 Post subject: slow XP loading with progress bar
PostPosted: April 28th, 2016, 6:54
i have got a FUJITSU SIEMENS SCENIC E600 old computer with XP HOME EDITION as OS.
But i have got this kind of issue:
When i turn my pc on, it happens FUJITSU SIEMENS log appears and after that there is a progress bar at the bottom of the black screen like this:
And then finally XP HOME EDITION loads but very slowly.....
So i ask you:
how can i remove that progress bar and make my XP faster like before ?
I also post you some pics of my BIOS settings because there is something strange in there, 2 standard IDE's !!!:
and these are 2 stardard IDE's details:
 Post subject: Re: slow XP loading with progress bar
PostPosted: April 28th, 2016, 7:54
you can simply add your image straight from your PC. use the "attach a picture or file" button down under the reply text box.
PostPosted: April 28th, 2016, 8:00
backup both drives and replace with new one.
PostPosted: April 28th, 2016, 10:26
If you have 2 drives, remove the non-system drive and see if the progress bar disappears.
Those who know don’t talk. Those who talk don’t know.
PostPosted: May 5th, 2016, 3:09
no, the problem is my hard disk is damaged and must be changed with an other one.
Users browsing this forum: No registered users and 170 guests
