Seagate ST3320820AS stays BSY
January 17th, 2016, 15:43
On PC3K, this 320GB hard drive spins up, BSY light stays on...
-has normal, quiet spinning sound, but stays BSY forever.
-Power off/on, there is no Terminal output.
-needless to say PC3K is useless at this point because something needs fixing first.
-any ideas folks?
(I have ordered an exact match Donor controller and will
see the results of ROM swap after a week or so...)
-Thanks
Re: Seagate ST3320820AS stays BSY
January 17th, 2016, 16:19
Odd there is no terminal output. Double checked settings and correct adapter?
And tried a loader yet?
January 20th, 2016, 13:28
If you have PC3K , I understand what you've already seen , but .....
you tried to solve the problem 7200.11 busy ????
January 20th, 2016, 15:35
I have seen drives before that nothing was being posted to terminal at all, however most often it's simply a matter of the terminal not working at the moment.
First, check if your terminal is even working using a good drive. Then I'd probably try shorting the read channel.
