 Post subject: wd20nmvw - usb3 - encrypted - lost password
PostPosted: October 28th, 2015, 22:15
onboard encryption via JMS538S
customer used smartware password to lock drive.
There is a hint - so its not corruption
Is there a solution for this ?
I know how to decrypt these with the bridge boards - it wants a password.
thanks
Expert in data recovery, RAID, VMware, Linux, Tape, Forensics, Cleanroom...
http://www.alandatarecovery.com
 Post subject: Re: wd20nmvw - usb3 - encrypted - lost password
PostPosted: October 29th, 2015, 0:07
if there was a way to decrypt it, then it would kinda defeat the purpose of hardware encryption, don't you think?
PostPosted: October 29th, 2015, 4:17
thanks
Well,
So There Are Two Passwords .One is Easily Solved By a Pro Tool Or Non Pro Methods .The Other One Can Be Cracked Once The HDD Has Content In Memory .Our Friend Einstein Can Do That IMHO
PostPosted: October 29th, 2015, 5:17
Not really.
If there is a password set and it is lost, only way to recover by conventional methods is meditation.
PostPosted: October 29th, 2015, 6:24
thanks
can you state the full model ? i have seen couple of WD new drives which are not encrypted by USB bridge so may be your only problem is smartware.
Data Recovery Pakistan
PostPosted: October 30th, 2015, 15:05
Did you see article about encryption on those hdd? It's look like it's possible to hack hdd and get data even if password are lost. I would love to get real case to try technic from this article.
