 Post subject: ST2000DM001 detected have 3.9Gb
PostPosted: March 14th, 2016, 6:47
Hy!
i have a external hdd Seagate 2Tb Serial Number: Z1E1W7R5 Part Number:1CH164-572 Model Number:ST2000DM001 Family:BARRACUDA firmware CC44 .After 3 years i face with a big problem the hdd is detected with 3,9Gb make 2 clinck and disk stoped.
Thank's.
 Post subject: Re: ST2000DM001 detected have 3.9Gb
PostPosted: March 14th, 2016, 7:02
Heads are bad. If you see disk is not recognized by full model and s/n. That one that you see is information from PCB.
Sistrum Data Recovery
http://www.sistrum.mk/en
clicking + stopped is not a good sign, most likely head problem.
was it dropped ?
if you have important data on drive, it is highly recommended to send it to a professional DR company.
Data Recovery Pakistan
PostPosted: March 14th, 2016, 7:21
The HDD was connect to a Asus router RT-N16 and never drop ,router and hdd have uninterruptible power supply .
PostPosted: March 14th, 2016, 8:48
warranty ends = life ends
I would say you are lucky to survive 3 years with a DM series drive.
the more you power up the drive the worse you will make it.
if data is worth, send it to reputed DR company.
Users browsing this forum: No registered users and 45 guests
