Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: ddrescue: 1st sector dead, need help
PostPosted: November 18th, 2015, 7:37
I am having troubles recovering files from a 1TB WD HDD, win NTFS, gone RAW. The first run of ddrescue took almost a week and showed amongst others, also :oops: the first sector to be bad, and now I feel like running out of luck and of solutions.
the first run with ddrescue:
ddrescue --force /dev/sdc /dev/sdd /mnt/logstick/ddrescue.log
ddrescue logfile and png of its viewer:
https://instaload.de/dl/564c5114c6a1e4.14388583
https://instaload.de/dl/564c50ddaf2642.63334684
? Should I run ddrescue again with r3 / three retries on bad sectors, hoping to get back the critical first sector?
? What are my chances according to the logfile?
? Which data recovery tool is most advisable to recover maximum files? photorec, dmde, recover my files, getdataback..?
I appreciate any help as I have been spending days researching and trying, without success...
THANKS!
 Post subject: Re: ddrescue: 1st sector dead, need help
PostPosted: November 18th, 2015, 8:26
the links you provided say "The selected file does not exist."
1. first sector can be reconstructed
2. you can try to run the /dev/sdd (the destination drive) against recovery software like r-studio Etc.
PostPosted: November 18th, 2015, 8:58
sorry for the broken links...
ddrescuelog.txt
- I am currently working with dmde - is r-studio, or an other one, better?
- should I retry the first sector with ddrescue?
thank you for your reply.
PostPosted: November 18th, 2015, 9:00
here are the two files as attachments...
And you give any details on how to reconstruct the first bad sector..?
File comment: ddrescue viewer
File comment: ddrescue logfile
ddrescuelog.txt [45.92 KiB]
Downloaded 967 times
PostPosted: November 18th, 2015, 9:19
1. have you tried in reverse ?
2. maybe all your important files is already backed up
PostPosted: November 18th, 2015, 9:49
no, so far I just did a first run. and the destination hdd is not accessible, I just tried mini tool partition wizard, maybe it could restore the mbr, but without any success. it also showed the size of the 4TB HDD as 0.
PostPosted: November 18th, 2015, 10:18
4TB is the destination drive ?
with no hardware cloning in your disposal and assuming you won't send it over to a pro i would have tried sector sector in reverse
PostPosted: November 18th, 2015, 10:37
I have attached the output of smartctl -a; maybe it helps in guiding to the next move.
Could you specify which parameters you mean by sector sector in reverse?
smartctl -a.docx [13.82 KiB]
Downloaded 649 times
PostPosted: November 18th, 2015, 10:48
Now just scan the clone with a program like R-Studio and recover your files to another drive.
PostPosted: November 18th, 2015, 11:50
is there a way to replace the bad 1st sector and hence regain accessibility to the whole drive?
is it possible that a second run with ddrescue and 3 retries/bad cell wil improve the structure of the cloned drive?
I wanted to continue with DMDE - is r-rescue better?
thanks again!!!
PostPosted: November 18th, 2015, 12:44
-b 512 -R
PostPosted: November 18th, 2015, 13:16
Are you sure that the destination drive hasn't failed? What does smartctl say about it?
If the 4TB drive is OK, can you show us the partition structure with a disc editor, eg DMDE (freeware):
http://dmde.com/download.html
PostPosted: November 18th, 2015, 16:14
I have started DMDE on the cloned drive around 5 hours ago, and it is currently at 0,5% with around 2000 jpegs found.
It seems that yes, the new image was successfully made.
And that the just the search will take more than one month.
Uff.
With a second run with ddrescue and another search process with dmde, maybe another go with another rescue programme, I might be occupied with this well into next summer... ???
any tips to speed it up, any shortcuts could save me effectively lifetime!
PostPosted: November 18th, 2015, 17:36
The search is proceeding at around 1 MB/s. Is the clone connected to a SATA port or is it connected via USB?
BTW, you can stop DMDE's search at any time and resume later. The search results can be logged to a file. After you stop the search, you can examine any of the NTFS fragments.
PostPosted: November 18th, 2015, 18:06
Spildit wrote:
I think that *maybe* your WD drives (both) need the slow fix lol
patient's drive with slow responding ?
i think it would have taken a lot longer than a week to clone
PostPosted: November 18th, 2015, 19:23
oops sorry
i thought by mentioning "(both)" you meant the "patient" AND the cloned
PostPosted: November 18th, 2015, 19:32
well, there's even more to consider..
the destination HDD, not the patient ;) is a new intenso drive, but my system at hand is quite slow - a thinkpad x200 with USB2 - seems still slow enough..
is it possible to pause the DMDE process and try to get back the data it found so far...?
what other possibilities do I have to speed up the prcess, besides getting new hardware?
PostPosted: November 19th, 2015, 18:53
You can use the Start/Stop button to pause and resume a scan. The Save and Load buttons allow you to save the current scan and restore a previous scan.
After pausing the search, you can select any found NTFS structure and Open Volume. This will enable you to access any files/folders that pertain to that NTFS fragment.
It would be helpful for us to see DMDE's Partitions window. If sector 0 is the only damaged sector at the beginning of the drive, then DMDE should still see the NTFS volume without a search. Repairing sector 0 would then require only a couple of mouse clicks.
One other thing that the Partitions window will show is whether your external drive is using 4KB sectoring, in which case you would have cloned a 512e drive to a 4Kn drive. I'm not sure how that would look to a data recovery program.
PostPosted: November 21st, 2015, 7:31
thank you for getting back to me - I have attached a picture of the DMDE partitions window, somehow the windows screenshot function didn't work here.
after scanning around 1% of the partition, dmde found ~4000 jpeg files, of which about the half had 0kb. I could recover a sample of the other jpegs could successfully.
- how would you judge the cloned disk based on the attached screenshot?
- I need to get back the structure of the disk, is it possible in any way?
Again, your help is very much appreciated.
PostPosted: November 21st, 2015, 7:37
another question - on DMDE's partitions search, some parameters can be set, including RAW EXT OR NTFS. so far, all that DMDE found belonged to RAW.
-> to speed up search, is it wise to limit it just to RAW?
Users browsing this forum: Google [Bot] and 286 guests
