 Post subject: Autoreassign [ On/Off ] - While Cloning M8E Series HDD
PostPosted: March 31st, 2016, 4:13
Hello All ,
Today i got a Case Where The Drive Came With Heads Stuck On Platter Issue .The Same Was Rectified In My Clean Room .Now The Current Situation is That Heads 0,1,2 From The Four Present 0,1,2,3 Are Cloning Fine .The Top Head 3 Is Having Reading Issues .Why Does This Happen Is My First question " Is It due To The Fact That Dust Settles While We Do The Procedure In The Cleanroom ? . I Always Blow Away Dust With a Manual Blower While i Am In The Procedure or About To Close The Case Top Lid .Am i Overdoing The dust Blowing ? . My Second Problem is That i Would Like To Ask My Friends
Question : How To Disable Autoreassign While Cloning These Samsung Drives ? In PC3K/DDP/MRT/Etc ,If I am Cloning The Top Head Head No 3 I Get The Following In Terminal .
log.zip [3.94 KiB]
Downloaded 416 times
 Post subject: Re: Autoreassign [ On/Off ] - While Cloning M8E Series HDD
PostPosted: March 31st, 2016, 17:04
Spildit wrote:
If you have the latest version of SHT click on the "Trinity" family icon and use "Work on ATA" - Auto Reasign Off.
Could you confirm that it works on M8?
PostPosted: April 1st, 2016, 0:39
+1
PostPosted: April 1st, 2016, 5:24
Spildit ,
How Much Are They Selling this Tool Now ? .
PostPosted: April 1st, 2016, 17:17
Spildit wrote:
But i can't confirm if that specific function to disable auto-reasign will work on the M8E drives as i don't have here any M8E drive to test with, but most likely it should work..
I'm asking because it would be very unique to have such a command(working) on M8
PostPosted: April 2nd, 2016, 8:25
If it works, then just wow...
PostPosted: April 2nd, 2016, 9:51
Spildit wrote:
The latest version of SHT - 4.0.7 supports M8E drives :
They are selling this for $200 USD without BURN-IN resources.
Hi ,
Can You Ask The Developer if It Works With the Drive Series I Posted ,Might Be I Get Interested Might Be We Can Research And Replicate solution For PC3k ,DFL And MRT ?
Users browsing this forum: No registered users and 219 guests
cron
