 Post subject: Media Harddrive UNALLOCATED ...
PostPosted: November 10th, 2015, 3:34
Hello there ,
I have Media Hard Drive here and try to put on PC in Disk Management it is "UNALLOCATED"
I try to recover the Partition using Minitool and I saw the files but I try to put again on the machine (media)
it not recognize ..
I have Backup of this Hard Drive but it is "Unallocated".
I try to Backup also the MBR using "HDHacker by Dimio"
and I try to put it back so that it work on the main machine but IT NOT WORK...
I will attach the said file afterward ...
is there anyway to determine what MBR use of this Disk,
and is there any way to Backup the MBR to work it back after editing the inside Files ..
http://www.gensantraders.com/hdd/855.rar
thanks
 Post subject: Re: Media Harddrive UNALLOCATED ...
PostPosted: November 10th, 2015, 3:54
Spildit wrote:
Get a new empty drive to play with, put that on the media device, format, put some data on it, check it's MBR on a PC with something like DMDE.
If you don't need the data on your disk just format it on the media device...
Hello there sir,
thanks for that ..
No Format Command on Media Device , The disk I played is only a copy .
after I copy I try the clone on the device and it work. but I need to get all the file inside and transfer to
other smaller drive .. I already get the files and put to other drive, but when I test it it not work.
I think there is problem on MBR area..
thanks
PostPosted: November 10th, 2015, 4:02
now I am trying with DMDE and it scan .. as of now got RAW ...
AVI and MP3 Files found...
I will update after scan finish ..
thanks
PostPosted: November 10th, 2015, 4:04
whats the model no. ?
WD ?
encrypted ?
PostPosted: November 10th, 2015, 4:15
As of now I played with Toshiba ,
I have the copy of this disk
Main is Hitachi,
Copied Disk,
Toshiba , Seagate, and WD..
Same files inside ...
Users browsing this forum: Majestic-12 [Bot] and 117 guests
