 Post subject: Corrupted imgc image
PostPosted: April 23rd, 2016, 12:01
Hi all,
I hope someone will be able to help with that. I have a fairly large (2TB) .imgc image created with HDD Raw Copy Tool. I was hoping to uncompress it to a raw image in order to recover some data - but whenever I try to open it, HDD Raw Copy Tools tells me "Selected file cannot be open; it is either damaged or inaccessible."
Since I can open other images from the same location without any issue, I do believe that the image is corrupted.
Question is: can I force it to open? Is there any other software that will allow me to convert it to a usable (even if corrupted) raw image?
Thanks!
 Post subject: Re: Corrupted imgc image
PostPosted: May 3rd, 2016, 22:02
have you try to clean it to make sure it does not have a virus? just making sure it does not have a virus bothering you on this.
PostPosted: May 4th, 2016, 3:08
does 7-zip extract those? you might get a lot from it if it does, apart from the corrupted bit.
PostPosted: May 4th, 2016, 7:48
Unfortunately I wasn't able to extract it with any common compression software, 7zip included.
PostPosted: May 4th, 2016, 16:22
Spildit wrote:
What ?
:shock: :shock: :shock:
My thoughts exactly. Didn't know what to reply, frankly.
PostPosted: May 4th, 2016, 18:43
It isn't that silly at all. I have an image from an Edu institution, a so called gold image for workstations that was built and somehow a virus got into it at an early stage. I wanted to extract some configs and data from it and was stopped by AV, the extraction software gave errors about not being able to find the file IIRC.
PostPosted: May 4th, 2016, 20:54
Good point. However, that's (unfortunately) not the case. Something apparently went wrong when creating the image (and I should have tested it right away!)
Users browsing this forum: Google [Bot] and 164 guests
