Re: Advice on recovery for a WD My Passport 2TB USB drive
February 14th, 2016, 7:36
jermy wrote:if you convert to SATA, then clone it to another WD
1) make sure they have the same LBA's
2) 4061-705094 uses the same chip and able to decrypt the data
the pic after finish clone:
it's clone about 75%
February 14th, 2016, 14:24
First, I see you did it wrong, you have to clone the entire drive I.e.
ddrescue <parameters> /dev/sdc /dev/sda <logfile>
not a partition (sdc1).
Second, with that size of error , I would have considered to clone it with hardware (I assume you'll have a lot more data out).
February 14th, 2016, 16:21
75% looks like good data from 3 heads (748GB), and one bad head with no data (252GB, and last successful read was 1.1 days ago). 25% of the data is toast unless you take it to a professional that is capable of replacing heads. I don't see any more do-it-yourself for that drive.
Also, as jermy pointed out, you might have a bit of extra trouble working with the recovered disk since you cloned a single partition to a whole drive.
February 15th, 2016, 1:35
Thank you for your replies
I'll reclone it by your recmmandation.
After get the most data, I'll see what I can do for a sick head.
April 4th, 2017, 17:01
I can help you with decrypting the data, if you still need. I know how to set up a
decryption filter using cryptsetup in linux.
