 Post subject: HddSupertool 1.5 - WDC WD10JMVW-11AJGS2 is not supported
PostPosted: January 27th, 2016, 11:14
I used HddSuptertool 1.5 lattest build in Partition magic linux (hiren boot cd 15.2)
When i try to read mod 02 and mod 32 i m getting "Command failed!"
the log
SC menu
q) Quit
p) Previous menu
h) Toggle script help
1) WD dump mod 42 (older drives)
2) WD royl dump mod 02
3) WD royl dump mod 32
4) WD royl patch mod 02 (slow fix)
5) WD royl patch mod 32 (slow fix)
6) WD royl dump all modules
Enter your choice:
> 3
3
Model: WDC WD10JMVW-11AJGS2
Serial: WD-WXJ1EA3LZFH5
Command failed!
sense_key=0xb asc=0x0 ascq=0x0
error=0x0 count=0x0 lba=0x0 device=0x0 status=0x0 altstatus=0x0
command_status= 0x0
data_transferred= 0x200
VSC menu
q) Quit
p) Previous menu
Enter your choice:
> 2
2
Command failed!
command_status= 0x0
VSC menu
q) Quit
p) Previous menu
Enter your choice:
> 6
6
Command failed!
command_status= 0x0
is there any chance to fix without changing to SATA PCB
Note: HDD is working with very very slow speed
 Post subject: Re: HddSupertool 1.5 - WDC WD10JMVW-11AJGS2 is not support
PostPosted: January 27th, 2016, 11:16
I think that might be a SED locked drive. Not positive, but a good chance it is.
PostPosted: January 27th, 2016, 12:57
You should e-mail sdcomputingservice@gmail.com
Users browsing this forum: Google [Bot] and 82 guests
