box, if that is what you are trying to do.
PostPosted: October 21st, 2015, 2:57
Yeah, I figured it out. ;)
Rushed my reply a bit.
I will try to do things all of you mentioned.
I searched the web before and I didn't found them so you've been a great help.
