 Post subject: WD My Passport WD10JMVW recovery
PostPosted: December 1st, 2015, 17:04
Hello gurus,
I received a 1TB WD My Passport from my customer for recovery but haven't been able to solve this mystery.
When powered on the disk spins up but starts beeping (4 short beeps) then spins down and tries to spin up again with same beeping sequence (this time repeats it 3 times)
I attached the audio here.
The disk has the PCB board with USB connector which I've already tried to replace with identical PCB (2060-771801-002).
Also rom chips has been transferred to the replacement pcb but still the same beeping symptoms occurs.
Disk has been opened in clean room for observation but there's no visible damage on top platter and heads are parked nicely to the ramp.
I have also a SATA PCB which should be compatible with the original PCB (2060-771823-000) but I haven't done any ROM transfer yet to this one because of the possible encrypting problem.
If there's someone who has fixed this kind of problems I would appreciate to get an estimate quote for recovery as PM.
Thanks!
BR,
A-P
wd10jmvw_beeping.zip [269.61 KiB]
Downloaded 636 times
 Post subject: Re: WD My Passport WD10JMVW recovery
PostPosted: December 1st, 2015, 17:32
It will be a physical (heads and/or media damage) problem.
PostPosted: December 2nd, 2015, 4:23
+1 for heads/media
Data Recovery Pakistan
PostPosted: December 2nd, 2015, 12:09
+2, definitely heads (at least).
PostPosted: December 2nd, 2015, 12:12
+3 for heads. And please stop powering on that drive. Every click and beep is dropping the chance that a professional can recover it later. Clicking is almost never related to the PCB.
PostPosted: December 2nd, 2015, 12:37
Couldn't agree more.
PostPosted: December 6th, 2015, 14:53
If the media damage isn't bad enough to kill new heads then it's a simple SATA conversion, headswap and decrypt on the fly for a pro. Let's hope it hasn't been powered on towards an inch of it's life as the other guys have mentioned :cry:
Data Recovery Cape Town
Users browsing this forum: No registered users and 178 guests
