 Post subject: HTS543216L9SA00
PostPosted: January 11th, 2016, 11:02
Hello Gurus,
The drive came to me from Kuwait opened. ( I don't know who opened it, but surely it's opened in non-controlled room with non-professional person )
The drive has a fingerprint on the top side and a ring scratch to the outer diameter ( 1 platter-2 heads ).
After replacing heads from fully matched donor, the drive spin up and calibrate normally but there's a 1 click then the drive become ready but no ID.
Any thoughts friends?
 Post subject: Re: HTS543216L9SA00
PostPosted: January 11th, 2016, 12:37
I don't know even if it's the original PCB and NV-RAM or not.
Is there a way to identify if it's the original PCB or not ?
Thanks in advance.
PostPosted: January 11th, 2016, 14:15
Post the NVRAM here
PostPosted: January 11th, 2016, 14:33
Thanks for the reply Mr. Sean.
NV-RAM.rar [417 Bytes]
Downloaded 810 times
PostPosted: January 11th, 2016, 15:00
The label would suggest a serial number of "VCFGXZ3A" but the NVRAM doesn't agree.
000001C0        56 43 47 30 42 31 52 41                      VCG0B1RA
The manufacture date on the cover 04MAY09) seems to match the "Mzn917" on the PCB label. That could be a YWW date code, ie week 17 of 2009, which does match the cover.
PostPosted: January 11th, 2016, 17:44
Thanks for replying Mr. Frank.
So, is this the native PCB?
PostPosted: January 11th, 2016, 17:55
According to NVRAM n LABLE - it's not native PCB
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: January 11th, 2016, 18:00
I may be wrong, but IIUC the serial number in the NVRAM does not match the one on the label, so it can't be native.
Here are 5 drives that appear to confirm my thinking:
http://www.ebay.com/itm/HTS543216L9SA00 ... 2206wt_918
Edit: Sorry, I didn't see the previous reply.
PostPosted: January 12th, 2016, 5:21
Thank you very much for confirming that my friends.
PostPosted: January 12th, 2016, 7:08
Correct
PostPosted: January 12th, 2016, 7:09
Duplicate post
PostPosted: January 12th, 2016, 8:08
Thank you all for confirmation.
So, is there anyway to retrieve the data without original PCB+NV-RAM?
Thanks in advance.
PostPosted: January 12th, 2016, 8:15
Possible. I believe your tool has adequate fonction to try this.
__________
THANK YOU
SHAHI
PostPosted: January 12th, 2016, 8:22
Thanks for reply Mr. Shahi.
I have MRT, but I have no access to SA ?
PostPosted: January 12th, 2016, 10:52
i'm not familiar with MRT but isn't there a function for NVRAM adjustment ?
if not PC3k does, outsource it to someone who has PC3K
PostPosted: January 12th, 2016, 10:57
Yes.
PostPosted: January 12th, 2016, 13:32
You won't get SA Access, it's normal in such circumstances.
You can try the NORMAL Mode and see
__________
THANK YOU
SHAHI
Users browsing this forum: Google [Bot] and 48 guests
