 Post subject: Fix HDDHackr incorrect restore with WDR
PostPosted: October 28th, 2015, 0:44
Here's another "HDDHackr ruined my drive" thread :D I've tried to go as far as I could on my own, but now I'm stuck. I've already bought a replacement, so I don't need that tip. And I also don't need to save/restore any data. I just think it would be fun/interesting to make the disk run again. I don't have any other working drive of the exact same model.
Background:
After changing idle time from 8 to 300 with wdidle3 and flashing with HDDHackr, the drive clicked shortly after booting which restarted the xbox. I thought there was a problem with the flashing and tried a bunch of times with different versions of HDDHackr, without any difference. (I guess it had to do with wdidle3 because I got the same symptom on the other drive, which went away after restoring the original idle setting.) But before that, here's where it went wrong, in a moment of frustration I restored to one of the included recovery files from HDDHackr. I thought it was enough that the last part of the model was the same, WD3200BEVT-22ZCT0.
Now the drive can't be identified anymore. I think I read what fzabkar wrote somewhere that some info in the ROM must match. With WDR6 I can read the ROM successfully (Read Flash - OK). I replaced 0D with the info from my UNDO.BIN and wrote it back to the drive. But still the same symptoms. Do I need to fix checksum for the change I did? It's annoying to work with because 4/5 times Windows locks after connecting the drive.
AFAIK I don't have access to the platters. In this thread there is a tip about loading overlay, might that help? How would I find a compatible overlay?
Passport is empty. If I right click and try to change model name, FW ver. or SN for example, under Actions, I get an error. "Get Model Name - 3042=UNKNOWN ERROR 3042"
SMART is empty. "S.M.A.R.T. status - BAD"
The only module I can read is 01. I will try to provide all info I can.
Drive Info
WDC ROM MODEL-DENALI- FW:08.FAD SN:WDC-ROM SN# XYZ---- (ROYL selected) port 0x170
Logical: Cyls 0, Heads 0, Sectors 0, LBA 0, 0Gb
Controller Buffer Size: 0Kb
Family: Denali (Royl)
DIR Rev.
ROM Rev: 08.FAD
Mod 0D : 00010000 (01.00)
Mod 4F : 000800FA (08.FA)
DIR Rev: 00020000 (02.00)
Drive Parameters
DRIVE DATA TABLES
Drive Data Table Version   2
Product ID                 129E
Controller Firmware Rev.   08.FAD
Overlay Firmware Revision  08.FAD
Servo Firmware Revision    02.D4
Read Channel Firmware Rev. 0128016S
Surface Format Version     L3.201
Drive Type                 3 - Mobile 2.5 Inch
Spindle Speed              5406 RPM
Area Density in Units of   0 MB per platter
Drive Build Information
Drive Platter Count        2
Physical HDs includ. depop 4
Virtual Heads Count        1
Heads BitMap Value         F
Zones Num                  21
Servo Wedges Num           208
RSVD Cylinders Count       128
User Cylinders Count       0
Cylinder Wedge Skew        28
Head Wedge Skew            40
Cluster Skew               68
ROM Type                   6 - Manteca
Flash Size                 192KB
Flash Programming Protocol 1
PCBA Type                  0 - Entek
PCBA Revision              0
Interface Type             2 Serial ATA
Drive Parts Information
Controller Chip Vendor     0
Controller Chip Revision   42B1 -
Controller Chip Family ID  44E -
MicroP Vendor              0
MicroP Revision            42B1
Channel Chip Vendor        E6
Channel Chip Revision      11
Preamp Vendor              2
Preamp Revision            1
Power IC Vendor            0
Power IC Revision          0
Feature Flags              7BB6
Jumper Setting Value       0
Drive Format Information
Tracks Per Inch            0K
Area Density               0 per platter
Format Type                0
Drive Format Type          0 Alternate
Head Format Class          0
HDA Type (max platters num)0
SATA IPM Timers
Partial                    5 ms
Slumber                    100 ms
Error Correction Information
No. of Interleaves         1
OTF Corr. Span in Bytes    22
Max FW Corr. Span in Bytes 43
No. of ECC and CRC Bytes   55
ReloList File Information
Relocations                0
Tares                      0
Ftares                     0
Possible Remaining Relos   0
Consumed Spares            0
Last LBA of Spare Pool     0
Original Drive Built Date
Drive Reconfiguration Date
MDL string                 WDC ROM MODEL-DENALI-
S/N string                 WDC-ROM SN# XYZ----
DCM:
Show ID47
ID47 Data:
Data DAC Table   , Offset: 0030
40 33 C0 D0 44 48 80 4D 11 00 01 06 14 56 24 C1 E0 F5 FA 12 01 00 35 81 30 3C 1D 03 7F 00 54 CD 10 80 70 0A 09 0A 09 00
40 15 C0 70 44 50 80 4D 11 02 FF 0F 05 56 53 C1 CA F0 F4 02 01 00 20 81 30 3C 1D 00 7F 00 54 CD 10 80 70 0A 0B 0B 0C 00
40 3E C0 20 44 50 80 4D 11 05 05 12 14 56 D7 E8 F8 F8 FE 02 01 00 21 81 30 3C 1D 00 7F 00 54 CD 10 80 70 0A 0A 0B 09 00
40 42 C0 50 44 48 80 4D 11 03 05 0E 14 56 08 C8 F2 F5 FD 02 01 00 39 81 30 3C 1D 01 7F 00 54 CD 10 80 70 0A 09 0A 09 00
40 40 C0 A0 44 78 80 4D 11 02 04 09 14 56 34 C5 D5 F9 FD 02 03 00 20 81 30 3C 1D 00 7F 00 54 CD 10 80 70 0A 06 0B 06 00
Preamp DAC Table , Offset: 0120
09 D3 6E 05
0B D3 82 04
0A D2 7D 04
0C D2 96 07
00 04 0A 05
00 04 0A 05
MRJog Table      , Offset: 0138
02 09
22 09
2C 09
3A 09
00 0B
00 0B
UNDO.BIN
00000000  52 4F 59 4C 04 00 1E 00 0D 00 01 00 82 A9 8D 6B  ROYL........‚©.k
00000010  30 30 30 31 30 30 30 30 00 00 00 00 00 00 00 01  00010000........
00000020  31 31 2E 30 31 41 31 31 00 01 03 01 00 00 50 01  11.01A11......P.
00000030  4E E0 01 9F 2C 70 00 01 FE FF 00 00 00 00 02 00  Nà.Ÿ,p..þÿ......
00000040  01 01 00 00 00 00 20 20 20 20 20 20 20 20 20 20  ......
00000050  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
00000060  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
00000070  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
00000080  20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00    ..............
00000090  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000000F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000100  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000110  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000120  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000130  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000140  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000150  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000160  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000170  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000180  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000190  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000001A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000001B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000001C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000001D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000001E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000001F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000200  52 4F 59 4C 01 00 30 00 02 00 03 00 16 1C E6 00  ROYL..0.......æ.
00000210  30 30 30 38 30 30 30 30 07 07 07 00 00 00 00 00  00080000........
00000220  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000230  1C 00 A2 00 17 00 B9 00 18 00 D1 00 26 00 F7 00  ..¢...¹...Ñ.&.÷.
00000240  33 00 90 01 0C 00 9C 01 12 00 C0 01 04 00 C4 01  3.....œ...À...Ä.
00000250  06 00 CA 01 13 00 DD 01 11 00 EE 01 27 00 15 02  ..Ê...Ý...î.'...
00000260  12 00 27 02 20 00 47 02 39 00 80 02 0D 00 8D 02  ..'. .G.9.€.....
00000270  0E 00 9B 02 44 00 DF 02 46 00 25 03 48 00 2A 01  ..›.D.ß.F.%.H.*.
00000280  33 00 5D 01 33 00 AE 01 12 00 6D 03 10 00 7D 03  3.].3.®...m...}.
00000290  0E 00 8B 03 56 00 E1 03 1A 00 FB 03 2D 00 28 04  ..‹.V.á...û.-.(.
000002A0  02 00 00 01 57 44 2D 57 58 36 30 41 39 39 34 30  ....WD-WX60A9940
000002B0  37 30 39 00 00 00 00 00 00 00 01 10 3F 00 00 00  709.........?...
000002C0  00 AF EA 42 25 AF EA 42 25 AF EA 42 25 AF EA 42  .¯êB%¯êB%¯êB%¯êB
000002D0  25 00 01 A4 03 00 00 00 00 07 7F 00 00 06 F4 01  %..¤..........ô.
000002E0  01 10 01 00 0C 18 01 64 00 00 00 00 01 0A 14 00  .......d........
000002F0  00 00 14 00 00 00 01 00 01 01 00 40 00 40 01 32  ...........@.@.2
00000300  00 05 07 00 01 00 02 80 00 3C 00 80 00 00 80 08  .......€.<.€..€.
00000310  10 0A 05 0A 24 2E 42 5F 78 80 80 00 08 00 05 03  ....$.B_x€€.....
00000320  00 02 00 03 06 00 08 00 04 0F 00 01 01 00 C8 00  ..............È.
00000330  00 04 32 00 05 07 00 01 00 02 80 00 C8 00 80 00  ..2.......€.È.€.
00000340  00 80 08 10 0A 05 0A 14 28 5F 5F 78 80 80 00 08  .€......(__x€€..
00000350  00 05 03 00 02 00 05 06 00 08 00 10 0F 00 01 01  ................
00000360  00 C8 00 00 04 32 00 05 07 00 01 00 02 80 00 C8  .È...2.......€.È
00000370  00 80 00 00 80 08 10 0A 05 0A 14 28 5F 5F 78 80  .€..€......(__x€
00000380  80 00 08 00 05 03 00 02 00 10 07 00 08 00 10 0F  €...............
00000390  00 01 00 01 00 01 02 0A 0B 07 05 02 00 01 02 06  ................
000003A0  02 00 00 02 06 00 00 06 04 00 03 02 00 16 00 01  ................
000003B0  02 06 02 00 00 02 03 00 00 06 06 00 05 0A 00 16  ................
000003C0  00 01 01 01 00 01 14 64 00 00 00 01 64 00 00 4E  .......d....d..N
000003D0  00 00 7E 00 00 07 01 78 03 00 64 00 00 00 03 84  ..~....x..d....„
000003E0  7C D0 00 0A 00 14 3C 40 00 01 04 0A FA 00 00 01  |Ð....<@....ú...
