 Post subject: Samsung 1 TB AV2 Series Motor roatation issue after HSA Swap
PostPosted: June 25th, 2014, 15:33
Recently swapped HSA of Samsung Laptop 1 TB HDD
Model: ST1000LM024, PN: HN-M101MBB/AV2, REV A, FW: 2BA30001
Patient has a broken head. After swapping from same model donor working head, the motor does not run & hdd does not get initiated :( . General problem in the AV2 Series & some AV1 series hdd with FW 2AR20003
Anybody have a solution for the same.. plz share..
Data Recovery Experts
http://www.nowdatarecovery.com
 Post subject: Re: Samsung 1 TB AV2 Series Motor roatation issue after HSA
PostPosted: June 26th, 2014, 7:42
If after heads swap the drive not spins, maybe you are not assemblied correctly the HDD.
Have you got experiende in dissasembling and assembling HDDs?
PostPosted: June 28th, 2014, 1:28
Hi sir,
I have successfully done the cases on most of the samsung hard drives which has head stuck & media issues with head broken from 3 years, have a clean room chamber & tools for the same.
But some particular series of seagate samsiung laptop hard drives has issues in motor rotation after swapping heads from same model drives, i have tried with 2 heads of the same model drive, but still then hdd does not give any rotations, only from its original head, the drive comes into rotation mode. Unfortunately patient heads are broken...
Is the issues are with,
1) Heads are not matching?
2) ROM is coded with preamp readings?
3) Need to match date code apart from Model, pn, fw & site code..?
PostPosted: June 28th, 2014, 7:38
padmanabha wrote:
Hi sir,
Check terminal response, I expect you'll see a preamp error there :-)
PostPosted: June 28th, 2014, 8:08
Hello Dear Friend Padmanabha
I Have Solution For Your Issue PM Me We Will Talk About it.
My Skype ID : smart.computech
Email : jignesh.pankhania@hotmail.com
Yours Friend
Jignesh Pankhania
PostPosted: June 29th, 2014, 5:53
padmanabha wrote:
Hi sir,
This es new forma me. If you hace success. Ley me know.
PostPosted: December 8th, 2015, 11:38
hi:
same issue ... how to fix this .. any help will be appreciated
PostPosted: December 8th, 2015, 12:56
hddtech, plz post terminal output. If drive does not spin might be not matching preamp.
best regards,
030 Datenrettung Berlin GmbH (Germany)
HDD, SSD, NAS, RAID Datenrettung - 030-datenrettung.de
Users browsing this forum: No registered users and 212 guests
