 Post subject: ST31000528AS FW-CC38
PostPosted: November 2nd, 2015, 8:27
Is there a way to clear SMART ?
Attempt to clear SMART
F3 1>N1
Init SMART Fail
LED:000000CC FAddr:0024E2D
Rst 0x20M
ASCII Diag mode
Heads test
F3 7>X
Head 00 Resistance 0115
Head 01 Resistance 00FF
Head 02 Resistance 00EF
Head 03 Resistance 00DC
 Post subject: Re: ST31000528AS FW-CC38
PostPosted: November 2nd, 2015, 8:36
have you insulated PCB first?
If not, use a piece of paper to insulate it from HDD, then spin down the motor with Z command, connect again the pcb to hdd and spin up motor with U command, then clear smart
Insulate PCB from hdd
F3 T>/2
F3 2>Z
(connect pcb to hdd)
F3 2>U
F3 2>/1
F3 1>N1
My firmware database:
PostPosted: November 3rd, 2015, 2:35
Well Terminal access is not a problem.
I am able to read system files via TERMINAL but the SMART is not reading 134 / 135
May be bad area i don't know
is there a hint
