 Post subject: Problem Seagate ST32000444SS origin EMC
PostPosted: February 7th, 2016, 7:44
sorry for my english i'm french.
I have a problem with my hard drive ST32000444SS origin EMC,
my server detect in ST320004CLAR2000 firmware BS1B,
They are detected, but I create a raid going on in error,
I can not seem to flash the firmware with DELL.
Can you help me ?
Regards,
Cirvent
 Post subject: Re-flash Seagate EMC hard drive with Dell firmware
PostPosted: February 7th, 2016, 9:57
That's a vendor hard drive and it's locked. Bypassing the lock is far from being obvious.
 Post subject: Re: Problem Seagate ST32000444SS origin EMC
PostPosted: February 9th, 2016, 15:12
thank you for your reply
I tested this http://blog.eblend.ca/2015/04/flash-dell-firmware-into-seagate.html
but it does not work.
You have an idea ?
Reagrd,
Cirvent
PostPosted: February 14th, 2016, 10:07
I'v seen many Emc branded SAS drives, most all of them weren't locked ,they just have a different sector size.
Angel Data Recovery
PostPosted: March 5th, 2016, 3:49
Regards the Seagate ConstellationES1-Muskie could you use firmware 0008? If so I'll retrieve it.
PostPosted: March 21st, 2016, 23:01
Seagate ConstellationES1-Muskie firmware in WinRar file. Sometimes with Dell you need their first and earliest firmware update if it can be found. Also sometimes with Dell you have to start with the manufacturer's firmware on the hdd but I've only run into that once and that was some time ago.
MU-SAS-0008.rar [567.58 KiB]
Downloaded 586 times
PostPosted: November 23rd, 2016, 12:11
I have the same problème in some way, I have dozen of ST32000444SS with a Dell firmware KS6B that I am trying to flash with the original Seagate 008.
I have tried with SeaTools and sg_write_buffer under Linux, but both of them fails.
Any ideas ?
Users browsing this forum: No registered users and 100 guests
