 Post subject: Seagate Freeplay ST1000LM010 spin but not detect
PostPosted: December 13th, 2015, 21:06
I have my external drive seagate freeplay 1tb ST1000LM010 that not detect on my computer but i heard a spin and have led flashing. i go to disk management there not detect my drive. I also change my my cable still not detect even i use sata cable still not detect. i also uninstall the USB from device management and restart my PC and the result is still the same. is it posible my board is corrupted?
Please help i have important data at my drive...
 Post subject: Re: Seagate Freeplay ST1000LM010 spin but not detect
PostPosted: December 13th, 2015, 21:18
it keeps spinning ?
is there any unusual noise ?
post terminal log
PostPosted: December 13th, 2015, 21:23
whoops double post
PostPosted: December 13th, 2015, 22:16
Jermy:
Yes, It keeps spinning. the noise is like crik crik at the beginning but after 3 seconds it spinning normally because before it not detect the noise like crik crik at the beginning also. even i connect using different USB cable and use direct to SATA Drive not detect also. How to see the terminal log?
Spildit :
i connect direct using SATA and see from BIOS also not detect. It only detect my primary hard drive running Operating System.
PostPosted: December 15th, 2015, 8:42
Spildit, i already check at the shop they say my hard drive cannot be recover. how to i take my data back? any suggestion?
PostPosted: December 15th, 2015, 8:54
do they have a picture of the platters ?
maybe it's media damage who is killing the heads
PostPosted: December 15th, 2015, 11:42
High chance "the shop" are not data recovery specialists or are not good enough. Or simply, information has been lost in translation as far as drive behavior and so on.
PostPosted: December 15th, 2015, 20:02
Jermy, labtech:
They don't have any media for it. i already buy the new USB adapter that working on my other hard drive but after i insert into my Seagate Freeplay still doesn't detect but the hard drive is Spinning, i just want to find the board with same model just want to try if the hard drive working or not but in my country hard to find this board model.
I already ask from ebay if want to buy the board, they ask to send the faulty board to transfer the PCB chip to another board. I do not know if it works or not after doing the board PCB transfer because my hard drive is spinning.
PostPosted: December 15th, 2015, 21:43
IMHO you wasting your time and money
if the drive is spinning and it's the original PCB, replacing the PCB is a waste of money
already stated above post the terminal log
PostPosted: December 18th, 2015, 2:25
Jermy:
Where is the terminal log located? i type terminal log no appear.
PostPosted: December 19th, 2015, 13:37
already answered by spildit above
PostPosted: December 27th, 2015, 5:46
maybe help you.
http://ts.acelaboratory.com/index.php?/ ... a-sys-file
viewtopic.php?f=1&t=27390
Users browsing this forum: No registered users and 40 guests