000003F0  0E 00 00 00 02 02 00 0F 32 0C CA FA 0A 32 0A 01  ........2.Êú.2..
00000400  3C 55 00 01 00 00 20 00 64 00 00 BA 00 19 01 00  <U.... .d..º....
00000410  00 00 00 00 00 00 01 60 02 12 00 22 00 0A 00 00  .......`..."....
00000420  00 00 00 01 01 01 00 00 01 E0 01 0F 0F 01 02 02  .........à......
00000430  0A 01 02 00 02 02 08 01 00 FF FF 02 03 8A 01 1E  .........ÿÿ..Š..
00000440  64 00 11 04 40 0B 02 00 01 00 00 00 00 05 00 00  d...@...........
00000450  00 00 00 FF FF 00 00 00 00 12 0A 12 00 00 00 05  ...ÿÿ...........
00000460  00 00 00 00 00 1E 00 00 00 00 00 00 00 00 00 4D  ...............M
00000470  00 29 00 07 00 12 2E 00 00 00 0E 00 00 00 00 05  .)..............
00000480  00 01 00 00 00 00 00 00 07 00 01 02 0D 00 01 03  ................
00000490  00 03 01 00 01 00 00 00 00 00 00 00 01 57 44 43  .............WDC
000004A0  20 57 44 33 32 30 30 42 45 56 54 2D 32 32 5A 43   WD3200BEVT-22ZC
000004B0  54 30 20 20 20 20 20 20 20 20 20 20 20 20 20 20  T0
000004C0  20 20 20 20 20 20 20 20 20 00 00 00 00 00 00 00           .......
000004D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000004E0  01 53 7C 42 7C 4C 7C 50 4D 4D 57 48 47 43 5A 52  .S|B|L|PMMWHGCZR
000004F0  48 56 5A 4B 52 55 46 00 20 20 20 20 20 20 20 20  HVZKRUF.
00000500  20 20 20 20 20 30 39 2D 32 34 2D 32 30 30 39 00       09-24-2009.
00000510  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000520  00 00 00 00 00 00 01 01 00 00 00 00 00 00 00 00  ................
00000530  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000540  00 00 00 00 00 00 00 00 00 57 44 43 57 44 43 57  .........WDCWDCW
00000550  44 43 57 44 43 57 44 43 57 44 43 57 44 43 57 44  DCWDCWDCWDCWDCWD
00000560  43 57 44 43 57 44 43 57 00 08 40 FE FF 00 01 30  CWDCWDCW..@þÿ..0
00000570  00 00 05 00 64 00 0A 20 32 00 00 00 0F 00 01 02  ....d.. 2.......
00000580  00 00 01 78 00 32 00 20 00 55 FF 00 01 00 00 00  ...x.2. .Uÿ.....
00000590  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000005A0  00 00 00 00 00 58 58 58 58 58 58 58 58 58 58 58  .....XXXXXXXXXXX
000005B0  58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58  XXXXXXXXXXXXXXXX
000005C0  58 58 58 58 58 58 58 58 58 58 58 58 58 58 58 58  XXXXXXXXXXXXXXXX
000005D0  58 58 58 58 58 01 01 01 01 01 00 00 00 00 00 00  XXXXX...........
000005E0  00 00 00 00 01 30 30 5A 43 30 30 32 32 25 00 01  .....00ZC0022%..
000005F0  00 01 00 00 00 00 00 00 00 00 00 00 01 02 05 10  ................
00000600  27 00 00 88 13 00 00 00 00 D0 07 00 00 88 13 00  '..ˆ.....Ð...ˆ..
00000610  00 1E 00 00 00 05 C8 00 00 00 00 00 00 00 00 00  ......È.........
00000620  01 00 09 01 00 00 00 00 00 01 00 00 00 00 00 00  ................
00000630  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000640  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000650  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000660  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000670  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000680  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000690  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000006A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000006B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000006C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000006D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000006E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000006F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000700  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000710  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000720  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000730  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000740  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000750  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000760  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000770  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000780  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000790  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000007A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000007B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000007C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000007D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000007E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000007F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
WD3200BEVT-22ZCT0_hddhackr.zip [775 Bytes]
Downloaded 562 times
08FA.zip [165.09 KiB]
Downloaded 709 times
 Post subject: Re: Fix HDDHackr incorrect restore with WDR
PostPosted: October 28th, 2015, 0:55
Mod 01
00000000  52 4F 59 4C 01 00 30 00 01 00 18 00 BB 75 4B 48  ROYL..0.....»uKH
00000010  30 30 30 32 30 30 30 30 01 02 03 04 05 00 06 00  00020000........
00000020  07 00 00 00 08 00 00 00 09 00 00 00 0A 00 00 00  ................
00000030  5E 01 12 02 01 00 18 00 03 18 00 00 00 00 00 00  ^...............
00000040  00 00 00 00 12 02 35 00 0A 00 03 18 80 00 18 00  ......5.....€...
00000050  00 00 18 00 00 00 12 02 6D 00 01 00 03 18 00 00  ........m.......
00000060  6A 2C 00 00 6A 2C 00 00 12 02 10 01 18 00 03 18  j,..j,..........
00000070  90 00 65 FC 00 00 65 FC 00 00 12 02 02 01 01 00  ..eü..eü........
00000080  03 18 10 00 64 FC 00 00 64 FC 00 00 12 02 03 01  ....dü..dü......
00000090  02 00 03 18 10 00 62 FC 00 00 62 FC 00 00 12 02  ......bü..bü....
000000A0  04 01 01 00 03 18 10 00 61 FC 00 00 61 FC 00 00  ........aü..aü..
000000B0  12 02 05 01 02 00 03 18 10 00 5F FC 00 00 5F FC  .........._ü.._ü
000000C0  00 00 12 02 07 01 01 00 03 18 10 00 5E FC 00 00  ............^ü..
000000D0  5E FC 00 00 12 02 06 01 01 00 03 18 10 00 5D FC  ^ü............]ü
000000E0  00 00 5D FC 00 00 12 02 08 01 20 00 03 98 10 00  ..]ü...... ..˜..
000000F0  26 00 00 00 26 00 00 00 12 02 02 00 03 00 03 18  &...&...........
00000100  90 00 A1 FC 00 00 A1 FC 00 00 12 02 17 00 40 00  ..¡ü..¡ü......@.
00000110  03 18 90 00 A4 FC 00 00 A4 FC 00 00 12 02 1B 00  ....¤ü..¤ü......
00000120  7B 00 03 18 90 00 E4 FC 00 00 E4 FC 00 00 12 02  {.....äü..äü....
00000130  1C 00 2F 00 03 18 90 00 5F FD 00 00 5F FD 00 00  ../....._ý.._ý..
00000140  12 02 14 00 1B 00 03 18 90 00 8E FD 00 00 8E FD  ..........Žý..Žý
00000150  00 00 12 02 15 00 10 00 03 18 90 00 A9 FD 00 00  ............©ý..
00000160  A9 FD 00 00 12 02 1E 00 16 00 03 18 90 00 B9 FD  ©ý............¹ý
00000170  00 00 B9 FD 00 00 12 02 2F 00 05 00 03 18 90 00  ..¹ý..../.......
00000180  CF FD 00 00 CF FD 00 00 12 02 2A 00 05 00 03 18  Ïý..Ïý....*.....
00000190  90 00 D4 FD 00 00 D4 FD 00 00 12 02 21 00 4B 00  ..Ôý..Ôý....!.K.
000001A0  03 18 90 00 D9 FD 00 00 D9 FD 00 00 12 02 22 00  ....Ùý..Ùý....".
000001B0  4B 00 03 18 90 00 24 FE 00 00 24 FE 00 00 12 02  K.....$þ..$þ....
000001C0  23 00 4B 00 03 18 90 00 6F FE 00 00 6F FE 00 00  #.K.....oþ..oþ..
000001D0  12 02 24 00 4B 00 03 18 90 00 BA FE 00 00 BA FE  ..$.K.....ºþ..ºþ
000001E0  00 00 12 02 11 00 D9 01 03 18 90 00 05 FF 00 00  ......Ù......ÿ..
000001F0  05 FF 00 00 12 02 19 00 1F 00 03 18 90 00 DE 00  .ÿ............Þ.
00000200  01 00 DE 00 01 00 12 02 12 00 35 00 03 18 90 00  ..Þ.......5.....
00000210  FD 00 01 00 FD 00 01 00 12 02 50 00 02 00 03 18  ý...ý.....P.....
00000220  90 00 32 01 01 00 32 01 01 00 12 02 51 00 02 00  ..2...2.....Q...
00000230  03 18 90 00 34 01 01 00 34 01 01 00 12 02 1F 00  ....4...4.......
00000240  15 00 03 18 90 00 36 01 01 00 36 01 01 00 12 02  ......6...6.....
00000250  6E 00 02 00 03 18 90 00 4B 01 01 00 4B 01 01 00  n.......K...K...
00000260  12 02 6F 00 FA 00 03 18 90 00 4D 01 01 00 4D 01  ..o.ú.....M...M.
00000270  01 00 12 02 16 01 06 00 03 18 80 00 6B 2C 00 00  ..........€.k,..
00000280  6B 2C 00 00 12 02 18 01 11 00 03 18 80 00 71 2C  k,..........€.q,
00000290  00 00 71 2C 00 00 12 02 55 AC 01 00 03 18 90 00  ..q,....U¬......
000002A0  5E 02 01 00 5E 02 01 00 12 02 09 01 81 01 03 18  ^...^...........
000002B0  10 00 46 00 00 00 46 00 00 00 12 02 04 36 10 00  ..F...F......6..
000002C0  03 18 00 00 EF FB 00 00 EF FB 00 00 12 02 33 00  ....ïû..ïû....3.
000002D0  22 01 03 18 08 00 C7 01 00 00 C7 01 00 00 12 02  ".....Ç...Ç.....
000002E0  31 00 B0 00 03 18 88 00 E9 02 00 00 E9 02 00 00  1.°...ˆ.é...é...
000002F0  12 02 0C 00 04 00 03 18 88 00 99 03 00 00 99 03  ........ˆ.™...™.
00000300  00 00 12 02 34 00 17 00 03 18 88 00 9D 03 00 00  ....4.....ˆ.....
