 Post subject: ST1000DM003 Bios does not recognize
PostPosted: January 21st, 2016, 2:48
Hello, sorry for my english, I am a programmer and I found this forum, you known every when we have some problem we try to search knownedge in web and I land here, very nice forum.
I have problem with this hard drive.
I have log from terminal
Boot 0x40M
Spin Up
TCC-001D[0x000065B4][0x00006A20][0x00006E8C]
Trans.
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-001D
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR:  MCMT SEC copy valid
Reconstruction: MCMT Reconstruction Start
  Max number of MC segments 0A61
Nonvolatile MCMT sequence number 0004FDE0
[RSRS] 0527
ProcessRWError -Read-   at LBA 00000000000431A9  Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00000000000431A9!
[SW] 0022
[SW] 0022
[SW] 0021
[SW] 0021
Reconstruction: Completed 1:  Reconstruction occurred
[MCMTWS]
Rst 0x40M
Spin Up
TCC-001D
LED:00000047 FAddr:FFFFFFFE
.......story ends 50 attempts
Could you explain me, what's mean LED:00000047 FAddr:FFFFFFFE
Can I do something to back my data
Ideas for what I should do next?
Thank you in advance.
 Post subject: Re: ST1000DM003 Bios does not recognize
PostPosted: January 21st, 2016, 21:34
LED:00000047 - Stack pointer out of range.
If you need data - go to pro.
PostPosted: January 25th, 2016, 2:40
Thanks,
Can I do something if I don't need data ?
You known some DIY
PostPosted: January 25th, 2016, 5:02
Well,
Saw Some of Your Posts At Acelab Also .You Are Good At Work Sir ,I Take My Words Back That i had posted long time back when you just started posting .Also you should remember we cannot just recommend someone we do not know and has just started posting to the forum .I Hope .In this case i also see a message that says its reallocating some sectors .Might be he could disable that and also Media cache messages [ disabling that might help ] . And you are correct he should go to a Pro .And on the lighter note poland is full of talent
Users browsing this forum: No registered users and 49 guests
