 Post subject: Toshiba MD04ACA400
PostPosted: December 10th, 2015, 0:24
Anyone have any troubleshooting experience with this model.
Drive spins up and continues to spin. No ID. Access to CP only. No ATA status lights either.
PM friendly.
Zero Alpha: zeroalpha.com.au
 Post subject: Re: Toshiba MD04ACA400
PostPosted: December 10th, 2015, 8:37
does it responds to terminal input?
PostPosted: December 10th, 2015, 17:46
Spildit wrote:
Did you try with Hitachi utility ?
I'm under the impression that this 3.5 drive might be really Toshiba.
ISTR that data-medics mentioned that it was a Toshiba, not a Hitachi. The PCB has 4 serial flash memories (IC9 - IC12), so there appears to be something different about its architecture.
PostPosted: December 10th, 2015, 18:21
This one had a damaged G-list:
viewtopic.php?f=1&t=31620
PostPosted: December 10th, 2015, 18:56
That one is a seagate 2.5
Wow, that was a bad brain fart.
Try this:
viewtopic.php?f=1&t=31612
Users browsing this forum: Google [Bot] and 232 guests
