 Post subject: WD donor DCM, close match
PostPosted: January 5th, 2016, 13:23
I have a problematic head of western digital WD400UE-22HCT0 and DCM:HYHTJBNH. The donor has slight difference in DCM as HYHTJHNB, rest is same. Will it work as donor of head?
Thanks.
 Post subject: Re: WD donor DCM, close match
PostPosted: January 5th, 2016, 13:31
Should work.
Good luck.
PostPosted: January 5th, 2016, 19:08
the HTJ part is what matters IMHO.
PostPosted: January 6th, 2016, 6:02
+1 it should work.
PostPosted: January 6th, 2016, 14:49
+2 compatible.
Assuming the media and SA are OK, it should work.
PostPosted: January 6th, 2016, 16:44
Thanks all, I am going to buy this donor. Wish me luck, will update the experiment.
PostPosted: January 6th, 2016, 16:52
Bad luck, seller says the picture is only for display and actual hard drive available for sale has different DCM :(
Users browsing this forum: Google [Bot] and 60 guests
