CANNOT ACCESS 2 WD HDD ATTHE SAME TIME AFTER RAW COPY
February 17th, 2016, 2:55
Hi
My WD Elements HDD suddenly stopped working ,it showed format disk every time,so i figured it to be simple partition error.So i bought a new WD Passport HDD and did a raw copy.Formatted the old HDD and everything went well.But now when I try to connect my HDD the system detects only the first HDD that is connected.I cannot connect and use both WD HDD athe same time.I tried formatting one HDD but still the problem persists.
Any Help??
