 Post subject: How to remove password from Seagate HDD ST9500325AS?
PostPosted: April 2nd, 2011, 17:15
Hi there, I have an Seagate Momentus 5400.6 ST9500325AS, and he was passwded. How can i remove the passwd?
I`v tried the http://www.seagateunlock.com/, and this dosen`t work, the passwords from the tutorial was not good.
Anybody has a firmware for this HDD to try with this method?
I don`t care if i lose the data, but if i can to recover anything that will be ok too.
Anybody can help me?
 Post subject: Re: How to remove password from Seagate HDD ST9500325AS?
PostPosted: April 3rd, 2011, 12:10
Same answer: unlock-seagate-pipline-t19005.html
ACELab partner
PostPosted: April 3rd, 2011, 16:13
You need tools to do this one. Then more than likely you will be asked if it is your drive. Did you set a PW on it and forget what you set. Try checking to see if your cap lock is on or off an try both of them.
Iorana Haraharaini
PostPosted: October 22nd, 2015, 6:50
I have to push this Thread ....
Cause i have the same Problems like dgtpro..
i have an Security locked Seagate Drive Momentus 5400.6 ST9500325AS out of my Settop Box. But this STB got defective and i do not need tho replace this, but i want to use the HDD out of this.
I could not get any Firmware from Segate, cause this drive is an OEM Product....
Can anybody provide me a Firmware to delete the Security lock. There is no need to Keep the data or resolve this..
Just using this 500 GB HDD...
Thanks in advance...
Big11
PostPosted: October 27th, 2015, 14:56
many thanks for this hint...
I would try this method, but where i can get such tiny connectors for the Jumpers of my 2,5" HDD ?
any suggestions ?
Thnks..
big11
Users browsing this forum: Google [Bot] and 215 guests
