 Post subject: What are the chances for complete recovery?
PostPosted: April 23rd, 2016, 6:27
Is it possible to recover data in this state?
 Post subject: Re: What are the chances for complete recovery?
PostPosted: April 23rd, 2016, 14:27
Of course. Get the data from the filter.
ACELab partner
PostPosted: April 25th, 2016, 5:05
:twisted:
Web: https://www.day1data.de
PostPosted: April 25th, 2016, 7:52
Beyond data recovery.
How long this drive was scanned with HDD Regenerator?
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: April 25th, 2016, 8:14
What about the other sides?
PostPosted: April 25th, 2016, 10:29
Sorry i don't understand. Are you saying the last recovery company i went to had intentionally or not damaged my hdd?
PostPosted: April 25th, 2016, 10:31
No idea about the condition of the other states. If data is unrecoverable, why is a recovery company ordering parts for this now?
PostPosted: April 26th, 2016, 5:17
Who took the picture you posted? Is the drive with a DR company now, and they gave you this picture, and at the same time they said they will order spare parts for this and recover your data?
Is this correct?
PostPosted: April 26th, 2016, 7:08
The drive is with Kroll now. Before I went to them, I went to two other companies. The first company took a month plus to get back saying data unrecoverable. They were able to clone an image of the drive though. The second company only took a day to evaluate and they were the one that sent me the above picture saying data unrecoverable. Now Kroll is saying parts have been ordered in their report online.
PostPosted: April 26th, 2016, 7:51
If this a actual photo of your drive ?
I would not advise to spend any parts on that one :(
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: April 26th, 2016, 8:13
The thing is Kroll does not charge unless data is recovered. And they went ahead to order the parts independently.
PostPosted: April 26th, 2016, 8:23
If that is actually your drive, don't waste any money on it. Even if the other platters aren't as bad, you're not going to get back any significant amount of data worth paying for.
I could be mistaken, but I believe that Kroll's policy is they only charge if data is recovered. However, it doesn't matter how little or much they recover. If they manage to save one useless Windows system file, they expect you to still pay the full amount. Gotta read the fine print my friend.
PostPosted: April 26th, 2016, 8:39
We recently had a case where we had a 2.5" hitachi drive where we were able to read about 98% of the drive. Sadly, the 4GB of data that they wanted was stored within the first 5% of the drive and after we finally conceded that we were not going to get any more, even though the drive still was quickly coming ready, we gave up. When we opened the cover, the top platter surface was completely gone. We were very fortunate to get 98% of the drive imaged, however, we were only able to get about 30% of the target data.
So, I can see how the first company might have been able to get a clone, but not a full recovery...and subsequent companies will be lucky to get a 75% clone, if they even bother to try.
For those who might not fully understand how hard drives split data between heads, I started a blog post showing how some hard drives alternate between heads.
PostPosted: April 26th, 2016, 8:49
"Thank you for your interest in Kroll Ontrack data recovery services.
The data recovery processes are as follow if you are keen to proceed:
1. Once the job is booked in, we will send you an email which will link you to a portal to monitor the progress of the job and also view the reports when it’s ready.
2. There will be no evaluation fees for standard service. Upon evaluation, we will provide you with a report indicating what are the data that we manage to recover for you along with a quotation for the data recovery services.
3. If you are fine with report, you will need to endorse on the quotation and we will proceed with the final stage of recovery. The data will be stored in another external media and we will deliver the original and backup media to you.
4. The recovery fees is in the range SGD 1000 – 2000 for standard service. The turn time is between 5-7 days. If it’s mechanical failure and need customised parts, the turn time may be longer as it is subjective to parts availability.
5. Logical failure: SGD 1000 – 1600, Mechanical failure: SGD 1600 – 2000.
6. There will be no charges if the media is unrecoverable.
7. In the event if the hard drive is recoverable and you do not proceed with the data recovery, there will be an admin fee of SGD 100.
8. If the media is not collected within 1 mth after the job is completed, it will be degaussed and donated."
I've posted the email Kroll had sent. There only seems to be a 100 dollar charge if I do not proceed with the recovery. Point 7. And I've agreed to this before I had sent my drive to them. I do not know why they are attempting to recover data from this drive but l'll wait and see.
PostPosted: April 27th, 2016, 3:30
The problem is the drive has already been to 2 companies prior to Kroll.
Each hand the drive has been through the drive would have got worse.
I know customers like to shop around, but after the 3rd or 4th quote the drive is just about done usually.
Users browsing this forum: No registered users and 260 guests
