 Post subject: ST4000DM000, "FAIL Servo" after headswap, donor still OK
PostPosted: November 8th, 2015, 8:37
Hello All,
Patient HDD sustained physical shock whilst powered on. Heads failed immediately. Attached image of failed heads - given the shape of them I'd say there's every chance they have damaged the platters.
The first set of donor parts used the drive would spin up, keep spinning and not make an attempt to calibrate. When donor parts were replaced back to donor they work normally. Given these results I'd be almost certain this was due to donor part incompatibility given the non-match on the SN and site. Quite simply, these parts were used as they were in stock on the off chance that they might be close enough.
The second set of parts were ordered in for the job. On swap the HDD would attempt to calibrate, but get he familiar "FAIL Servo Op=0100 Resp=0007" errors in terminal. The terminal output replicated the output with the patient heads. HDD spins down after failed attempts to calibrate. However, on testing the donor parts back in the host they work normally.
Any thoughts/suggestions?
Patient:
ST4000DM000
PN: 1F2168-568
SN : Z30...
CC54
SITE: TK
Donor in stock:
ST4000DM000
PN: 1F2168-568
SN: S30...
CC54
SITE: SU
Donor ordered for job:
Model : ST4000DM000
PN: 1F2168-500
SN : Z30...
CC52
SITE: TK
Best regards,
J
CDR - Manchester Data Recovery Services
0161 408 4857
http://www.cheadledatarecovery.co.uk/
 Post subject: Re: ST4000DM000, "FAIL Servo" after headswap, donor still O
PostPosted: November 8th, 2015, 9:47
The FW and PN not exactly the same...
As far as I know, these DM are quite picky for head swap.
ACELab partner
PostPosted: November 8th, 2015, 10:41
Hi Pclab, thanks for that.
The donor ordered in was at a decent price so it was worth the purchase. Trying to find a match on all parameters on this HDD from a supplier within Europe is currently difficult. I've seen a few with a match on FW but a 1F2168-300 revision. A full match has been found in the USA, but as expected it is expensive.
PostPosted: November 9th, 2015, 11:33
tried altering head adaptives?
PostPosted: November 9th, 2015, 17:03
Just to share my experience with DM drives.
Always buy more than one donor.
Match the first 3 numbers or serial as well as everything else.
Be patient when you power the drive after a head swap sometimes it takes 5-10 mins for the drive to come ready.
Start the drive with head 0 disabled and re enable after the drive comes ready.
Move head adaptives from donor (although if the donor heads are giving servo errors moving head adaptives won't help).
Do selective file imaging, trust me the donor heads won't last a entire drive image.
Cross fingers :)
Web: https://www.day1data.de
PostPosted: November 12th, 2015, 4:15
I usually match exactly nothing (apart from electrical connectivity), use what i have at hand and make it 'compatible'.
Edit: sometimes family has to be the same...
PostPosted: November 12th, 2015, 13:58
Well Pepe Sir ,
Who can match your experience and knowledge [ none according to me ] . Can you give a hint what to de might be i can try at some spare time
PS : trust me guys this man is capable to do anything
PostPosted: November 12th, 2015, 14:00
cheadledatarecovery wrote:
Hello All,
Patient:
ST4000DM000
PN: 1F2168-568
SN : Z30...
CC54
SITE: TK
Donor in stock:
ST4000DM000
PN: 1F2168-568
SN: S30...
CC54
SITE: SU
Model : ST4000DM000
PN: 1F2168-500
SN : Z30...
CC52
SITE: TK
Best regards,
J
Hi ,
Try Disable Head 4 And 7 In Your Case .Drive Should Be Able To Clone Rest Heads Easily IMHO
PostPosted: November 12th, 2015, 18:05
I guess u meant H3 and H7.
thanks, but i am not God, really. :)
i feel that every day
PostPosted: November 13th, 2015, 7:38
Yes Correct Mr Pepe Sir ,
Physical Head 3 And 7 .Logical Head 4 And 8
PostPosted: November 13th, 2015, 9:24
it is logical 3 and 7 too, but it does not matter
Users browsing this forum: ad1479 and 73 guests
