 Post subject: seagate central 4TB issues - hard drive inoperable.
PostPosted: February 26th, 2016, 19:34
there was an upgrade available online and when the computer was upgrading my connection got lost and now my computer can't locate the seagate central device.
I think that the interrupted might have rendered my hard drive inoperable.
Is there anything I can do?
I hope somebody can help me...
 Post subject: Re: seagate central 4TB issues - hard drive inoperable.
PostPosted: February 27th, 2016, 11:03
First off, it would help if you posted a bit more information. Can yo give the drive model number, link to it's product page maybe, and what software you used to do the update?
Most firmware updaters will not start the update until it has the whole file stored locally and did some sort of hash check before proceeding with the update. Same goes for NAS-type drives. They'll first retrieve the whole firmware file and check it before starting the flashing process, making internet issues unlikely to have caused an issue.
PostPosted: February 27th, 2016, 18:01
Can you remove the drive from its enclosure and test it on a SATA port? Start with a SMART report. This will tell us the physical state of the drive. Note that the file system will most probably be a Linux type, in which case you could try a Ubuntu Live CD or Linux Reader for Windows.
PostPosted: February 28th, 2016, 3:56
we have recently received a Seagate fast HDD labeled as 4TB and inside box there were 2 x 2TB drives (2.5") configured as RAID 0 also enclosure was configured as 4K sector. by description it looks like the same to me.
Data Recovery Pakistan
PostPosted: March 1st, 2016, 17:42
I think the OP is talking about the Seagate Central drive (STCG2000100)
http://www.seagate.com/external-hard-dr ... e-central/
The drive has a web GUI and he most likely started the firmware update through there.
Users browsing this forum: Bing [Bot], Google [Bot] and 39 guests
