 Post subject: If my hard drive is making this noise, what could it mean?
PostPosted: November 27th, 2015, 23:17
https://youtu.be/ONAirz_6GVk
My drive spins up and then gets stuck in the beep-click loop. I'm asking any gurus if they have any ideas what the problem could be as I consider data recovery. Any help is much appreciated. :)
 Post subject: Re: If my hard drive is making this noise, what could it mea
PostPosted: November 28th, 2015, 7:16
It means that it has pretty severe physical issues. Bad heads at least and quite probably media damage :-(
PostPosted: November 28th, 2015, 11:58
Okay thanks. Is this something I can fix myself with a donor drive?
PostPosted: November 28th, 2015, 16:23
short very serious answer if the data is important go you - and I bet it is important to you:
no
Fachwerkstatt für Data Recovery / Datenrettung in Stuttgart - Riedel IT - Ameisenbergstraße 30 - 70188 Stuttgart
