 Post subject: ST500LM000 SSHD Unusual Issue
PostPosted: March 25th, 2016, 13:24
Reading through posts, most issues with this drive is that it doesn't spin up. This one does spin and stays spun up. It seems like a typical Seagate issue in that it goes BSY with any interaction. However this is only after about 20 seconds. I can initially get the drive to read and get into the Utility. If I shut it down and restart I was able to get a backup (again in the first 20 seconds after starting) so I do have a full backup. I have changed Saved Mode Pages so could write to the drive, so I rebuilt the translator, cleared SMART etc but the issue still remains. If I reboot the drive I can see the first and last sector (within the 20 seconds) so translator rebuild did work okay. But then the drive goes BSY again. Below is the Crtl-X report which looks like garbage followed by the terminal output when the drive goes BSY. Is this the NAND which is affecting the drive, or head failure showing up in a more unusual way??
Rst 0x40M
Servo Processor Is Reset.
(P) SATA Reset
RAW OFF
PASS
Spin Up
Spin issued
6Gb Max Speed lowered to 3Gb for Intel bug
Send Status: COMRESET seen
Request spin / disc table recovery
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ATA  15 Cmds
Ts(ms)     dT(ms)   Op Cnt  LBA
         0 99999999 00 0000 000000000000
         0        0 00 0000 000000000000
RW  32 Cmds
Ts(ms)     dT(ms)   xT(ms)  Type Option Mode  St EC       Info
1074269231 99999999 3230703803 22  011209 4000000 21 00000088 DL
      3395 3220701460 4294967052 62  219219 200020 11 20002090
      3490       95 16785301 42  011203 000008 43 00003080 SWD
      3390 4294967196    16939 02  18011215 001002 1 00020080 XFR RD SYS WDG BO 000000 BES 8715BE8.06411C7.0715BE9
     36202    32812 34046098 22  10411A01 020000 41 20000080 DL
    134889    98687 134094992 02  011201 1094811 1 00000080 XFR RD SYS LBA B 01000002DF6B L 6000810022A78E BO 000001 BES 02758B4.4317A33.02759B4
     36811 4294869218 2147450896 45  011203 10000080 2 4526009E FALL
      4043 4294934528 2147487762 12  0112A1 000004 81 80040480 TEMP -2872 degC
  17338327 17334284 4278161426 0A  20091201 10001200 81 00080080 FDB
     28646 4277657615 134193213 12  2819301 000000 1 A0120180 TEMP 3066 degC
  67768409 67739763 4243988500 02  228221 4000000 41 000000D0 XFR WR SYS BO 8A000002 BES 04E85A2.01685E1.006B5A2
  33558628 4260757515 4261413898 02  80019301 000001 1 01000880 XFR WR SYS LBA B 808000037407 L 2001100140401 BO 052000 BES 1065D14.2066D3F.1064D00
   2101358 4263510026 132153355 22  011201 24800008 1 00400088 DL
     12411 4292878349 4294959110 02  128201 000301 1 00110280 XFR WR SYS LBA B 00C1004352F7 L 33000080000208 BO 000020 BES 1016ACA2.0069E21.0068C22
268472449 268460038 4043292683 82  029211 000200 43 808800C2
      6348 4026501195  8910802 22  09FA21 080000 41 00000082 DL
      4254 4294965202  3179327 82  20029301 000011 1 00000080
  67113181 67108927 4227858956 06  028201 80100010 21 08008284 DITH
  16781550 4244635665 4278190087 1A  10928203 42800090 3 00000080 VCM_TEMP
     20725 4278206471    24587 0A  202A205 008000 9 00000084 FDB
1082134784 1082114059 3212836878 42  20168205 023041 1 00060882 SWD
1140855044 58720260 4236771403 12  02C201 000000 41 280000A0 TEMP -303 degC
2151682324 1010827280 2445295626 82  038A21 20000500 1 02000090
      7994 2143292966 269480491 02  06C621 8004008 3 00100080 XFR WR BO 2426821 BES 331DBEF.0319BF7.071DBE8
1117803814 1117795820 1096810128 02  42028221 100000 81 04E00890 XFR WR SYS BO 20000040 VL 8C2A.8E21
   8393011 3185556493 4286578699 26  02C601 48108000 3 C2008180 SK_TUNE
      4118 4286578403        0 55  000000 000000 1 00000080
      4166       48        0 42  000000 000000 1 00000080 SWD
      4265       99        0 27  000000 000000 1 00000080 SND_SRV 0C01 0000 0000 0000 0000 0000 0000 0000
        0000 0000 0000 0000 0000 0000 0000 0000
        0001 C804 00D0
        A94A 0000 0004 0040 0F7D 0F81 0F86 0F83
        0F7E 0F78 0F72 0F67 0F57 0F3C 0F21 0F13
        98F7 A87D 6449 7924 E242 428F 697B AE6D