00000310  9D 03 00 00 12 02 32 00 20 00 03 18 88 00 B4 03  ......2. ...ˆ.´.
00000320  00 00 B4 03 00 00 12 02 36 00 07 00 03 18 88 00  ..´.....6.....ˆ.
00000330  D4 03 00 00 D4 03 00 00 12 02 29 00 05 00 03 18  Ô...Ô.....).....
00000340  88 00 DB 03 00 00 DB 03 00 00 12 02 40 00 69 00  ˆ.Û...Û.....@.i.
00000350  03 18 88 00 E0 03 00 00 E0 03 00 00 12 02 41 00  ..ˆ.à...à.....A.
00000360  69 00 03 18 88 00 49 04 00 00 49 04 00 00 12 02  i...ˆ.I...I.....
00000370  42 00 69 00 03 18 88 00 B2 04 00 00 B2 04 00 00  B.i...ˆ.²...²...
00000380  12 02 43 00 69 00 03 18 88 00 1B 05 00 00 1B 05  ..C.i...ˆ.......
00000390  00 00 12 02 4E 00 27 02 03 18 80 00 84 05 00 00  ....N.'...€.„...
000003A0  84 05 00 00 12 02 49 00 02 00 03 18 88 00 AB 07  „.....I.....ˆ.«.
000003B0  00 00 AB 07 00 00 12 02 4A 00 05 00 03 18 88 00  ..«.....J.....ˆ.
000003C0  AD 07 00 00 AD 07 00 00 12 02 4D 00 01 00 03 18  ..........M.....
000003D0  88 00 B2 07 00 00 B2 07 00 00 12 02 03 00 22 00  ˆ.²...².......".
000003E0  03 18 88 00 B3 07 00 00 B3 07 00 00 12 02 04 00  ..ˆ.³...³.......
000003F0  A1 1E 03 18 00 00 D5 07 00 00 D5 07 00 00 12 02  ¡.....Õ...Õ.....
00000400  25 00 01 01 03 18 80 00 76 26 00 00 76 26 00 00  %.....€.v&..v&..
00000410  12 02 26 00 81 00 03 18 80 00 77 27 00 00 77 27  ..&.....€.w'..w'
00000420  00 00 12 02 38 00 01 01 03 18 80 00 F8 27 00 00  ....8.....€.ø'..
00000430  F8 27 00 00 12 02 39 00 11 00 03 18 80 00 F9 28  ø'....9.....€.ù(
00000440  00 00 F9 28 00 00 12 02 37 00 01 00 03 18 88 00  ..ù(....7.....ˆ.
00000450  0A 29 00 00 0A 29 00 00 12 02 2D 00 2C 01 03 18  .)...)....-.,...
00000460  00 00 0B 29 00 00 0B 29 00 00 12 02 2E 00 2C 01  ...)...)......,.
00000470  03 18 00 00 37 2A 00 00 37 2A 00 00 12 02 B5 00  ....7*..7*....µ.
00000480  A0 00 03 18 80 00 63 2B 00 00 63 2B 00 00 12 02   ...€.c+..c+....
00000490  6B 00 04 00 03 98 80 00 03 2C 00 00 03 2C 00 00  k....˜€..,...,..
000004A0  12 02 3A 00 03 00 03 18 88 00 07 2C 00 00 07 2C  ..:.....ˆ..,...,
000004B0  00 00 12 02 28 00 10 00 03 18 08 00 0A 2C 00 00  ....(........,..
000004C0  0A 2C 00 00 12 02 3B 00 10 00 03 18 08 00 1A 2C  .,....;........,
000004D0  00 00 1A 2C 00 00 12 02 3C 00 10 00 03 18 08 00  ...,....<.......
000004E0  2A 2C 00 00 2A 2C 00 00 12 02 3D 00 10 00 03 18  *,..*,....=.....
000004F0  08 00 3A 2C 00 00 3A 2C 00 00 12 02 3E 00 10 00  ..:,..:,....>...
00000500  03 18 08 00 4A 2C 00 00 4A 2C 00 00 12 02 3F 00  ....J,..J,....?.
00000510  10 00 03 18 08 00 5A 2C 00 00 5A 2C 00 00 12 02  ......Z,..Z,....
00000520  68 00 4B 00 03 18 00 00 82 2C 00 00 82 2C 00 00  h.K.....‚,..‚,..
00000530  12 02 69 00 4B 00 03 18 00 00 CD 2C 00 00 CD 2C  ..i.K.....Í,..Í,
00000540  00 00 12 02 6A 00 4B 00 03 18 00 00 18 2D 00 00  ....j.K......-..
00000550  18 2D 00 00 12 02 15 01 61 00 03 18 90 00 7F 03  .-......a.......
00000560  01 00 7F 03 01 00 12 02 02 35 95 00 03 18 00 00  .........5•.....
00000570  68 2D 00 00 68 2D 00 00 12 02 DE 00 CC 00 03 18  h-..h-....Þ.Ì...
00000580  00 00 FD 2D 00 00 FD 2D 00 00 12 02 B6 00 BC 00  ..ý-..ý-....¶.¼.
00000590  03 18 00 00 C9 2E 00 00 C9 2E 00 00 12 02 D5 00  ....É...É.....Õ.
000005A0  B3 00 03 18 00 00 85 2F 00 00 85 2F 00 00 12 02  ³.....…/..…/....
000005B0  11 34 72 00 03 18 00 00 38 30 00 00 38 30 00 00  .4r.....80..80..
000005C0  12 02 D1 00 DF 00 03 18 00 00 AA 30 00 00 AA 30  ..Ñ.ß.....ª0..ª0
000005D0  00 00 12 02 DB 00 C0 00 03 18 00 00 89 31 00 00  ....Û.À.....‰1..
000005E0  89 31 00 00 12 02 DF 00 DB 00 03 18 00 00 49 32  ‰1....ß.Û.....I2
000005F0  00 00 49 32 00 00 12 02 DD 00 BA 00 03 18 00 00  ..I2....Ý.º.....
00000600  24 33 00 00 24 33 00 00 12 02 D6 00 BC 00 03 18  $3..$3....Ö.¼...
00000610  00 00 DE 33 00 00 DE 33 00 00 12 02 02 34 C3 00  ..Þ3..Þ3.....4Ã.
00000620  03 18 00 00 9A 34 00 00 9A 34 00 00 12 02 D7 00  ....š4..š4....×.
00000630  BD 00 03 18 00 00 5D 35 00 00 5D 35 00 00 12 02  ½.....]5..]5....
00000640  D2 00 80 00 03 18 00 00 1A 36 00 00 1A 36 00 00  Ò.€......6...6..
00000650  12 02 00 33 83 00 03 18 00 00 9A 36 00 00 9A 36  ...3ƒ.....š6..š6
00000660  00 00 12 02 01 33 9A 00 03 18 00 00 1D 37 00 00  .....3š......7..
00000670  1D 37 00 00 12 02 BB 00 93 00 03 18 00 00 B7 37  .7....».“.....·7
00000680  00 00 B7 37 00 00 12 02 00 34 A3 00 03 18 00 00  ..·7.....4£.....
00000690  4A 38 00 00 4A 38 00 00 12 02 05 34 99 00 03 18  J8..J8.....4™...
000006A0  00 00 ED 38 00 00 ED 38 00 00 12 02 D9 00 B9 00  ..í8..í8....Ù.¹.
000006B0  03 18 00 00 86 39 00 00 86 39 00 00 12 02 D4 00  ....†9..†9....Ô.
000006C0  7F 00 03 18 00 00 3F 3A 00 00 3F 3A 00 00 12 02  ......?:..?:....
000006D0  DC 00 87 00 03 18 00 00 BE 3A 00 00 BE 3A 00 00  Ü.‡.....¾:..¾:..
000006E0  12 02 D0 00 83 00 03 18 00 00 45 3B 00 00 45 3B  ..Ð.ƒ.....E;..E;
000006F0  00 00 12 02 D3 00 70 00 03 18 00 00 C8 3B 00 00  ....Ó.p.....È;..
00000700  C8 3B 00 00 12 02 F7 00 B8 00 03 18 00 00 38 3C  È;....÷.¸.....8<
00000710  00 00 38 3C 00 00 12 02 BA 00 9D 00 03 18 00 00  ..8<....º.......
00000720  F0 3C 00 00 F0 3C 00 00 12 02 06 34 96 00 03 18  ð<..ð<.....4–...
00000730  00 00 8D 3D 00 00 8D 3D 00 00 12 02 B9 00 9A 00  ...=...=....¹.š.
00000740  03 18 00 00 23 3E 00 00 23 3E 00 00 12 02 BC 00  ....#>..#>....¼.
00000750  96 00 03 18 00 00 BD 3E 00 00 BD 3E 00 00 12 02  –.....½>..½>....
00000760  D8 00 73 00 03 18 00 00 53 3F 00 00 53 3F 00 00  Ø.s.....S?..S?..
00000770  12 02 BD 00 DB 00 03 18 00 00 C6 3F 00 00 C6 3F  ..½.Û.....Æ?..Æ?
00000780  00 00 12 02 BE 00 15 00 03 18 00 00 A1 40 00 00  ....¾.......¡@..
00000790  A1 40 00 00 12 02 01 34 94 00 03 18 00 00 B6 40  ¡@.....4”.....¶@
000007A0  00 00 B6 40 00 00 12 02 02 33 83 00 03 18 00 00  ..¶@.....3ƒ.....
000007B0  4A 41 00 00 4A 41 00 00 12 02 B8 00 02 00 03 18  JA..JA....¸.....
000007C0  00 00 CD 41 00 00 CD 41 00 00 12 02 BF 00 08 00  ..ÍA..ÍA....¿...
000007D0  03 18 00 00 CF 41 00 00 CF 41 00 00 12 02 E6 00  ....ÏA..ÏA....æ.
000007E0  40 00 03 18 00 00 D7 41 00 00 D7 41 00 00 12 02  @.....×A..×A....
000007F0  E7 00 20 00 03 18 00 00 17 42 00 00 17 42 00 00  ç. ......B...B..
00000800  12 02 B7 00 0A 00 03 18 04 00 7D FC 00 00 7D FC  ..·.......}ü..}ü
00000810  00 00 12 02 FA 00 00 01 03 18 04 00 5F 02 01 00  ....ú......._...
