 Post subject: Use HDD LLF from a Bootdisk
PostPosted: April 13th, 2016, 1:25
Hi
If your notebook just have one hard drive you can't run HDD LLF from this HD to format this disk = is there any known way to use HDD LLF from a Boot disk / Boot stick to format the single hard drive of this notebook?
 Post subject: Re: Use HDD LLF from a Bootdisk
PostPosted: April 13th, 2016, 2:15
read the wikipedias on what LLF actually is, and why it really isn't anymore. Any util that will write 00's to every sector will do, even a full format, or secure erase. I don't think anyone worries about any bad sectors left over that may contain data.. realistically
things like hirens disk should have it, maybe Kali, but I bet there is a tonne of others. even a windows bootdisk should do it. with a format with the full option
PostPosted: April 13th, 2016, 2:42
@HaQue
Thanks for your replay but I ordered HDD LLF and now I want to use it, give the tool a chance. I think that i found a way to implement it. The tool is called WinToUSB (also called Windows To USB) http://easyuefi.com/wintousb/index.html . You can boot from a stick like this and you should be able to run the standalone version from HDD LLF under this "Stick Windows".
PostPosted: April 13th, 2016, 3:22
yes looks like a viable solution, would be good to know your experiences with win2go and the tool, good luck :)
Users browsing this forum: Google [Bot] and 150 guests