        947D 79C7 4949 9209 5294 3112 C43F 47BC
      4274        9     1958 2F  000000 000000 1 00000080 SPN_UP NORMAL
     10033     5759       14 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000002B5F4 L 000000000180 BO 000000 BES 0036000.003BFFF.0036000
     10048       15       13 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000002B774 L 000000000100 BO 000000 BES 003C000.003FFFF.003C000
TCC:001E
ERROR:  Flash LED 9C03 - Cannot condemn a clump with valid sectors
   Clmp               0161
   DType              0000
   Valid Sector Cnt   F0BF
   First Cache Node   FFFE
Clump Parametrics:
                    Clump = 033B
                 DataType = 0000
                 ModeFlag = 00
               EraseCount = 00000022
           EraseFailCount = 00
         ProgramFailCount = 00
            WeakReadCount = 00
    UncorrectableECCError = 00
---SOC PSM Command History---
Cmd#/PsmCmd    Clump     Offset     Length     LbaMid     LbaLow   LbaBits39To32 Options   Status    DestClump  DestOffset
     0002       033B       0040       0000       8000       1862       0000       1000       0080       C207       11C3
     0602       033B       0040       0000       8000       1862       0000       1000       0080       C207       11C3
     0502       0279       0040       0000       8000       1862       0000       1000       0080       C207       11C3
     0402       021A       0040       0000       8000       1862       0000       1000       0080       C207       11C3
     0302       022B       0040       0000       8000       1862       0000       1000       0080       C207       11C3
Flash Statistics:
BridgePSMDriverID = 0x0009
FlashID 98D7 8493 72D7
Flash Manufacturer: Toshiba19nm
Flash Capacity = 00008 GB MLC
Combo Mode
NumberOfClumps =    0x0400
LBAsPerCluster =    0x0020
LBAsPerClumpMLC =    0x4000
LBAsPerClumpSLC =    0x2000
ClustersPerClumpMLC =    0x0200
ClustersPerClumpSLC =    0x0100
DefragClumpThresholdInSectors =    0x2000
UserSLCMaxSizeInClumps =           0x0180
NumberOfPotentiallyWrittenClusters =    0x0002
DefectListRevisionKey         0x0002
SLC Clumps                    0x01A7
ActiveClumpInfo
   Active Journal             Clump 017B   Offset 1720
   Active Anchor              Clump 0008   Offset 1660
   DType 0000   Read Cache          Clump 03B7   Offset 0000
   DType 0001   Read Boot           Clump 038C   Offset 0000
   DType 0008   Dirty Write Cache   Clump 014D   Offset 0000
   DType 0009   Dirty Boot          Clump 015A   Offset 0000
   DType 0011   Clean Write Cache   Clump 00A6   Offset 0000
   DType 0012   Clean Boot          Clump 0160   Offset 0000
   DType 001A   SIM                 Clump 0166   Offset 11C0
--- ALF RFS Recorder ---
--- Recorder prints backwards: newest to oldest ---
IARCount    Status       Clump      ClumpSentinel      FunctionOrigin
0000006B    DO_ERASE     023C       CMLC               IAR
0000008C    DO_CONDEMN   0161       RC                 RFS
0000008C    DO_ERASE     033B       CMLC               IAR
0000008B    DO_ERASE     033B       CMLC               RFS
0000008B    DO_ERASE     0279       CMLC               IAR
0000008A    DO_ERASE     0279       CMLC               RFS
0000008A    DO_ERASE     021A       CMLC               IAR
00000089    DO_ERASE     021A       CMLC               RFS
00000089    DO_ERASE     022B       CMLC               IAR
00000088    DO_ERASE     022B       CMLC               RFS
00000088    DO_ERASE     01D9       CMLC               IAR
00000087    DO_ERASE     01D9       CMLC               RFS
00000087    DO_ERASE     01D0       CMLC               IAR
00000086    DO_ERASE     01D0       CMLC               RFS
00000086    DO_ERASE     0246       CMLC               IAR
00000085    DO_ERASE     0246       CMLC               RFS
00000085    DO_ERASE     03DF       CMLC               IAR
00000084    DO_ERASE     03DF       CMLC               RFS
00000084    DO_ERASE     021F       CMLC               IAR
00000083    DO_ERASE     021F       CMLC               RFS
00000083    DO_ERASE     036D       CMLC               IAR
