 Post subject: ST3500325AS Problem
PostPosted: March 17th, 2016, 1:52
With PCB+HDA
Rst 0x08M
ASCII Diag mode
F3 T>
RW cmd 002F req = 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 00 00 A0 E1
opts = 00000000
RW Err = 84150180
Just with PCB alone I m getting same
Rst 0x08M
ASCII Diag mode
F3 T>
opts = 00000000
RW Err = 84150180
Contacts are clear and well
After all getting LED CC or CE error
How to rectify this?
 Post subject: Re: ST3500325AS Problem
PostPosted: March 17th, 2016, 2:20
Sorry model number ST9500325AS 5400.6
PostPosted: March 17th, 2016, 4:31
Need more info.
Does the drive stay spinning, any usual noises?
Is the model and capacity detected?
Can you view any sectors?
Do you have access to terminal?
Web: https://www.day1data.de
PostPosted: March 17th, 2016, 6:54
+1 day1data share more information.
but i would say heads issue.
PostPosted: March 17th, 2016, 10:32
1. Hdd is not detected when spinning with tor tor sound(not Tick Tick) 11 times with small interval
2. After Spin-down the hdd is detected with correct ID no Size but not initialized (image Attached)
One More info: When Connecting just PCB with sata and power the system detect with correct ID
how this how to resolve this?
Sorry for poor explanation
PostPosted: March 17th, 2016, 11:04
Heads and/or media. Requires heads exchange plus further work.
Not DIY
PostPosted: March 18th, 2016, 5:30
this is head problem
http://www.hpwlab.com
PostPosted: March 20th, 2016, 9:37
head problem
PostPosted: March 20th, 2016, 16:09
+1
Data Recovery Pakistan
PostPosted: March 21st, 2016, 23:24
Well,
PM Me If you Need a Head Swap In This Drive ,We Are Based in Chandigarh .
Users browsing this forum: No registered users and 193 guests