00000820  5F 02 01 00 12 02 FC 00 04 00 03 18 04 00 22 00  _.....ü.......".
00000830  00 00 22 00 00 00 12 02 FD 00 40 00 03 18 04 00  ..".....ý.@.....
00000840  54 44 00 00 54 44 00 00 12 02 EE 00 04 00 03 18  TD..TD....î.....
00000850  04 00 47 02 01 00 47 02 01 00 12 02 00 3E 04 00  ..G...G......>..
00000860  03 18 04 00 87 FC 00 00 87 FC 00 00 12 02 01 38  ....‡ü..‡ü.....8
00000870  20 00 03 18 00 00 37 42 00 00 37 42 00 00 12 02   .....7B..7B....
00000880  00 3C 20 00 03 18 04 00 5F 03 01 00 5F 03 01 00  .< ....._..._...
00000890  12 02 15 34 66 01 03 18 00 00 57 42 00 00 57 42  ...4f.....WB..WB
000008A0  00 00 12 02 01 35 97 00 03 18 00 00 BD 43 00 00  .....5—.....½C..
000008B0  BD 43 00 00 12 02 C4 00 DE 00 03 98 00 00 97 44  ½C....Ä.Þ..˜..—D
000008C0  00 00 97 44 00 00 12 02 A8 00 97 00 03 98 00 00  ..—D....¨.—..˜..
000008D0  75 45 00 00 75 45 00 00 12 02 A2 00 DF 00 03 98  uE..uE....¢.ß..˜
000008E0  00 00 0C 46 00 00 0C 46 00 00 12 02 C5 00 72 00  ...F...F....Å.r.
000008F0  03 18 00 00 EB 46 00 00 EB 46 00 00 12 02 C3 00  ....ëF..ëF....Ã.
00000900  C7 00 03 98 00 00 C6 F9 00 00 C6 F9 00 00 12 02  Ç..˜..Æù..Æù....
00000910  C8 00 D9 00 03 98 00 00 8D FA 00 00 8D FA 00 00  È.Ù..˜...ú...ú..
00000920  12 02 91 00 04 00 03 18 00 00 66 FB 00 00 66 FB  ..‘.......fû..fû
00000930  00 00 12 02 CC 00 06 00 03 18 04 00 58 02 01 00  ....Ì.......X...
00000940  58 02 01 00 12 02 CA 00 06 00 03 18 04 00 52 02  X.....Ê.......R.
00000950  01 00 52 02 01 00 12 02 99 00 06 00 03 18 04 00  ..R.....™.......
00000960  4C 02 01 00 4C 02 01 00 12 02 98 00 18 00 03 18  L...L.....˜.....
00000970  04 00 E2 F6 00 00 E2 F6 00 00 12 02 CB 00 06 00  ..âö..âö....Ë...
00000980  03 18 04 00 9B FC 00 00 9B FC 00 00 12 02 CD 00  ....›ü..›ü....Í.
00000990  06 00 03 18 04 00 95 FC 00 00 95 FC 00 00 12 02  ......•ü..•ü....
000009A0  CF 00 06 00 03 18 04 00 8F FC 00 00 8F FC 00 00  Ï........ü...ü..
000009B0  12 02 CE 00 06 00 03 18 04 00 DC F6 00 00 DC F6  ..Î.......Üö..Üö
000009C0  00 00 12 02 93 00 06 00 03 18 04 00 D6 F6 00 00  ....“.......Öö..
000009D0  D6 F6 00 00 12 02 C1 00 01 00 03 18 04 00 4B 02  Öö....Á.......K.
000009E0  01 00 4B 02 01 00 12 02 C2 00 02 00 03 18 00 00  ..K.....Â.......
000009F0  6A FB 00 00 6A FB 00 00 12 02 C7 00 01 00 03 18  jû..jû....Ç.....
00000A00  04 00 8E FC 00 00 8E FC 00 00 12 02 9E 00 05 00  ..Žü..Žü....ž...
00000A10  03 18 04 00 D1 F6 00 00 D1 F6 00 00 12 02 C6 00  ....Ñö..Ñö....Æ.
00000A20  59 00 03 18 04 00 78 F6 00 00 78 F6 00 00 12 02  Y.....xö..xö....
00000A30  C9 00 40 00 03 18 04 00 38 F6 00 00 38 F6 00 00  É.@.....8ö..8ö..
00000A40  12 02 94 00 0A 00 03 18 04 00 2E F6 00 00 2E F6  ..”........ö...ö
00000A50  00 00 12 02 96 00 78 00 03 18 04 00 B6 F5 00 00  ....–.x.....¶õ..
00000A60  B6 F5 00 00 12 02 97 00 18 00 03 18 04 00 9E F5  ¶õ....—.......žõ
00000A70  00 00 9E F5 00 00 12 02 AA 00 83 00 03 98 00 00  ..žõ....ª.ƒ..˜..
00000A80  6C FB 00 00 6C FB 00 00 12 02 A9 00 78 00 03 18  lû..lû....©.x...
00000A90  04 00 26 F5 00 00 26 F5 00 00 12 02 A5 00 0F 00  ..&õ..&õ....¥...
00000AA0  03 18 04 00 17 F5 00 00 17 F5 00 00 12 02 A6 00  .....õ...õ....¦.
00000AB0  68 01 03 18 04 00 AF F3 00 00 AF F3 00 00 12 02  h.....¯ó..¯ó....
00000AC0  92 00 32 00 03 18 04 00 7D F3 00 00 7D F3 00 00  ’.2.....}ó..}ó..
00000AD0  12 02 A0 00 40 00 03 18 04 00 3D F3 00 00 3D F3  .. .@.....=ó..=ó
00000AE0  00 00 12 02 A1 00 6E 00 03 98 00 00 5D 47 00 00  ....¡.n..˜..]G..
00000AF0  5D 47 00 00 12 02 9A 00 28 00 03 18 04 00 15 F3  ]G....š.(......ó
00000B00  00 00 15 F3 00 00 12 02 9C 00 01 00 03 18 04 00  ...ó....œ.......
00000B10  8D FC 00 00 8D FC 00 00 12 02 00 20 5E 01 03 18  .ü...ü..... ^...
00000B20  04 00 B7 F1 00 00 B7 F1 00 00 12 02 01 20 5E 01  ..·ñ..·ñ..... ^.
00000B30  03 18 04 00 59 F0 00 00 59 F0 00 00 12 02 02 20  ....Yð..Yð.....
00000B40  5E 01 03 18 04 00 FB EE 00 00 FB EE 00 00 12 02  ^.....ûî..ûî....
00000B50  03 20 5E 01 03 18 04 00 9D ED 00 00 9D ED 00 00  . ^......í...í..
00000B60  12 02 04 20 5E 01 03 18 04 00 3F EC 00 00 3F EC  ... ^.....?ì..?ì
00000B70  00 00 12 02 05 20 5E 01 03 18 04 00 E1 EA 00 00  ..... ^.....áê..
00000B80  E1 EA 00 00 12 02 06 20 5E 01 03 18 04 00 83 E9  áê..... ^.....ƒé
00000B90  00 00 83 E9 00 00 12 02 07 20 5E 01 03 18 04 00  ..ƒé..... ^.....
00000BA0  25 E8 00 00 25 E8 00 00 12 02 20 20 50 00 03 18  %è..%è....  P...
00000BB0  04 00 D5 E7 00 00 D5 E7 00 00 12 02 21 20 50 00  ..Õç..Õç....! P.
00000BC0  03 18 04 00 85 E7 00 00 85 E7 00 00 12 02 22 20  ....…ç..…ç...."
00000BD0  50 00 03 18 04 00 35 E7 00 00 35 E7 00 00 12 02  P.....5ç..5ç....
00000BE0  23 20 50 00 03 18 04 00 E5 E6 00 00 E5 E6 00 00  # P.....åæ..åæ..
00000BF0  12 02 24 20 50 00 03 18 04 00 95 E6 00 00 95 E6  ..$ P.....•æ..•æ
00000C00  00 00 12 02 25 20 50 00 03 18 04 00 45 E6 00 00  ....% P.....Eæ..
00000C10  45 E6 00 00 12 02 26 20 50 00 03 18 04 00 F5 E5  Eæ....& P.....õå
00000C20  00 00 F5 E5 00 00 12 02 27 20 50 00 03 18 04 00  ..õå....' P.....
00000C30  A5 E5 00 00 A5 E5 00 00 12 02 30 20 A0 00 03 18  ¥å..¥å....0  ...
00000C40  04 00 05 E5 00 00 05 E5 00 00 12 02 31 20 A0 00  ...å...å....1  .
00000C50  03 18 04 00 65 E4 00 00 65 E4 00 00 12 02 32 20  ....eä..eä....2
00000C60  A0 00 03 18 04 00 C5 E3 00 00 C5 E3 00 00 12 02   .....Åã..Åã....
00000C70  33 20 A0 00 03 18 04 00 25 E3 00 00 25 E3 00 00  3  .....%ã..%ã..
00000C80  12 02 34 20 A0 00 03 18 04 00 85 E2 00 00 85 E2  ..4  .....…â..…â
00000C90  00 00 12 02 35 20 A0 00 03 18 04 00 E5 E1 00 00  ....5  .....åá..
00000CA0  E5 E1 00 00 12 02 36 20 A0 00 03 18 04 00 45 E1  åá....6  .....Eá
00000CB0  00 00 45 E1 00 00 12 02 37 20 A0 00 03 18 04 00  ..Eá....7  .....
00000CC0  A5 E0 00 00 A5 E0 00 00 12 02 10 20 A0 00 03 18  ¥à..¥à.....  ...
00000CD0  04 00 05 E0 00 00 05 E0 00 00 12 02 11 20 A0 00  ...à...à.....  .
00000CE0  03 18 04 00 65 DF 00 00 65 DF 00 00 12 02 12 20  ....eß..eß.....
00000CF0  A0 00 03 18 04 00 C5 DE 00 00 C5 DE 00 00 12 02   .....ÅÞ..ÅÞ....
00000D00  13 20 A0 00 03 18 04 00 25 DE 00 00 25 DE 00 00  .  .....%Þ..%Þ..
00000D10  12 02 14 20 A0 00 03 18 04 00 85 DD 00 00 85 DD  ...  .....…Ý..…Ý
00000D20  00 00 12 02 15 20 A0 00 03 18 04 00 E5 DC 00 00  .....  .....åÜ..
