 Post subject: WD ROM Corrupt and Microcode Unknown
PostPosted: November 9th, 2017, 2:46
Hello Everyone.
I have a hard drive for recovery purpose. i found that the rom of the hard drive is corrupted. nither we can read it using DFL SRP Nor By the programmer. the microcode of the hard drive is unknown.
i have try to upload the rom of different microcode found from the internet on another same number rom ic.
i did not success in getting the modules and tracks of the hdd.
the hard disk model is WD10EZRX-00L4HB0. Make date 3 Aug 2014.
Please Help. Is there any way to regenerate rom of the hard drive if microcode is unknown.
Thanks in advance
Paras Sharma
 Post subject: Re: WD ROM Corrupt and Microcode Unknown
PostPosted: November 9th, 2017, 7:19
try this one
ROM.zip [246.04 KiB]
Downloaded 549 times
I believe it supposed to work
(if there is no other problems, like heads for example)
PostPosted: November 9th, 2017, 8:24
these drive doesn't store ROM copy on SA and am afraid this wont work, the only possibility is to find a very close drive to do the job.
Data Recovery Pakistan
PostPosted: November 9th, 2017, 9:15
and the one I've provided IS!
PostPosted: November 9th, 2017, 10:04
lets wait OP, whether it works or not !
PostPosted: November 9th, 2017, 12:55
If Its in India I Can Work On It .
PostPosted: November 10th, 2017, 4:17
Hello Mr Amirbir
If you can help then then give us the solution. this forum is to help each other and discuss the hard drive recovery issues.
please do not try to market yourself in the forum. if you have knowledge then share it otherwise do not need to reply.
Best regards
Paras Sharma
PostPosted: November 10th, 2017, 4:21
jermy wrote:
try this one
ROM.zip
Thanks for share Mr Jermy but this Rom belongs to different model of hdd and does not work.
Please share more rom of the Same model i.e WD10EZRX-00L4HB0 DATE 3 AUG 2014
PostPosted: November 10th, 2017, 8:08
starparas wrote:
jermy wrote:
try this one
ROM.zip
with this ROM (which is a very close ROM + the same family) you have access to SA at least ?
PostPosted: November 10th, 2017, 12:37
Hi Jermy And Guys ,
This Guy Is Not a Pleasant Person To communicate To ,This Same Message He Gave Me On DFL Forums And This is The Reply I Gave Him
"Well,
Might Be My Knowledge Is Quite Less Then You ,But Still I Can Solve 99.99% Cases ,In This Case i Asked If Interested In Sending To My Lab i Can Have a Look .Were Have I Said i Will Take Money For This infact You Are Not Aware of This Fact That if i Get a Request In a Form Of PM Also For Money I Reject Such PM's .A Professional Reply Is That i Rely On a Few Tools In My Lab And i Have The Confidence That I Can Solve It There There Should Be No Problem With That In The First Place .On The Other Hand If You Have a Issue With Me Replying To Your Posts I Am OK With That You Can Let Me Know And i Will Not Reply To Them .This Case is a 5 Minutes Job for Me To Solve .
PS : In The Future I Will Write As a Special Note That even if It Comes To My Lab i Will Do It For Free Might Be That Will Explain It Better ."
I am Of the Opinion He Has No Respect For Any Of His Seniors And He Seems To think He Knows It All ,So Whats The Point Of Explaining Him .Paras sharma Solve This Case Yourself Why Are You Taking Help From People In The First Place .In Case I Asked you About any Money Or anything even By a PM Here Or Anywhere Else Be My quest To Explain All Of Us Here ,Typical Indian Mentality " Get Work , Get it Solved For Free ,Take The Money Made And Pocket It " . GO TO HELL
PostPosted: November 30th, 2017, 8:47
Mr Amirbir
Why are you frustrated with my reply. i just ask you if you have knowledge then share it. why are you asking me to send the hdd to you. maybe you can solve it for free but i am new in the field of data recovery so i want to learn thats why i ask it in the forum. but you did not give a good reply. i hope you understand what i mean to say. and one more thing is i never try to disrespect anyone here. neither senior nor beginner.
Paras Sharma
