 Post subject: ST1000DM003 RECOV Servo Op=0100 Resp=0005
PostPosted: March 25th, 2016, 16:22
Dear Friends,
I have a drive of client and i need solution for data recovery. Your professional and expert advise required for solution.
Thanks,
Regards,
Arslan
Boot 0x40M
Spin Up
TCC-001F[0x000042F9][0x000042F9]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddWWWMMMMMM
 Post subject: Re: ST1000DM003 RECOV Servo Op=0100 Resp=0005
PostPosted: March 25th, 2016, 17:45
I believe this topic explains what that issue is: https://www.data-medics.com/forum/seaga ... -t901.html
PostPosted: March 26th, 2016, 9:13
itrecovery wrote:
Dear Friends,
Thanks,
Regards,
Arslan
Boot 0x40M
Spin Up
can you show the full log ?
what is drive physical behavior, is there any mild clicking or abnormal sound ?
which city you are from ?
Data Recovery Pakistan
PostPosted: March 28th, 2016, 3:05
Dear Mingmergepk,
I am from Lahore.
The drive is busy only. it starts normal and then spinning smoothly. No clicking not even motor stops
Thanks,
PostPosted: March 28th, 2016, 8:08
did you try to short the read channels ?
PostPosted: March 28th, 2016, 14:59
DiscFW is unreadable. Heads or SA bad blocks
Users browsing this forum: No registered users and 235 guests