00000D30  E5 DC 00 00 12 02 16 20 A0 00 03 18 04 00 45 DC  åÜ.....  .....EÜ
00000D40  00 00 45 DC 00 00 12 02 17 20 A0 00 03 18 04 00  ..EÜ.....  .....
00000D50  A5 DB 00 00 A5 DB 00 00 12 02 40 20 5E 01 03 18  ¥Û..¥Û....@ ^...
00000D60  04 00 47 DA 00 00 47 DA 00 00 12 02 41 20 5E 01  ..GÚ..GÚ....A ^.
00000D70  03 18 04 00 E9 D8 00 00 E9 D8 00 00 12 02 42 20  ....éØ..éØ....B
00000D80  5E 01 03 18 04 00 8B D7 00 00 8B D7 00 00 12 02  ^.....‹×..‹×....
00000D90  43 20 5E 01 03 18 04 00 2D D6 00 00 2D D6 00 00  C ^.....-Ö..-Ö..
00000DA0  12 02 44 20 5E 01 03 18 04 00 CF D4 00 00 CF D4  ..D ^.....ÏÔ..ÏÔ
00000DB0  00 00 12 02 45 20 5E 01 03 18 04 00 71 D3 00 00  ....E ^.....qÓ..
00000DC0  71 D3 00 00 12 02 46 20 5E 01 03 18 04 00 13 D2  qÓ....F ^......Ò
00000DD0  00 00 13 D2 00 00 12 02 47 20 5E 01 03 18 04 00  ...Ò....G ^.....
00000DE0  B5 D0 00 00 B5 D0 00 00 12 02 50 20 32 00 03 18  µÐ..µÐ....P 2...
00000DF0  04 00 83 D0 00 00 83 D0 00 00 12 02 51 20 32 00  ..ƒÐ..ƒÐ....Q 2.
00000E00  03 18 04 00 51 D0 00 00 51 D0 00 00 12 02 52 20  ....QÐ..QÐ....R
00000E10  32 00 03 18 04 00 1F D0 00 00 1F D0 00 00 12 02  2......Ð...Ð....
00000E20  53 20 32 00 03 18 04 00 ED CF 00 00 ED CF 00 00  S 2.....íÏ..íÏ..
00000E30  12 02 54 20 32 00 03 18 04 00 BB CF 00 00 BB CF  ..T 2.....»Ï..»Ï
00000E40  00 00 12 02 55 20 32 00 03 18 04 00 89 CF 00 00  ....U 2.....‰Ï..
00000E50  89 CF 00 00 12 02 56 20 32 00 03 18 04 00 57 CF  ‰Ï....V 2.....WÏ
00000E60  00 00 57 CF 00 00 12 02 57 20 32 00 03 18 04 00  ..WÏ....W 2.....
00000E70  25 CF 00 00 25 CF 00 00 12 02 60 20 3C 00 03 18  %Ï..%Ï....` <...
00000E80  04 00 E9 CE 00 00 E9 CE 00 00 12 02 61 20 3C 00  ..éÎ..éÎ....a <.
00000E90  03 18 04 00 AD CE 00 00 AD CE 00 00 12 02 62 20  .....Î...Î....b
00000EA0  3C 00 03 18 04 00 71 CE 00 00 71 CE 00 00 12 02  <.....qÎ..qÎ....
00000EB0  63 20 3C 00 03 18 04 00 35 CE 00 00 35 CE 00 00  c <.....5Î..5Î..
00000EC0  12 02 64 20 3C 00 03 18 04 00 F9 CD 00 00 F9 CD  ..d <.....ùÍ..ùÍ
00000ED0  00 00 12 02 65 20 3C 00 03 18 04 00 BD CD 00 00  ....e <.....½Í..
00000EE0  BD CD 00 00 12 02 66 20 3C 00 03 18 04 00 81 CD  ½Í....f <......Í
00000EF0  00 00 81 CD 00 00 12 02 67 20 3C 00 03 18 04 00  ...Í....g <.....
00000F00  45 CD 00 00 45 CD 00 00 12 02 10 80 05 00 03 18  EÍ..EÍ.....€....
00000F10  00 00 B6 C9 00 00 B6 C9 00 00 12 02 2C 80 03 00  ..¶É..¶É....,€..
00000F20  03 18 00 00 BB C9 00 00 BB C9 00 00 12 02 35 80  ....»É..»É....5€
00000F30  10 00 03 18 00 00 BE C9 00 00 BE C9 00 00 12 02  ......¾É..¾É....
00000F40  38 80 02 00 03 18 00 00 CE C9 00 00 CE C9 00 00  8€......ÎÉ..ÎÉ..
00000F50  12 02 3C 80 02 00 03 18 00 00 D0 C9 00 00 D0 C9  ..<€......ÐÉ..ÐÉ
00000F60  00 00 12 02 16 80 05 00 03 18 00 00 D2 C9 00 00  .....€......ÒÉ..
00000F70  D2 C9 00 00 12 02 1D 80 21 00 03 18 00 00 D7 C9  ÒÉ.....€!.....×É
00000F80  00 00 D7 C9 00 00 12 02 44 80 02 00 03 18 00 00  ..×É....D€......
00000F90  F8 C9 00 00 F8 C9 00 00 12 02 31 80 04 00 03 18  øÉ..øÉ....1€....
00000FA0  00 00 FA C9 00 00 FA C9 00 00 12 02 62 80 0D 00  ..úÉ..úÉ....b€..
00000FB0  03 18 00 00 FE C9 00 00 FE C9 00 00 12 02 63 80  ....þÉ..þÉ....c€
00000FC0  0D 00 03 18 00 00 0B CA 00 00 0B CA 00 00 12 02  .......Ê...Ê....
00000FD0  41 80 02 00 03 18 00 00 18 CA 00 00 18 CA 00 00  A€.......Ê...Ê..
00000FE0  12 02 42 80 02 00 03 18 00 00 1A CA 00 00 1A CA  ..B€.......Ê...Ê
00000FF0  00 00 12 02 0E 80 05 00 03 18 00 00 1C CA 00 00  .....€.......Ê..
00001000  1C CA 00 00 12 02 2D 80 21 00 03 18 00 00 21 CA  .Ê....-€!.....!Ê
00001010  00 00 21 CA 00 00 12 02 19 80 05 00 03 18 00 00  ..!Ê.....€......
00001020  42 CA 00 00 42 CA 00 00 12 02 2F 80 04 00 03 18  BÊ..BÊ..../€....
00001030  00 00 47 CA 00 00 47 CA 00 00 12 02 34 80 21 00  ..GÊ..GÊ....4€!.
00001040  03 18 00 00 4B CA 00 00 4B CA 00 00 12 02 2E 80  ....KÊ..KÊ.....€
00001050  04 00 03 18 00 00 6C CA 00 00 6C CA 00 00 12 02  ......lÊ..lÊ....
00001060  32 80 04 00 03 18 00 00 70 CA 00 00 70 CA 00 00  2€......pÊ..pÊ..
00001070  12 02 17 80 05 00 03 18 00 00 74 CA 00 00 74 CA  ...€......tÊ..tÊ
00001080  00 00 12 02 02 80 02 00 03 18 00 00 79 CA 00 00  .....€......yÊ..
00001090  79 CA 00 00 12 02 0B 80 02 00 03 18 00 00 7B CA  yÊ.....€......{Ê
000010A0  00 00 7B CA 00 00 12 02 05 80 02 00 03 18 00 00  ..{Ê.....€......
000010B0  7D CA 00 00 7D CA 00 00 12 02 20 80 04 00 03 18  }Ê..}Ê.... €....
000010C0  00 00 7F CA 00 00 7F CA 00 00 12 02 46 80 02 00  ...Ê...Ê....F€..
000010D0  03 18 00 00 83 CA 00 00 83 CA 00 00 12 02 45 80  ....ƒÊ..ƒÊ....E€
000010E0  02 00 03 18 00 00 85 CA 00 00 85 CA 00 00 12 02  ......…Ê..…Ê....
000010F0  27 80 02 00 03 18 00 00 87 CA 00 00 87 CA 00 00  '€......‡Ê..‡Ê..
00001100  12 02 14 80 01 00 03 18 00 00 89 CA 00 00 89 CA  ...€......‰Ê..‰Ê
00001110  00 00 12 02 1C 80 02 00 03 18 00 00 8A CA 00 00  .....€......ŠÊ..
00001120  8A CA 00 00 12 02 23 80 03 00 03 18 00 00 8C CA  ŠÊ....#€......ŒÊ
00001130  00 00 8C CA 00 00 12 02 1F 80 02 00 03 18 00 00  ..ŒÊ.....€......
00001140  8F CA 00 00 8F CA 00 00 12 02 3A 80 02 00 03 18  .Ê...Ê....:€....
00001150  00 00 91 CA 00 00 91 CA 00 00 12 02 3E 80 02 00  ..‘Ê..‘Ê....>€..
00001160  03 18 00 00 93 CA 00 00 93 CA 00 00 12 02 12 80  ....“Ê..“Ê.....€
00001170  05 00 03 18 00 00 95 CA 00 00 95 CA 00 00 12 02  ......•Ê..•Ê....
00001180  26 80 0D 00 03 18 00 00 9A CA 00 00 9A CA 00 00  &€......šÊ..šÊ..
00001190  12 02 2B 80 05 00 03 18 00 00 A7 CA 00 00 A7 CA  ..+€......§Ê..§Ê
000011A0  00 00 12 02 29 80 02 00 03 18 00 00 AC CA 00 00  ....)€......¬Ê..
000011B0  AC CA 00 00 12 02 2A 80 02 00 03 18 00 00 AE CA  ¬Ê....*€......®Ê
000011C0  00 00 AE CA 00 00 12 02 37 80 02 00 03 18 00 00  ..®Ê....7€......
000011D0  B0 CA 00 00 B0 CA 00 00 12 02 3B 80 02 00 03 18  °Ê..°Ê....;€....
000011E0  00 00 B2 CA 00 00 B2 CA 00 00 12 02 0F 80 05 00  ..²Ê..²Ê.....€..
000011F0  03 18 00 00 B4 CA 00 00 B4 CA 00 00 12 02 0A 80  ....´Ê..´Ê.....€
00001200  02 00 03 18 00 00 B9 CA 00 00 B9 CA 00 00 12 02  ......¹Ê..¹Ê....
