 Post subject: Recover Data on Acer Aspire One.
PostPosted: December 28th, 2015, 6:09
Hello.
I have a Netbook "Acer Aspire One" and wanted to recover it, But I have a problem. The user Overwritten Data and most files can't recovered. Any idea?
I used "GetDataBack" version 5.2.XX and I want to know can I have better options?
Thank you.
 Post subject: Re: Recover Data on Acer Aspire One.
PostPosted: December 28th, 2015, 7:01
Can you provide more details of the version of GetDataBack? I don't think there is a version by that number. It is either 1.00 or 4.33 AFAIK.
If user overwritten files, then IMHO there is nothing more you can do. GDB is pretty good, comparable to R-Studio and these two should recover anything that is recoverable barring hardware faults.
PostPosted: December 28th, 2015, 7:36
Oh sorry, I mean was "GetData Recover My Files 5.2.1.1964".
If data overwritten then nobody can recover it?
PostPosted: December 28th, 2015, 8:19
i think use rstudio
https://www.rstudio.com/
PostPosted: December 28th, 2015, 8:21
http://www.r-studio.com/
this is better
PostPosted: December 28th, 2015, 13:11
If you choose R-Studio, this article will help: File Recovery after Re-installing Windows.
R-Studio Data Recovery Software
PostPosted: December 29th, 2015, 8:24
Yes: http://www.ufsexplorer.com/index.php
But you should realize, though it's an excellent data recovery software, its time machine functionality is still under development, so overwritten data is lost atm.
PostPosted: December 30th, 2015, 4:34
Can it recover overwrites data?
PostPosted: December 30th, 2015, 5:02
hack3rcon wrote:
Hello.
Thank you.
What did they overwrite?
Did they re-install windows on the drive?
Was the drive formatted in Windows? Was it a quick format or extended format?
Was the drive zero erased or similar?
Finding these things out from the user can let you know if you wasting your time or not.
You need to do a "RAW" recovery and search by file extensions, R-Studio, UFS-Explorer etc can do this.
Your most likley not going to get any sort or file names or file directory back.
Web: https://www.day1data.de
PostPosted: December 30th, 2015, 5:25
depends on how much is overwritten. generally you wont know until you try and see the results. I recently recovered files from a mac that had a botched el Capitan install over the top of data that was actually thought to be saved beforehand, but wasn't. there were many many bad and corrupt files, but also many pictures and some documents were ok. I would say somewhere between 15 - 20%. It is going to be a nightmare for this customer to sort through though.
PostPosted: December 31st, 2015, 5:19
day1data wrote:
hack3rcon wrote:
Hello.
Thank you.
Thank you.
They formatted the drive and copy other file on most of it. For example, If the drive is 50GB then copy new files about 40GB.
PostPosted: December 31st, 2015, 13:52
Spildit wrote:
hack3rcon wrote:
day1data wrote:
hack3rcon wrote:
Hello.
Thank you.
Thank you.
Then with luck and by RAW RECOVERY (without folders and names) you might be able to rescue partially the data on the 10 GB that are left ... But of course that would be the end of the drive where normaly you will have lots of junk like windows pagination files so ... get ready to accept your loss.
If overwritten Data recovery is impossible then how government recovering data? I mean is that "NSA" can't recover it too?
PostPosted: December 31st, 2015, 14:26
it doesn't matter, overwritten data is gone, there isn't a government agency in the world who can recover it
Users browsing this forum: Abdul Rauf, Google [Bot] and 447 guests