00000082    DO_ERASE     036D       CMLC               RFS
00000082    DO_ERASE     01C9       CMLC               IAR
00000081    DO_ERASE     01C9       CMLC               RFS
00000081    DO_ERASE     02BC       CMLC               IAR
00000080    DO_ERASE     02BC       CMLC               RFS
00000080    DO_ERASE     02B4       CMLC               IAR
0000007F    DO_ERASE     02B4       CMLC               RFS
0000007F    DO_ERASE     0392       CMLC               IAR
0000007E    DO_ERASE     0392       CMLC               RFS
0000007E    DO_ERASE     01AE       CMLC               IAR
0000007D    DO_ERASE     01AE       CMLC               RFS
0000007D    DO_ERASE     0231       CMLC               IAR
0000007C    DO_ERASE     0231       CMLC               RFS
0000007C    DO_ERASE     03EB       CMLC               IAR
0000007B    DO_ERASE     03EB       CMLC               RFS
0000007B    DO_ERASE     0236       CMLC               IAR
0000007A    DO_ERASE     0236       CMLC               RFS
0000007A    DO_ERASE     01B6       CMLC               IAR
00000079    DO_ERASE     01B6       CMLC               RFS
00000079    DO_ERASE     0364       CMLC               IAR
00000078    DO_ERASE     0364       CMLC               RFS
00000078    DO_ERASE     026E       CMLC               IAR
00000077    DO_ERASE     026E       CMLC               RFS
00000077    DO_ERASE     02DE       CMLC               IAR
00000076    DO_ERASE     02DE       CMLC               RFS
00000076    DO_ERASE     0398       CMLC               IAR
00000075    DO_ERASE     0398       CMLC               RFS
00000075    DO_ERASE     03FE       CMLC               IAR
00000074    DO_ERASE     03FE       CMLC               RFS
00000074    DO_ERASE     02A4       CMLC               IAR
00000073    DO_ERASE     02A4       CMLC               RFS
00000073    DO_ERASE     0329       CMLC               IAR
00000072    DO_ERASE     0329       CMLC               RFS
00000072    DO_ERASE     01F8       CMLC               IAR
00000071    DO_ERASE     01F8       CMLC               RFS
00000071    DO_ERASE     03DE       CMLC               IAR
00000070    DO_ERASE     03DE       CMLC               RFS
00000070    DO_ERASE     0380       CMLC               IAR
0000006F    DO_ERASE     0380       CMLC               RFS
0000006F    DO_ERASE     01AD       CMLC               IAR
0000006E    DO_ERASE     0311       CMLC               IAR
0000006D    DO_ERASE     01CD       CMLC               IAR
0000006C    DO_ERASE     0215       CMLC               IAR
ALFRecorder:
   IssueALFRequest
   MakeAnErasedClumpAvailable
   EraseCondemnedClump
   TableAdjustForMoveClump
   JournalEntryForMoveClump
   AddEntryToJournal
   IssueALFRequest
   EraseCondemnedClump
   AddEntryToJournal
   IssueALFRequest
   EraseCondemnedClump
   AddEntryToJournal
   IssueALFRequest
   EraseCondemnedClump
   AddEntryToJournal
   IssueALFRequest
   EraseCondemnedClump
   AddEntryToJournal
   IssueALFRequest
   EraseCondemnedClump
   AddEntryToJournal
   IssueALFRequest
   EraseCondemnedClump
   AddEntryToJournal
   IssueALFRequest
   EraseCondemnedClump
   AddEntryToJournal
   IssueALFRequest
   EraseCondemnedClump
   AddEntryToJournal
   IssueALFRequest
   EraseCondemnedClump
   AddEntryToJournal
   IssueALFRequest
   EraseCondemnedClump
   AddEntryToJournal
   IssueALFRequest
   EraseCondemnedClump
   AddEntryToJournal
   IdentifyLeastValuableClump
   IssueALFRequest
   CondemnClump
TCC:001F
Dither
Dither
SIM Error 1009 LBA 0000000000097E38 FD 003AD17B
RW Error 00000080
SIM Error 1009 LBA 0000000000097E38 FD 0037F30A
RW Error 00000080
SIM Error 1009 LBA 0000000000097E38 FD 00383137
RW Error 00000080
RW Error 00000080
SIM Error 1009 LBA 0000000000097E38 FD FCFFF3FF
RW Error 00000080
RW Error 00000080
RW Error 00000080
RW Error 00000080
RW Error 00000080
 Post subject: Re: ST500LM000 SSHD Unusual Issue
PostPosted: March 26th, 2016, 13:51
http://ts.acelaboratory.com/index.php?/ ... a-sys-file
Users browsing this forum: No registered users and 252 guests