00001210  25 80 02 00 03 18 00 00 BB CA 00 00 BB CA 00 00  %€......»Ê..»Ê..
00001220  12 02 09 80 02 00 03 18 00 00 BD CA 00 00 BD CA  ...€......½Ê..½Ê
00001230  00 00 12 02 0C 80 02 00 03 18 00 00 BF CA 00 00  .....€......¿Ê..
00001240  BF CA 00 00 12 02 06 80 02 00 03 18 00 00 C1 CA  ¿Ê.....€......ÁÊ
00001250  00 00 C1 CA 00 00 12 02 18 80 02 00 03 18 00 00  ..ÁÊ.....€......
00001260  C3 CA 00 00 C3 CA 00 00 12 02 0D 80 05 00 03 18  ÃÊ..ÃÊ.....€....
00001270  00 00 C5 CA 00 00 C5 CA 00 00 12 02 08 80 02 00  ..ÅÊ..ÅÊ.....€..
00001280  03 18 00 00 CA CA 00 00 CA CA 00 00 12 02 24 80  ....ÊÊ..ÊÊ....$€
00001290  02 00 03 18 00 00 CC CA 00 00 CC CA 00 00 12 02  ......ÌÊ..ÌÊ....
000012A0  15 80 02 00 03 18 00 00 CE CA 00 00 CE CA 00 00  .€......ÎÊ..ÎÊ..
000012B0  12 02 07 80 02 00 03 18 00 00 D0 CA 00 00 D0 CA  ...€......ÐÊ..ÐÊ
000012C0  00 00 12 02 65 80 21 00 03 18 00 00 D2 CA 00 00  ....e€!.....ÒÊ..
000012D0  D2 CA 00 00 12 02 1A 80 05 00 03 18 00 00 F3 CA  ÒÊ.....€......óÊ
000012E0  00 00 F3 CA 00 00 12 02 30 80 02 00 03 18 00 00  ..óÊ....0€......
000012F0  F8 CA 00 00 F8 CA 00 00 12 02 1E 80 31 00 03 18  øÊ..øÊ.....€1...
00001300  00 00 FA CA 00 00 FA CA 00 00 12 02 01 80 02 00  ..úÊ..úÊ.....€..
00001310  03 18 00 00 2B CB 00 00 2B CB 00 00 12 02 22 80  ....+Ë..+Ë...."€
00001320  05 00 03 18 00 00 2D CB 00 00 2D CB 00 00 12 02  ......-Ë..-Ë....
00001330  64 80 05 00 03 18 00 00 32 CB 00 00 32 CB 00 00  d€......2Ë..2Ë..
00001340  12 02 49 80 0D 00 03 18 00 00 37 CB 00 00 37 CB  ..I€......7Ë..7Ë
00001350  00 00 12 02 5D 80 05 00 03 18 00 00 44 CB 00 00  ....]€......DË..
00001360  44 CB 00 00 12 02 5E 80 0D 00 03 18 00 00 49 CB  DË....^€......IË
00001370  00 00 49 CB 00 00 12 02 5F 80 10 00 03 18 00 00  ..IË...._€......
00001380  56 CB 00 00 56 CB 00 00 12 02 60 80 02 00 03 18  VË..VË....`€....
00001390  00 00 66 CB 00 00 66 CB 00 00 12 02 61 80 02 00  ..fË..fË....a€..
000013A0  03 18 00 00 68 CB 00 00 68 CB 00 00 12 02 11 80  ....hË..hË.....€
000013B0  05 00 03 18 00 00 6A CB 00 00 6A CB 00 00 12 02  ......jË..jË....
000013C0  3F 80 02 00 03 18 00 00 6F CB 00 00 6F CB 00 00  ?€......oË..oË..
000013D0  12 02 40 80 02 00 03 18 00 00 71 CB 00 00 71 CB  ..@€......qË..qË
000013E0  00 00 12 02 33 80 0D 00 03 18 00 00 73 CB 00 00  ....3€......sË..
000013F0  73 CB 00 00 12 02 43 80 02 00 03 18 00 00 80 CB  sË....C€......€Ë
00001400  00 00 80 CB 00 00 12 02 00 80 02 00 03 18 00 00  ..€Ë.....€......
00001410  82 CB 00 00 82 CB 00 00 12 02 21 80 03 00 03 18  ‚Ë..‚Ë....!€....
00001420  00 00 84 CB 00 00 84 CB 00 00 12 02 FC 8F 01 00  ..„Ë..„Ë....ü...
00001430  03 18 00 00 87 CB 00 00 87 CB 00 00 12 02 FD 8F  ....‡Ë..‡Ë....ý.
00001440  08 00 03 18 00 00 88 CB 00 00 88 CB 00 00 12 02  ......ˆË..ˆË....
00001450  FE 8F 10 00 03 18 00 00 90 CB 00 00 90 CB 00 00  þ........Ë...Ë..
00001460  12 02 47 80 21 00 03 18 00 00 A0 CB 00 00 A0 CB  ..G€!..... Ë.. Ë
00001470  00 00 12 02 48 80 0D 00 03 18 00 00 C1 CB 00 00  ....H€......ÁË..
00001480  C1 CB 00 00 12 02 04 80 03 00 03 18 00 00 CE CB  ÁË.....€......ÎË
00001490  00 00 CE CB 00 00 12 02 03 80 03 00 03 18 00 00  ..ÎË.....€......
000014A0  D1 CB 00 00 D1 CB 00 00 12 02 28 80 03 00 03 18  ÑË..ÑË....(€....
000014B0  00 00 D4 CB 00 00 D4 CB 00 00 12 02 39 80 02 00  ..ÔË..ÔË....9€..
000014C0  03 18 00 00 D7 CB 00 00 D7 CB 00 00 12 02 3D 80  ....×Ë..×Ë....=€
000014D0  02 00 03 18 00 00 D9 CB 00 00 D9 CB 00 00 12 02  ......ÙË..ÙË....
000014E0  36 80 10 00 03 18 00 00 DB CB 00 00 DB CB 00 00  6€......ÛË..ÛË..
000014F0  12 02 1B 80 21 00 03 18 00 00 EB CB 00 00 EB CB  ...€!.....ëË..ëË
00001500  00 00 12 02 13 80 05 00 03 18 00 00 0C CC 00 00  .....€.......Ì..
00001510  0C CC 00 00 12 02 4C 80 05 00 03 18 00 00 11 CC  .Ì....L€.......Ì
00001520  00 00 11 CC 00 00 12 02 4D 80 0D 00 03 18 00 00  ...Ì....M€......
00001530  16 CC 00 00 16 CC 00 00 12 02 4E 80 64 00 03 18  .Ì...Ì....N€d...
00001540  00 00 23 CC 00 00 23 CC 00 00 12 02 4F 80 03 00  ..#Ì..#Ì....O€..
00001550  03 18 00 00 87 CC 00 00 87 CC 00 00 12 02 4A 80  ....‡Ì..‡Ì....J€
00001560  05 00 03 18 00 00 8A CC 00 00 8A CC 00 00 12 02  ......ŠÌ..ŠÌ....
00001570  4B 80 0D 00 03 18 00 00 8F CC 00 00 8F CC 00 00  K€.......Ì...Ì..
00001580  12 02 50 80 05 00 03 18 00 00 9C CC 00 00 9C CC  ..P€......œÌ..œÌ
00001590  00 00 12 02 51 80 0D 00 03 18 00 00 A1 CC 00 00  ....Q€......¡Ì..
000015A0  A1 CC 00 00 12 02 52 80 10 00 03 18 00 00 AE CC  ¡Ì....R€......®Ì
000015B0  00 00 AE CC 00 00 12 02 53 80 05 00 03 18 00 00  ..®Ì....S€......
000015C0  BE CC 00 00 BE CC 00 00 12 02 54 80 0D 00 03 18  ¾Ì..¾Ì....T€....
000015D0  00 00 C3 CC 00 00 C3 CC 00 00 12 02 55 80 05 00  ..ÃÌ..ÃÌ....U€..
000015E0  03 18 00 00 D0 CC 00 00 D0 CC 00 00 12 02 56 80  ....ÐÌ..ÐÌ....V€
000015F0  0D 00 03 18 00 00 D5 CC 00 00 D5 CC 00 00 12 02  ......ÕÌ..ÕÌ....
00001600  57 80 05 00 03 18 00 00 E2 CC 00 00 E2 CC 00 00  W€......âÌ..âÌ..
00001610  12 02 58 80 0D 00 03 18 00 00 E7 CC 00 00 E7 CC  ..X€......çÌ..çÌ
00001620  00 00 12 02 59 80 05 00 03 18 00 00 F4 CC 00 00  ....Y€......ôÌ..
00001630  F4 CC 00 00 12 02 5A 80 0D 00 03 18 00 00 F9 CC  ôÌ....Z€......ùÌ
00001640  00 00 F9 CC 00 00 12 02 5B 80 10 00 03 18 00 00  ..ùÌ....[€......
00001650  06 CD 00 00 06 CD 00 00 12 02 5C 80 02 00 03 18  .Í...Í....\€....
00001660  00 00 16 CD 00 00 16 CD 00 00 12 02 66 80 02 00  ...Í...Í....f€..
00001670  03 18 00 00 18 CD 00 00 18 CD 00 00 12 02 67 80  .....Í...Í....g€
00001680  05 00 03 18 00 00 1A CD 00 00 1A CD 00 00 12 02  .......Í...Í....
00001690  68 80 0D 00 03 18 00 00 1F CD 00 00 1F CD 00 00  h€.......Í...Í..
000016A0  12 02 69 80 0F 00 03 18 00 00 2C CD 00 00 2C CD  ..i€......,Í..,Í
000016B0  00 00 12 02 6A 80 03 00 03 18 00 00 3B CD 00 00  ....j€......;Í..
000016C0  3B CD 00 00 12 02 6B 80 03 00 03 18 00 00 3E CD  ;Í....k€......>Í
000016D0  00 00 3E CD 00 00 12 02 6C 80 04 00 03 18 00 00  ..>Í....l€......
000016E0  41 CD 00 00 41 CD 00 00 12 02 00 10 0E 00 03 18  AÍ..AÍ..........
000016F0  00 00 FD F6 00 00 FD F6 00 00 12 02 B1 00 11 00  ..ýö..ýö....±...
