 Post subject: Not Bios recog. Seagate Barracuda 7200.12 500 GB - FW: CC45
PostPosted: November 20th, 2015, 15:35
Hello folks,
first the HDD was BIOS recog. after a restart of the computer it was not recog. anymore. No spinning up - completely silent.
bsy bug?
corroded contacts? -- attachment
any DIY recommendations? ;-) RS232 TTL adapter I have.. already reanimated 2 Seagate HDDs with that. But in that case I won't do anything wrong.
Best Greetings
Benjamin
File comment: pcb overview
File comment: corroded contacts
Fachwerkstatt für Data Recovery / Datenrettung in Stuttgart - Riedel IT - Ameisenbergstraße 30 - 70188 Stuttgart
 Post subject: Re: Not Bios recog. Seagate Barracuda 7200.12 500 GB - FW: C
PostPosted: November 20th, 2015, 16:32
If it's not spinning at all and silent then the PCB would be the first starting point.
First check the TVS top left of the PCB, if that's OK then get a new PCB of same P/N and you MUST swap the 8-pin "ROM" chip top left. Careful though, if you damage that you're in BIG trouble!
Good luck.
PostPosted: November 20th, 2015, 17:05
That TVS is driving me crazy... i have to put very much pressure on a specific point with the COM (black) cable to get 0 OHM. Next time I try it pressure doesn't help... next time I get 0 Ohm again...
I'm only at the beginning to check a Diode correctly.. any recommendations?
Thanks so far! :-)
Greetings
Benjamin
PostPosted: November 20th, 2015, 17:15
Yes, BenDataRecovery stop doing DataRecovery for clients untill you have way more knowledge :)
Don't gamble with your clients data.
Splidit... I see no point in your comment. But maybe you could show me the steps I do mistakes in your view so I can be a better "gambler" in your terminology. :)
So far there are no indicators for me that this is a mechanical issue.. / it seems to be the TVS as prescribed above... Honestly I do not have the full knowledge... but as long as I don't open the drive and do nothing besides measuring I don't think I can do any harm.
Greetings Benjamin
edit:
Splidit, thank you fort that! :D
PostPosted: November 20th, 2015, 17:32
Splidit, thanks for your help sending me the links with very useful information - bet I will read that.
To calm you down a little bit: *no offence*
In many cases I send the requests to a partner or to Ontrack. It depends on various factors.
Acutally I need help in that case here... the 5 V TVS is high-ohmig in both directions. above 130 k in the direction I meassured it (see the picture above)... an 65 k in the other direction
PostPosted: November 20th, 2015, 19:34
I have the exact PCB layout like in the attached picture
http://www.hddoracle.com/viewtopic.php?f=24&t=123&p=149
then I found this manual:
start your drive by shorting read channels
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 6.035 secs
[Remove the shorting and give following command]
F3 2>U
HighPowerMode
ExecuteSpinRequest
Spin Up Complete
Elapsed Time 3.573 secs
F3 2>/
F3 T>m0,2,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 16, Max Certify Rewr
ite Retries = not supported
User Partition Format Successful - Elapsed Time 0 mins 00 secs
F3 T>/1
F3 1>N1
Clear SMART is completed.
F3 1>
[disconnect the power, wait couple seconds and connect again]
Rst 0x08M
(P) SATA Reset
Should be careful about that?
Wouldn't it be dangerouse to use the same procedure for a 7200.11 drive on a 7200.12 drive die to the Non-Resident G-List issue ?
Answer: Not always, it's danger only if NRG is filled with some entries, if is empty it's ok to regen translators (m0,2,2,,,,,22).
You may check if NRG is empty with V40 command.
like in that post:
viewtopic.php?f=1&t=18907&start=40
Can I do any harm when I short circuit the Reading Points in the picture and get terminal access.. when NRG is empty can i regen translators?
PostPosted: November 20th, 2015, 19:44
measuring 100 ohm in the read cirucit - and 50 ohm in the write circuit... so the points should be the right ones? Just double-checked it and compared it to the pictures in the hdd-oracle thread.
