ST3320613AS (320GB) LBA 0 need help
December 29th, 2015, 12:21
Hi guys,
I am using PC3K and would be very happy to get your addvice on the following case:
I got today the following drive:
Model : ST3320613AS (320GB) 7200.11
Firmware : CC2H
The drive become ready but stuck on LBA 0 problem and don't know what to do.
I cleared the smart and regenrated the translator again but the drive keeps on LBA 0.
I have feeling that it relate to the sys files or to the G-List but not sure..
At first time the drive started with BSY state problem and refused to comunicate with the terminal at all.
After few combinations of shoritng the read chanel the drive come back to live (with out the real capacity 320GB) and give access to terminal.
I followed few times the steps for fixing 7200.11 BSY problem and LBA 0 problem but the drive still on LBA 0.
During the first round for fixing BSY state the drive couldn't clear the smart.
Evantualy when I powered off and on the drive become on ready state keep spining doesn't click, run fast and give access to all sys files and models but keeps on LBA 0.
No matter what I did the drive keeps on that situation.
I am sure that I am missing something but can't figure out what it is.
By the way, If I try to reach to the SA without the terminal than I get error on terminal
LED:000000CE FAddr:0025FE1F
I have access to the P-List but don't have access to the Non Resident Primary DST List and Don't have access to the Non Resident G-List
NRG, copy 0: Rq Rd Sys File part ID 0, Offs 0x0 err! Tech state 0x72, 0x04440000
NRG, copy 1: Rq Rd Sys File part ID 0, Offs 0x0 err! Tech state 0x72, 0x04440000
Error reading Non Resident G-List!
Error reading Non Resident Primary DST List!
This is the utility log when I open it after power off and on:
HDD family detecting...
Family ID: 2D
Selected family......................... : 2D, Brinks
Model by ID............................. : ST3320613AS
Loading default settings!
Use the options dialog to review and save utility settings.
Then press OK!
Family default settings loading!
Tech Key...
Requesting FW Pkg ver ........ BR140D.CCD2.CG0H0H.
Detecting Phys Sct Size...
Result.................................. : 512
Detecting Max Head number...
Phys. heads............................. : 2
Obtaining Saved Mode Pages File information...
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
SMP Dbl: 0x3C000317 - 0x037FF7FF (0x0000000F)
LBA alignment........................... : 0
Obtaining Registry File information...
Reading Registry File...
Parsing Registry File...
Media Cache
MC is not supported / NVC caching
Collecting Sys Files information...
  ID        Len
   0          4  Reserved Defect Table (SA defect table)
   1          2  Drive Information File (DIF)
   2         16  Performance Parameter File (PPF)
   3       3787  Primary Defect File (P-List))
   4         12  Servo Adaptive Parameter File (SAP)
   5          4  Manufacturing Information File (MIF)
   6         66  Read Adaptive Parameters File (RAP)
   7          1  Controller Adaptive Parameters File (CAP)
   8       4800
   9          1  SMART Configuration File
   A       2251  SMART Data File
   B       1000
   C      64000  Serial Port Test Results File (Self Scan Log)
   D        160
   E        432  Data Integrity Check (DIC), HEAD 0
   F        223  DIC Dummy File
  13          8  Disc Registry File (settings, security, etc)
  15        100  BGMS File (Directed Offline Scan)
  16          2
  17         40
  19         24  Log File
  1A         33  Log File
  1B          1  Log File
  1C          9
  1D        128  Physical Overlay File 0
  1E        128  Physical Overlay File 1
  1F        640  Physical Overlay File 2
  22         80  Drive Self Test (DST), Head 0
  23         80  Drive Self Test (DST), Head 1
  2A          9  Saved Mode Pages (HDD settings)
  2B        928  R/W Operating Parameters (translator, etc)
  2C        432  Data Integrity Check (DIC), HEAD 1
  33       4576
  34        640  Packed CONGEN XML definition
  35         26  SMART Data
  3A          4
Collecting Sys File Infos completed
Collecting DT Infos...
ROM:
  ID     MemOffs        Len
   0     6020100      33792  Read Adaptive Parameters File (RAP)
   1     6020000        256  Controller Adaptive Parameters File (CAP)
   4     4001000       4096  Servo Adaptive Parameter File (SAP)
         602BE00       4096
              total    8192
   5       6C000      81920  Servo Firmware Table
   A     60A6CF8       1024  Seek Profile
  13     60B1CE0        544  Dependent Zone Table for User Area
  14     60B1F00         64  Dependent Zone Table for System Area
  15           0     524288  Flash ROM
  1B     60B1008       3288  Dependent Zone Group Tables for User Area
  1C     60B0EC8        320  Dependent Zone Group Tables for System Area
  1D     6020120        208  VBAR Configuration File
  1E     6020310       2320  Zone Format Parameters File
RAM:
  ID     MemOffs        Len
   2     60201F0        288  Zone Table
         602BE00       4096
              total    8192
   6      267A44      40996  Servo Flaw Table
  16     6020100         32  Drive Configuration Table
  17     6021F20       1744  Temperature Control Configuration
  1F     6184690       1224  RW working user preamp table
  20     6184B58         72  RW working system preamp table
Collecting DT Infos completed
Reading autotuning buffer...............   Ok
Searching module table in RAM... .......   Ok
Searching volume 3 file table in RAM....   Ok
Searching volume 0 file table in RAM....   Ok
Searching SMP RAM FID in RAM............   Ok
Searching Non Resident G-List FID in RAM   Ok
Searching CFW OVL FID in RAM............   Ok
Searching DT table(RAM, WR) in RAM......   Ok
Searching DT table(RAM, RD) in RAM......   Ok
System Files I/O method detection... ATA(indirect)
Re: ST3320613AS (320GB) LBA 0 need help
December 29th, 2015, 20:45
Spildit wrote:Try to apply the 7200.11 fix by hand (without PC3K) ?
http://www.hddoracle.com/viewtopic.php?f=83&t=38
Regards.
I did this at the begining, any way thank you for the repaly, I fixed the drive :)
