 Post subject: ST5000DM000 Terminal Output Help
PostPosted: December 30th, 2015, 14:09
Anyone know if this is head failure? The drive has been dropped so I would be amazed if its not head failure (although the drive does not click and keeps spinning). Obviously with this drive terminal input is limited. Output below.
Boot 0x80M
Spin Up
RECOV Servo Op=0100 Resp=0005
0100 0000 0000 0001 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
ResponseFrame 4030 006C 05DC 6DFD 0008 0000 0000 0000 0F17 00C8 0000 7200 0000 0000 0000 0000 0000 0000 27FA 0E11 59C7 0001 0001 D616 FFFD ABCD ABCD FF8A 0000 0001 1B1A 0000 0004
Trans.
Rst 0x80M
Spin Up
SpinOK
TCC:001E
Humidity:25.2%
(P) SATA Reset
Last Saved GlobalHeader EraseInProgress:00 DiscDataValid:00
NVC Power Loss Host Sig:478DDE7F PC:00F5
NVC Debug Log: DEADBEEF 03 03 0000 00000000
   PP: 6EEA1846 0000030C E930
   TW: 1EF7D947 00000188 A735
GC:   A06D4892 00000004 C0C1
ENP0x00F6
New GlobalHeader EraseInProgress:00 DiscDataValid:00
NVCClearingEraseInProgress:00
NVCOkToWrite:07
NVCClientDisabled:00
DumpNVC
MCMainPOR: Start:
Media Cache Data Base  02468748B0
Check MCMT Version: Current
MC026: Reconstruction: MCMT Reconstruction Start
[RSRS] 175C
MC024: Reconstruction: Completed:
[MCMTWS] Tail/Head 1758 175C
SP200: MSP Restore Start
MSPBaseSegmentIndex 000016E0
MSPDiscSequenceNumber 00069E64
ProcessRWError -Read-   at LBA 0048E3ACD6  Sense Code=40000087
MC001: Reconstruction: EXCEPTION: Segment Read Failed
ReadFooters: TotalUserBlocks E448 Seg 16E0 Sequ 00069E6B MaxSeg 1703 FirstFooterLBA 0012E04C
  ReadValidFooterOfMetadata:  Footer LBA 000012E04E
    Metadata Footer ID/Sequ FFFFFFFF FFFFFFFF
Invalid footer .
ProcessRWError -Read-   at LBA 0048E3CF4A  Sense Code=40000087
ReadFooters: TotalUserBlocks 4C18 Seg 170A Sequ 00069E6A MaxSeg 1716 FirstFooterLBA 0012EFBB
  ReadValidFooterOfMetadata:  Footer LBA 000012EFBD
    Metadata Footer ID/Sequ 19179447 00069E6A.
  Footer Obtained: FooterLBA 000012EFBB
Seg Footer  IDX 0000 SQ 00069E6A PL 0001 ID EB854140A6CD8450 D651E378AE632CEF 19179447
MC016: Reconstruction: EXCEPTION: Header is okay and valid Footer Present
SP201: MSP Reading Band - 000AF5F5 - 000AFF78
SP210: MSP Restore not required
SP211: MSP Restore Passed
MCMainPOR: MediaCacheDiscStateFlags 0000002A  MCStateFlags 00400041  Tms 00000163 000001AD 0000033A
6Gb Max Speed lowered to 3Gb for Intel bug
Send Status: COMRESET seen
[BRO - 0002] 000AF5F5 - 000AFF77
RAW ON After Spinup for counter=0x00002000, BlkAddr=0x0048E3C3B6
ProcessRWError -Write-  at LBA 0048E3ACD6  Sense Code=40000087
RAW Mode Sector Writes After Spinup Is Now OFF, End BlkAddr=0x0048E3C577
ProcessRWError -Write-  at LBA 0048E3AE9F  Sense Code=40000087
ProcessRWError -Write-  at LBA 0048E3B06F  Sense Code=40000087vqvqvqvqvqvqvqvqvqvq
Starting LBA of RW Request=0048E3ACD6  Length=000009D8
ProcessRWError -Write-  at LBA 0048E3B088  Sense Code=C4090081
Dither
Dither
Dither
Dither
RAW Reallocate [WA]!
ProcessRWError -Write-  at LBA 0048E3B089  Sense Code=C4090081
Dither
Dither
Dither
Dither
ProcessRWError -Write-  at LBA 0048E3B08A  Sense Code=C4090081
Dither
Dither
Dither
 Post subject: Re: ST5000DM000 Terminal Output Help
PostPosted: December 30th, 2015, 15:00
Switch off media cash, remove background processes, repair broken system files if needed. Drive has problems to read system area (may be because of shifted platters).
PostPosted: December 30th, 2015, 15:12
Unfortunately I cannot get to service information objects by Terminal or ATA to turn off background processes.
PostPosted: December 30th, 2015, 18:12
Did you try to short read channel?
Users browsing this forum: No registered users and 69 guests
