 Post subject: ST9750422AS
PostPosted: April 20th, 2016, 9:39
Terminal log:
EarlySpinup Enabled
Rst 0x10M
(P) SATA Reset
RAW OFF
PASS
APM disabled by SPort
ASCII Diag mode
F3 T>
The drive spin up calibrate normally ( stays busy for approx. 40 sec then ready )
No user area access.
Any thoughts?
Thanks in advance.
 Post subject: Re: ST9750422AS
PostPosted: April 20th, 2016, 9:59
what happens when you try to access data area?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: April 20th, 2016, 10:05
After HM creation (All heads (0,1,2,3) shows UNC)
PostPosted: April 20th, 2016, 10:11
F3 7>X
Head 00 Resistance 019E
Head 01 Resistance 0187
Head 02 Resistance 01AE
Head 03 Resistance 01B1
I think the problem with sys file/s?
But which one?
Thanks in advance.
PostPosted: April 20th, 2016, 11:08
F3 T>Ctrl + x
PostPosted: April 21st, 2016, 1:56
Does it load the translator?
PostPosted: April 21st, 2016, 6:11
Try and open a few sys files like P-List, Translator, NG-List etc.
Is model, serial no and capacity detected?
Web: https://www.day1data.de
PostPosted: April 21st, 2016, 7:16
Thanks for replies guys.
Case solved.
Translator issue plus defective H0&H3. :)
PostPosted: April 21st, 2016, 9:54
Case solved.
Nice work!
PostPosted: April 21st, 2016, 10:03
Thank you.
good luck
PostPosted: April 21st, 2016, 11:25
great job, congrats
PostPosted: April 21st, 2016, 14:27
Thank you Mr. Jermy.
I appreciate your kind help.
Users browsing this forum: Google [Bot] and 112 guests
