 Post subject: SAMSUNG (HD204UI)
PostPosted: January 4th, 2016, 8:35
Terminal output :
ActiveFW : 00FWVer : 0001SATA PLL cal doneDDR size detected = 32MB*PA VID=0000 PN=0009 Rev=0001- 785x Found*PA VID=0000 PN=0009 Rev=0001- 785x FoundU
S_0
RV Sensor Circuit Enabled
Shock Sensor Circuit Enabled
SO_1
SpinStartUp: mcSpinRPM = 0
RPM at Handoff: 526
Temp : 22 degC
SpinOk
mS1 00000003
UF 3 1stGrayErr Hd:0
VOP!
PK_3 C: 0 H:0
UF 3 1stGrayErr Hd:1
VOP!
PK_3 C: 0 H:1
UF 3 1stGrayErr Hd:2
VOP!
PK_3 C: 0 H:2
UF 3 1stGrayErr Hd:3
VOP!
PK_3 C: 0 H:3
UF 3 1stGrayErr Hd:4
VOP!
PK_3 C: 0 H:4
UF 3 1stGrayErr Hd:5
VOP!
PK_3 C: 0 H:5
VOP!
PK_3 C: 0 H:0
VOP!
PK_3 C: 0 H:1
VOP!
PK_3 C: 0 H:2
VOP!
PK_3 C: 0 H:3
VOP!
PK_3 C: 0 H:4
VOP!
PK_3 C: 0 H:5
VOP!
PK_3 C: 0 H:0
VOP!
PK_3 C: 0 H:1
VOP!
PK_3 C: 0 H:2
VOP!
PK_3 C: 0 H:3
Unlatch Fail
EPOK
VOP!
PK_4 C: 0 H:4
VOP!
PK_4 C: 0 H:4
LED 1102
LED 1102
LED 1102
Drive is clicking several times then spin down and stays busy.
Any thoughts ?
Thanks in advance.
 Post subject: Re: SAMSUNG (HD204UI)
PostPosted: January 4th, 2016, 8:52
looks head failure to me
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: January 4th, 2016, 9:38
ya3ni bet7beni ? :)
Me too.
Thanks for confirmation.
PostPosted: January 4th, 2016, 17:29
Spildit wrote:
i have to disagree, see ACE's user manual page 65
chapter 8.7.2 Cyclic<<LED 1102>> message
PostPosted: January 4th, 2016, 17:55
i'm not arguing on the diagnosis that's been given (bad heads)
(because of the "UF 3 1stGrayErr Hd:x")
i just mentioned about LED 1102
no hard feelings :)
PostPosted: January 5th, 2016, 7:59
Thanks for heads (Pre-amp) confirmation Spildit.