PostPosted: November 20th, 2015, 20:11
Decided to let the ROM transfered (soldered) to a new PCB.
PostPosted: November 21st, 2015, 11:11
I like the "lets try everything maybe something will work approach".
PostPosted: November 21st, 2015, 15:04
Try with the new PCB with ROM swap. If drive still doesn't spin check TTL log with PCB.
That I will do let do ;-). Thanks for support.
PostPosted: November 21st, 2015, 15:16
I would say check every possibilities and not fully try every possible step by yourself... You now the "data rec business" is very hard.. and it is not easy to find a way between spending 3000 € for a RAID recovery and the money the customer could afford and is willing to aford for that...
There is a difference between try everything and check everything...
For me it is important that wen someone has a problem to contribute to that problem. I'm the last one who is not wiling to pay for support.
At this point I want to express my gratitude to Sean / pcimage england who helped me a lot in that case and offered me his professional help with the ROM Swap thing. He made a big contribution by offering me his support without demanding money for initial consultation. I almost insisted him giving something for that. Because he gave me 30 minutes of his time. Instead I wrote a Google Review.
edit: I almost forgot Jared who helped me a lot in another case.
The attitude of helping each other and share knowledge and information is so important. Sharing knowledge means for sure giving money for that in exchange. Everything has to be fair in exchange... everyone has to live...
It seems for me such a big fight gaining knowledge without paying money for beeing in the elite PC3000 circle. And almost forced to upgrade it every I don't now...
In the end I want to express my gratitude to everyone who helped me with information actively or passively through this place sharing their knowledge in this forum.
Have a nice weekend everyone!!
PostPosted: November 21st, 2015, 17:16
Splidit, thank you for your help again. All the information I get from others and you in this forum will help (and already helped) to know what I can and what I can't do in the field of data recovery. My task is to be like a pioneer and find ways to help my customers in the interest of price , quality and speed. These factors should have a balance in the interest of my customers and my company. Maybe my direct form seems a little bit harsh... I'm curious like a little child. Asking many "perhaps stupid" (could be annoying or misunderstood) questions.
edit: have a nice weekend too! And thank you! ;-)
PostPosted: November 21st, 2015, 18:08
Spildit wrote:
The "m" command in the 7200.11 fix should not be applied to 7200.12 models. It results in partial LBA access due to a failure to account for a non-resident G-list. Apparently the fix works provided that the NRG-list is empty, but fails otherwise. That's why some "professionals" have reported success in the past.
If you do the m command on the 7200.12 drive and the drive have entries on Non-Resident G-List you will end up with partial access only, or so to say you will be able to read/verify only up untill the first sector that was present on the non-resident G-List.
fzabkar & Spildit:
CAN'T thank the both of you enough for pointing that out. I hope this will teach ANYONE not to thoughtlessly copy (seemingly) "magic recipes" off the Internet!!
@fzabkar loved the somewhat ironic undertone in "professionals" ;) *grin*
PostPosted: November 21st, 2015, 18:21
Spildit wrote:
Ok, check PM.
Regards.
Thanks for your help via PM. Now I understand much better what you meant! It helped me to be more patient and humble. And hopefully studying intensely the field of data recovery. I behaved almost like it is a 1 week thing to learn... and that is wrong.
PostPosted: December 9th, 2015, 14:38
What could that be?
Boot 0x40M
Spin Up
TCC-001D[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-001D
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR: MCMT SEC copy valid
Reconstruction: MCMT Reconstruction Start
Max number of MC segments 0A61
Nonvolatile MCMT sequence number 0000AA95
[RSRS] 03CA
ProcessRWError -Read- at LBA 0000000000031257 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000031257!
Reconstruction: Completed 1:
[MCMTWS]
Rst 0x40M
Spin Up
TCC-001D
LED:00000047 FAddr:FFFFFFFE
PostPosted: December 9th, 2015, 17:37
Don't ask how... but the issue is resolved... drive is now imaging!
PostPosted: December 11th, 2015, 16:03
The last two posts doesn't belong there. The issue was resolved by donor board and ROM transfer.
Users browsing this forum: Google [Bot] and 209 guests