00001700  03 18 00 00 0B F7 00 00 0B F7 00 00 12 02 B2 00  .....÷...÷....².
00001710  17 00 03 18 00 00 1C F7 00 00 1C F7 00 00 12 02  .......÷...÷....
00001720  01 10 0F 00 03 18 00 00 33 F7 00 00 33 F7 00 00  ........3÷..3÷..
00001730  12 02 02 10 10 00 03 18 00 00 42 F7 00 00 42 F7  ..........B÷..B÷
00001740  00 00 12 02 03 10 14 00 03 18 00 00 52 F7 00 00  ............R÷..
00001750  52 F7 00 00 12 02 05 10 0E 00 03 18 00 00 66 F7  R÷............f÷
00001760  00 00 66 F7 00 00 12 02 04 10 11 00 03 18 00 00  ..f÷............
00001770  74 F7 00 00 74 F7 00 00 12 02 07 10 0E 00 03 18  t÷..t÷..........
00001780  00 00 85 F7 00 00 85 F7 00 00 12 02 08 10 18 00  ..…÷..…÷........
00001790  03 18 00 00 93 F7 00 00 93 F7 00 00 12 02 01 11  ....“÷..“÷......
000017A0  10 00 03 18 00 00 FF FB 00 00 FF FB 00 00 12 02  ......ÿû..ÿû....
000017B0  00 11 10 00 03 18 00 00 CB 47 00 00 CB 47 00 00  ........ËG..ËG..
000017C0  12 02 E0 00 8B 02 03 18 04 00 DB 47 00 00 DB 47  ..à.‹.....ÛG..ÛG
000017D0  00 00 12 02 E1 00 8B 02 03 18 04 00 66 4A 00 00  ....á.‹.....fJ..
000017E0  66 4A 00 00 12 02 E2 00 8B 02 03 18 04 00 F1 4C  fJ....â.‹.....ñL
000017F0  00 00 F1 4C 00 00 12 02 E3 00 8B 02 03 18 04 00  ..ñL....ã.‹.....
00001800  7C 4F 00 00 7C 4F 00 00 12 02 66 00 69 00 03 18  |O..|O....f.i...
00001810  80 00 AB F7 00 00 AB F7 00 00 12 02 DD AD 22 00  €.«÷..«÷....Ý.".
00001820  03 18 80 00 0F FC 00 00 0F FC 00 00 12 02 FE 00  ..€..ü...ü....þ.
00001830  00 01 03 18 04 00 07 52 00 00 07 52 00 00 12 02  .......R...R....
00001840  FB 00 40 00 03 18 04 00 14 F8 00 00 14 F8 00 00  û.@......ø...ø..
00001850  12 02 0F 12 11 00 03 18 00 00 31 FC 00 00 31 FC  ..........1ü..1ü
00001860  00 00 12 02 13 12 10 00 03 18 00 00 07 53 00 00  .............S..
00001870  07 53 00 00 12 02 12 14 11 00 03 18 00 00 54 F8  .S............Tø
00001880  00 00 54 F8 00 00 12 02 00 14 11 00 03 18 00 00  ..Tø............
00001890  42 FC 00 00 42 FC 00 00 12 02 07 12 11 00 03 18  Bü..Bü..........
000018A0  00 00 17 53 00 00 17 53 00 00 12 02 08 12 11 00  ...S...S........
000018B0  03 18 00 00 65 F8 00 00 65 F8 00 00 00 02 06 12  ....eø..eø......
000018C0  11 00 03 18 00 00 28 53 00 00 28 53 00 00 00 00  ......(S..(S....
000018D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000018E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000018F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001900  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001910  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001920  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001930  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001940  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001950  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001960  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001970  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001980  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001990  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000019A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000019B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000019C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000019D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000019E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000019F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001A00  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001A10  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001A20  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001A30  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001A40  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001A50  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001A60  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001A70  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001A80  00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00  ................
00001A90  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001AA0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001AB0  00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00  ................
00001AC0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001AD0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001AE0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001AF0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001B00  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001B10  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001B20  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001B30  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001B40  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001B50  01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001B60  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001B70  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001B80  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001B90  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001BA0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001BB0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001BC0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001BD0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001BE0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001BF0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00001C00  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001C10  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001C20  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF BF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ¿
00001C30  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001C40  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001C50  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001C60  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001C70  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001C80  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001C90  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001CA0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001CB0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001CC0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001CD0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001CE0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001CF0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001D00  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001D10  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001D20  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001D30  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001D40  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001D50  FF FF FF FF FF FF FF FF FF FF 7F FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿ.ÿÿÿÿÿ
00001D60  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001D70  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001D80  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001D90  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001DA0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001DB0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001DC0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001DD0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001DE0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001DF0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001E00  FF FF FF FF FF FF FE FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿþÿÿÿÿÿÿÿÿÿ
00001E10  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001E20  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001E30  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001E40  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001E50  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001E60  FF FF FF FF FF FF 7F FF FF FF FF FF FF FF FF EF  ÿÿÿÿÿÿ.ÿÿÿÿÿÿÿÿï
00001E70  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001E80  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001E90  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001EA0  FF FF FF FF DF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿßÿÿÿÿÿÿÿÿÿÿÿ
00001EB0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001EC0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001ED0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001EE0  DF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ßÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001EF0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001F00  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001F10  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001F20  FF FF FF FF FF FF FF FF BF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿ¿ÿÿÿÿÿÿÿ
00001F30  FF FF FF FF FF FF FF FF FF FF FF FB FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿûÿÿÿÿ
00001F40  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001F50  FF FF FF FF FF FF FF FF FF FF 7F FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿ.ÿÿÿÿÿ
00001F60  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001F70  FF FD FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿýÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001F80  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001F90  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001FA0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001FB0  FF FF FF FF FF FF FF FF FF FF FF FF FD FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿýÿÿÿ
00001FC0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001FD0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001FE0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00001FF0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002000  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002040  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002070  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002080  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002090  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000020A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000020B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000020C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000020D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000020E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000020F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002100  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002110  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002120  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002130  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002140  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002150  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002160  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002170  00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002180  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002190  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000021A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000021B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000021C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000021D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000021E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000021F0  00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00  ................
00002200  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002210  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002220  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002230  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002240  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002250  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002260  00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002270  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002280  00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00  ................
00002290  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000022A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000022B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000022C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000022D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000022E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000022F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002300  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002310  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002320  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002330  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002340  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002350  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002360  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002370  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002380  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002390  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000023A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000023B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000023C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000023D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000023E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000023F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002400  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002410  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002420  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002430  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002440  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002450  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002460  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002470  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002480  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002490  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000024A0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000024B0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000024C0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000024D0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000024E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000024F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002500  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002510  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002520  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002530  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002540  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002550  FF FF FF FF FF FF FF FF FF FF 7F FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿ.ÿÿÿÿÿ
00002560  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002570  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002580  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002590  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000025A0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000025B0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000025C0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000025D0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000025E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000025F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002600  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002610  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002620  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF BF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ¿
00002630  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002640  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002650  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002660  FF FF FF FF FF FF FF FF FF FF FF DF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿßÿÿÿÿ
00002670  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002680  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002690  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000026A0  FF FF FF FF DF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿßÿÿÿÿÿÿÿÿÿÿÿ
000026B0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000026C0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000026D0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000026E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000026F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002700  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002710  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002720  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002730  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002740  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002750  FF FF FF FF FF FF FF FF FF FF 7F FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿ.ÿÿÿÿÿ
00002760  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002770  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002780  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002790  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000027A0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000027B0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000027C0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000027D0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000027E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
000027F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002800  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002810  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002820  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002830  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002840  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002850  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002860  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002870  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002880  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002890  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000028A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000028B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000028C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000028D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000028E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000028F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002900  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002910  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002920  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002930  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002940  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002950  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002960  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002970  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002980  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002990  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000029A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000029B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000029C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000029D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000029E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000029F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002A00  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002A10  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002A20  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002A30  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002A40  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002A50  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002A60  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002A70  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002A80  00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00  ................
00002A90  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002AA0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002AB0  00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00  ................
00002AC0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002AD0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002AE0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002AF0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002B00  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002B10  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002B20  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002B30  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002B40  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002B50  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002B60  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002B70  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002B80  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002B90  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002BA0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002BB0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002BC0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002BD0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002BE0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002BF0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00002C00  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002C10  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002C20  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002C30  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002C40  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002C50  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002C60  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002C70  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002C80  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002C90  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002CA0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002CB0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002CC0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002CD0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002CE0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002CF0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002D00  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002D10  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002D20  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002D30  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002D40  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002D50  FF FF FF FF FF FF FF FF FF FF 7F FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿ.ÿÿÿÿÿ
00002D60  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002D70  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002D80  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002D90  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002DA0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002DB0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002DC0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002DD0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF EF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿïÿ
00002DE0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002DF0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002E00  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002E10  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002E20  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002E30  FF FF FF FF FF FF 7F FF FF FF FF EF FF FF FF FF  ÿÿÿÿÿÿ.ÿÿÿÿïÿÿÿÿ
00002E40  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002E50  DF FF FF FF FF FF FF FF FF FF FF FF F7 FF FF FF  ßÿÿÿÿÿÿÿÿÿÿÿ÷ÿÿÿ
00002E60  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002E70  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002E80  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002E90  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF DF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿß
00002EA0  FF FF FF FF DF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿßÿÿÿÿÿÿÿÿÿÿÿ
00002EB0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002EC0  DF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ßÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002ED0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002EE0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002EF0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002F00  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002F10  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002F20  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002F30  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002F40  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002F50  FF FF FF FF FF FF FF FF FF FF 7F FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿ.ÿÿÿÿÿ
00002F60  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002F70  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002F80  FF FF FF FF FB FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿûÿÿÿÿÿÿÿÿÿÿÿ
00002F90  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002FA0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002FB0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002FC0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002FD0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002FE0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
00002FF0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
PostPosted: October 28th, 2015, 1:18
can you upload the original ROM + the present ?
PostPosted: October 28th, 2015, 1:34
I'm not sure what you mean. I don't have the ROM from before HDDHackr. Present ROM is attached to the first post, 08FA.zip. The only difference from before my edit with WDR is 0D.
