Fujitsu 320GB HDD failure, main controller ic ?
February 2nd, 2016, 16:51
I have a failed Fujitsu 320GB HDD, Firmware 00808909, board : CA26344-B33104BA, the problem started when i tried to hibernate on my laptop today, appeared blue screen, after hardware restarting of laptop, it shows no bootable device ...
i used an external hdd driver box and connected the failed hdd to another laptop through usb port, it still doesn't function.
i opened the hdd and saw :
the disk spins, the heads also move to disk center and return back to first place ( out of dick area ) again ... and this is repeated ... , but the main controller ic ( 88i6737-TFJ1 ) gets hot fast ! and the hdd is not recognized by pc ...
i think the main IC is damaged, thought to change the board and found :http://www.hddzone.com/fujitsu-pcb-ca26344b33104ba-p-511.html
but in the page, it says :
"Note: This PCB's BIOS is intergrated on the Main Controller IC. You should exchange the Main Controller IC to let the HDD be recognized."
so it means if i change the board and my first main controller IC be damaged, i can't fix the hdd to recover data ?!
is there any other way ?!!
Thanks & Regards.
Re: Fujitsu 320GB HDD failure, main controller ic ?
February 3rd, 2016, 7:01
Today, someone told me the head is damaged and the main controller IC gets hot because the head can't read data ...
what do you think ? main controller IC is damaged or head is failed ?!
Thanks & Regards
February 4th, 2016, 8:31
99% head damage.
