 Post subject: crasahed drive sent to recovery
PostPosted: June 14th, 2017, 9:00
i have a hdd that crashed and i sent it to commercial recovery. The recovery team has the encryption key to decrypt it.
the feedback i got was
We are currently still trying to recover your data, head 0 is giving us a bit of a headache.
Tech report:
Transplanted heads. Made SA backup. 1x NTFS partition, it is encrypted.
Transplanted heads 3 times, but head 0 dies after a while.
Mirror finished with 2.3M sectors not read (head0).
What does this mean? is the drive busted?
 Post subject: Re: crasahed drive sent to recovery
PostPosted: June 14th, 2017, 18:27
2.3 million sectors unread is not a huge number on most modern drives. A 1Tb drive has around 2 Billion sectors total. So it sounds like they recovered a majority of the data. I'd ask them for a listing of the files with bad/unread sectors.
Unless of course those bad/unread sectors contain the disk encryption key, in which case you are definitely screwed.
PostPosted: June 15th, 2017, 3:58
Drive stores your data on magnetic platters, where the smallest portion of data that drive operates is a sector (4096 bits). Modern drives consist of a millions and billions sectors. So, in your case you've lost some part of disk (data). Actually, 2,3M sectors it is not too much, if there was a serious mechanical problem. It is better if all unsuccessful sectors are located in one region, in this case more data will survive.
Users browsing this forum: No registered users and 261 guests
