 Post subject: remove password hitachi
PostPosted: November 1st, 2015, 18:33
Hello.
Today I got a hard disk Hitachi model HTS545050B9A300 , 500 gb , 2.5,
Windows only recognizes him from the Disk Manager , but can not create partitions, I can not do anything.
try unsuccessfully with DFT format but is blocked by password
I also tried without success , with the program "zu " but you can not unlock ....
with MHDD not get it
Can you help me?
can not I find this hard drive firmware
 Post subject: Re: remove password hitachi
PostPosted: November 2nd, 2015, 2:27
Spildit wrote:
Hi !
When you check with MHDD does it states that the drive is password protected ?
If so did you lock the drive and do you know the password ?
yes:
the DFT program:
I do not have the password ...
It is a hard drive from an old laptop broken.
Is there a solution ?
thanks
PostPosted: November 2nd, 2015, 2:32
Spildit wrote:
Hi !
yes:
DFT with the program
thanks
PostPosted: November 2nd, 2015, 5:04
duplicate message , sorry
PostPosted: November 2nd, 2015, 17:31
and what you used command line parameters ?
PostPosted: November 2nd, 2015, 19:17
Spildit,
HTS545050B9A300 - Hitachi-IBM
not NativeHitachi
PostPosted: November 3rd, 2015, 9:56
thanks for the help
After nearly all day with this, read and read , I have several questions
in the bios , what should I put option ? native IDE or AHCI ?
ide in native mode , I always get the message : unlock not done
AHCI mode , I always get " elapsed " and nothing more ,You can also spend 3 hours
SATA port that connect the hard drive ?
I have the versión zu_betta_fix_020813
What you could be happening?
forgive my English is a little poor
PostPosted: November 3rd, 2015, 17:20
ok , I have to connect the hard drive in the last sata port in native mode ide
run again after zu, Use the command ZU / P. ----- unlock not done!!!
with the command ZU / P8, I get the message: NOW YOU CAN SCREW IT IN. PRESS ANY WHEN READY ",
I press enter.... UNLOCK NOOOOOT DONE
My motherboard is a Gigabyte GA - 880GMA - UD2H, It has an IDE port where I connected a recorder
After ZU detects the drive and attacks it, the program will report the NativeHitachi message "NOW YOU CAN SCREW IT IN. PRESS ANY KEY WHEN READY".
The HGST message will be "POWER OFF / ON AND EXECUTE ZU AGAIN".
In the first case, you just need to reinstall the controller on the drive, carefully screw it down, and then press any key.
In the second case, turn off the power and reinstall the controller. Then power up the HDD and run ZU again with the same parameters. This procedure applies to IBM / HGST (ExcelStore) models from DTLA to HTS7225xxK9SA00 (5K250) (dozens of models).
do not really understand...
PostPosted: November 4th, 2015, 5:40
-Help for Master password———————————
SEAGATE -> “Seagate” + 25 spaces
MAXTOR
series N40P -> “Maxtor INIT SECURITY TEST STEP ” + 1 or + 2 spaces
series N40P -> “Maxtor INIT SECURITY TEST STEP F”
series 541DX -> “Maxtor” + 24 spaces
series Athena (D541X model 2B) and diamondmax80 -> “Maxtor”
WESTERN DIGITAL -> “WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCWD”
FUJITSU -> 32 spaces
SAMSUNG -> “tttttttttttttttttttttttttttttttt” (32 times t)
IBM
series DTTA -> “CED79IJUFNATIT” + 18 spaces
series DJNA -> “VON89IJUFSUNAJ” + 18 spaces
series DPTA -> “VON89IJUFSUNAJ” + 18 spaces
series DTLA -> “RAM00IJUFOTSELET” + 16 spaces
series DADA-26480 (6,4gb) -> “BEF89IJUF__AIDACA” + 15 spaces
HITACHI series DK23AA, DK23BA and DK23CA -> 32 spaces
TOSHIBA -> 32 spaces
XBOX -> “XBOXSCENE” or “TEAMASSEMBLY”
PostPosted: November 4th, 2015, 8:51
first you need to enable safe mode. then run the zu with the p.