Before (from HDDHackr WD3200BEVT-22ZCT0 (01-31-2009).BIN):
00000000  52 4F 59 4C 04 00 1E 00 0D 00 01 00 EA 2E 71 D9  ROYL........ê.qÙ
00000010  30 30 30 31 30 30 30 30 00 00 00 00 00 00 00 01  00010000........
00000020  31 31 2E 30 31 41 31 31 00 01 03 01 00 00 50 01  11.01A11......P.
00000030  4E E0 01 13 A4 CC 00 01 FE FF 00 00 00 00 00 00  Nà..¤Ì..þÿ......
00000040  01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000070  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000080  00 00                                            ..
After:
0002F2D0        52 4F 59 4C 04 00 1E 00 0D 00 01 00 82 A9    ROYL........‚©
0002F2E0  8D 6B 30 30 30 31 30 30 30 30 00 00 00 00 00 00  .k00010000......
0002F2F0  00 01 31 31 2E 30 31 41 31 31 00 01 03 01 00 00  ..11.01A11......
0002F300  50 01 4E E0 01 9F 2C 70 00 01 FE FF 00 00 00 00  P.Nà.Ÿ,p..þÿ....
0002F310  02 00 01 01 00 00 00 00 20 20 20 20 20 20 20 20  ........
0002F320  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
0002F330  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
0002F340  20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20
0002F350  20 20 20 20
PostPosted: October 28th, 2015, 2:01
do you have access to SA now ?
PostPosted: October 28th, 2015, 11:36
Sorry for my lengthy post and if I was unclear. I know HDDHackr replaces 0D and 02, so my first idea was of course to restore those. But as I said in my first post, I can only ready mod 01, on all others I get a red cross.
My question was really, how do I gain access to the platters, service area? I hoped replacing 0D would help. I have the original mod 02 from my UNDO.BIN, so I don't need a donor for that.
Platters spin up when I choose Modules Operations. And I get what I think is a full list (road map?). I also tried loading road map from file, from your library (22ZCT0_08.FPD), without being able to read any modules. "Via Enumeration" shows less modules, but not 02, and my computer often freeze during that stage. I only managed to try to read two modules, unsuccessfully, before it froze.
I just ruined my Windows installation from all the hard reboots. So I need to fix that before I can go any further.
If I need a donor for something, I found FW 08.FA here:
http://www.hpwlab.com/hdd/thread-1145-1-1.html
but I can't read arabic, and google translate doesn't make much sense. Have tried to register at least.
PostPosted: October 28th, 2015, 14:07
Can you read the tracks? The original 02 module can sometimes be restored from module 802F or 802E.
PostPosted: October 28th, 2015, 15:50
I don't think I can read tracks, but I'll try again when I get my WinXP up and running. But as said above. I have my original UNDO.BIN, which AFAIK contains the full mod 02.
Sorry about the late responses, but all my posts get moderated.
 Post subject: Re: Fix HDDHackr incorrect restore with WDR
PostPosted: October 29th, 2015, 4:18
Doh! Yes, I did see that, but I confused myself. Sorry.
AISI, WDR can read module 01 (the module directory), but it cannot read the other modules. Module 01 is probably being accessed in CHS mode (ie by specifying its Cylinder/Head/Sector location). The other modules would normally be accessed with a Vendor Specific Command (VSC) that uses the module's ID rather than its CHS address. However, access "by ID" appears to be nonfunctional in the drive's present state.
You will need to use WDR or some other tool to write your original module 02 to the physical location specified in module 01.
Could you upload module 01 as a BIN/ZIP?
PostPosted: October 29th, 2015, 11:06
So mod 01 is also on the platters? That sounds promising. I think I remember reading about VSC getting disabled because of some mismatch when restoring the wrong UNDO. So how would I go about writing 02 back without VSC (with CHS)?
Thanks for your time and help. Mod 01 is attached.
0001.zip [3.05 KiB]
Downloaded 684 times
PostPosted: October 29th, 2015, 17:24
I have attached the SA module directory list sorted by module ID and logical block address.
Module 02 has a size of 3 sectors and is located at logical block # 0xFCA1.
SA_modules.zip [8.29 KiB]
Downloaded 603 times
PostPosted: October 30th, 2015, 16:46
Ok, so I made some progress. I'm able to read tracks! But I had a hard time converting LBA 0xFCA1 to cylinder info in WDR "Tracks Operations". I think LBA to CHS conversions got me confused, because that was irrelevant in this case.
(At first I thought that I could specify a SPT size, and it would then create a virtual cylinder map from that. But I found out that Cyl # is always the same regardless of SPT size. SPT just specifies how many sectors of the cylinder/track it will read. A full track here is 693/0x2B5 sectors. So I thought 64673/0xFCA1 would be around track 93. Because reading full tracks was quite slow I checked the tracks in the similar HDD from your library instead, and found mod 02 in track 35/0x23. The backup mod 802E at 51820/0xCA6C I thought would be around track 74, but it was in track 54/0x36. So still 19 in between, don't know where it counts from, but have seen people mentioning negative tracks.)
Successfully read both track 35 and 54. The backup mod 802E in track 54 was almost the same as in my HDDHackr UNDO.BIN (I saw that the one in your library also differed a little). And mod 02 in track 35 was the one I (shouldn't have) flashed. Now to the new issue, I can't write back. Don't get any errors, but when I read the track again it hasn't changed. I don't think my WDR6 is crippled, I could write ROM at least.
From Spildit's thread at HDD Oracle about the How Swap method I found the following that might apply to me.
"what if the drive cannot write to the System Area to fix corrupted modules?/.../
This could be due to the following reasons:/.../
- Modules containing unique write parameters for the heads (adaptives) are corrupted, so the drive cannot write.
-The hard drive doesn't give access to System Area if some critical modules are corrupted."
Could I read out the needed mods via Tracks and apply them somehow, to be able to write?
PostPosted: November 1st, 2015, 2:17
Some (not useful) progress. I dumped track 34 which contains mod 11 (overlay), and extracted it. But loading that didn't make any difference as far as I can tell.
What made difference was going into Modules Operations, ticking w/o Road Map and pressing Init on mod 01. After that I could dump all modules and read P-list for example. But SMART list is still empty, and the log says BAD. I got CRC OK on all mods except 0x6F (and 0x20, which only showed up in Via Enumeration).
But still no write access. Write Test reports BAD on all 4 heads, annoying, so near and yet so far. :(
Also tried restoring the "matching" incorrect 0D, together with init 01 and load overlay, but no difference. Can I use the init-button on more than mod 01, to maybe initialize needed mods for writing?
ps. The track numbering calculations above of course makes sense if you count backwards from 128.
PostPosted: November 1st, 2015, 3:46
Module 0x6F often has a bad checksum even in good drives.
Module 0x20 doesn't exist in the directory, so that's why it shows up only "Via Enumeration".
If you wish to examine your SMART data, then I have written a utility to extract them from modules 20, 21, 22, 23, 24, etc.
Hidden SMART attributes in WD HDDs:
http://www.hddoracle.com/viewtopic.php?f=59&t=127
BTW "road map" is a quaint Russian mis-translation of "directory", perhaps because of confusion with "street directory".
WD_smart2.7z [85.87 KiB]
Downloaded 619 times
PostPosted: November 1st, 2015, 10:00
Thanks, but I know SMART is good, because I checked it before using HDDHackr. I just try to mention everything I see, if it happens to make sense for someone who knows more about this than me. Thought it was a little strange that SMART didn't show when I could read mods.
Right know I'm stuck. Have no idea how to take this any further, and get write access. Except a Hot Swap, which isn't possible.
PostPosted: November 1st, 2015, 10:33
All modules attached, even enumerated.
Modules.rar [3.18 MiB]
Downloaded 815 times
PostPosted: November 1st, 2015, 14:44
Because I had nothing to do I compared ROM with the backups in SA. All of them had minor differences, except 104 which looked like a stripped down version. The directory info in WDR about backup locations wasn't completely correct, they were located in the following modules:
0A=102
47=103
0D=104 (stripped)
30=105
4F=106
0B=107
PostPosted: November 1st, 2015, 17:34
It doesn't help you at all, but just FYI here are the SMART data in modules 21 and 22:
ID  Flg   Cur  Wor  Thr  Raw             Description
  1   2F   200  200   51  00000000000001  Raw Read Error Rate
  3   27   187  185   21  00000000000661  Spin Up Time
  4   32    97   97    0  00000000000DC4  Start/Stop Count
  5   33   200  200  140  00000000000000  Re-allocated Sector Count
  7   2E   100  253    0  00000000000000  Seek Error Rate
  9   32    96   96    0  00000000000DFE  Power-On Hours Count
10   33   100  100   51  00000000000000  Spin Retry Count
11   32   100  100    0  00000000000000  Drive Calibration Retry Count
12   32    98   98    0  000000000008DC  Drive Power Cycle Count
184  *B2   100  100    0  00000000000000  End to End Error Det/Corr Count
187  *B2   100  100    0  00000000000000  Reported Uncorrectable Errors
188  *B2    97   97    0  00000000000003  Command Time Out
190  *A2    75   34    0  00000000000019  Airflow Temperature
192   32   200  200    0  00000000000071  Emergency Retract Cycle Count
193   32   195  195    0  0000000000417C  Load/Unload Cycle Count
194   22   122   81    0  00000000000019  HDA Temperature
195  *B6     1    1    0  000000011A0BFE  ECC on the Fly Count
196   32   200  200    0  00000000000000  Re-allocated Sector Event
197   32   200  200    0  00000000000000  Current Pending Sector Count
198   30   100  253    0  00000000000000  Offline Uncorrectable Sector Count
199   32   200  200    0  00000000000000  UltraDMA CRC Error Rate
200   09   100  253   51  00000000000000  Multi Zone Error Rate
240  *B2    96   96    0  00000000000DE2  Head Flying Hours
241  *B2     1    1    0  00C05DF3B8F896  Total LBAs written
242  *B2   200  200    0  0000021F71BC39  Total LBAs read
     * = hidden attribute
The Total LBAs Written data are clearly bogus, so this appears to be yet another SMART bug.
PostPosted: February 15th, 2016, 16:25
Would a hot swap enable write access?
How close must the date code be to be hot swappable? I understand there's probably no general rule, more a question about probability.
I will maybe be able to get a drive with 09-06-2009, the one above is 09-24-2009.
Users browsing this forum: Google [Bot] and 47 guests