PostPosted: November 5th, 2015, 7:41
I have to follow this tutorial to put it in safe mode
http://www.atola.com/products/insight/m ... emode.html
I have to buy a screwdriver t4 .
PostPosted: November 5th, 2015, 18:32
thank you all for the help, but nothing works ... I always get the message "" "UNLOCK NOT DONE" "" "....
I can put it in safe mode, but does not work .....
¿I can unlock these discs?
Am i doing something wrong ?
What exact steps need to follow?
thanks
PostPosted: November 6th, 2015, 2:54
I need that?
http://www.ebay.es/itm/PC-3000-SATA-to- ... DKZRvw9ECg
PostPosted: November 6th, 2015, 7:32
show a screenshot of MHDD to identify the channel to which you connected the HDD
If the timer is working,it is likely that the channel selected is not correct
PostPosted: November 6th, 2015, 8:10
4DOS EMS swapping initialized (240K)
4DOS running under Windows 98
4DOS 7,50   (Win98) DOS 7,10
Copyright 1988-2004  Rex Conn & JP Software Inc.  All Rights Reserv
c:\_dumps>zu /s
PB3OC60FHitachi HTS545032B9A300
NOT SUPPORTED
transferred hdd in safe mod
c:\_dumps>zu /s.
HDD=HGST/IBM
POWER OFF/ON AND EXECUTE ZU AGAIN
transferred hdd to normal mode
c:\_dumps>zu /s.
HDD=HGST/IBM
POWER OFF/ON
UNLOCK DONE
c:\_dumps>zu /s
NO PWD.BYE!
c:\_dumps>
PostPosted: November 6th, 2015, 17:08
thanks Moltke
yeeees:
It was necessary to use the two commands , first p8 , put in safe mode p . to unlock
ahora tengo otro problema, bo puedo formatear la unidad, DFT program me da el error 0x73 excessive shock
broken hard drive?
you can upgrade the firmware of the hard drive?
PostPosted: November 7th, 2015, 2:51
now I have another problem when I try to format it, or do some teste with DFT software , I get the error 0x73 excessive shock, ¿ broken hard drive?
PostPosted: November 7th, 2015, 8:44
need to see the dumps identify device (ata=0ECh) & smart(ata=0B0h...D0h)
repair laptop HGST-disk requires considerable time .
but the procedure is completely standard. the cycle of writing,formatting(or recalc translator) ,reading.
PostPosted: November 8th, 2015, 9:59
How I can see ?
Spildit wrote:
You can read my guide on Hard Drive testing and Hard drive defect hiding as there are some tests / procedures to hide defects that you can do even if you don't have specific firmware tools.
Be aware that it will take HUGE AMOUNT OF TIME on Biger drives like yours.
Have a nice reading :
http://www.hddoracle.com/viewtopic.php?f=117&t=1397
http://www.hddoracle.com/viewtopic.php?f=117&t=1393
Regards and please post if you can read/write to sectors with Victoria/MHDD + S.M.A.R.T. log.
Spildit wrote:
Can you erase the drive ? Use something like Victoria to dump S.M.A.R.T. and check if you can read /verify the surface.
Maye the drive have just a bad S.M.A.R.T. value for the shock sensor ...
Maybe it have bad sectors as well ....
thanks, now what I have to work with Drevitalize. It seems to find many bad sectors
time consuming, I hope to finish ? as finished, I show a screenshot of victoria
with MHDD I can not format , said device broken ...
again, thank you all for the help
PostPosted: November 8th, 2015, 13:38
Spildit wrote:
I would do a "fast erase" with MHDD or Victoria by using the internal standar secure erase procedure as it's faster then using write.
no,it's still better not to do,as in rdmt may contain incorrect entries describing the defects. in addition, if the Security Erase fails,it is difficult to control the location of the crash. better done through SCT.
Users browsing this forum: No registered users and 100 guests
