 Post subject: Toshiba 500gb hard drive encrypted virus
PostPosted: April 24th, 2016, 7:56
Banned User
Hello friends
I have a document encrypted virus .crypt help me
I did try many ways but not decipher
thank you
CHứng mất ngủ.doc [32.88 KiB]
Downloaded 732 times
Banned for spamming
 Post subject: Re: Toshiba 500gb hard drive encrypted virus
PostPosted: April 24th, 2016, 8:55
How have you tried to decipher?
PostPosted: April 24th, 2016, 9:34
Banned User
I follow a few guidelines as here noransom.kaspersky.com
I send 1 files sample decrypt
You help me
thank you
Banned for spamming
PostPosted: April 24th, 2016, 12:05
That's because you don't have the CoinVault or Bitcryptor ransomware.
Try this instead:
http://www.bleepingcomputer.com/news/security/gomasom-crypt-ransomware-decrypted/
make sure you are WORKING ON A COPY of the data, and always keep a good original copy safe. If you have had trouble simply identifying it, then maybe consider giving this job to someone that has the experience to give it the required diligence.
You could have TeslaCrypt 4.0, and if so... ouch, sorry :-(
PostPosted: April 24th, 2016, 13:56
Banned User
Try this instead:
I use this screen notice how you
help me
Banned for spamming
PostPosted: April 24th, 2016, 15:45
I would recommend 1st understanding what malware you are dealing with (https://id-ransomware.malwarehunterteam.com/), then 2nd determine whether there is a solution for it (if not consider if worthwhile coming up with your own), and 3rd apply solution.
+1 on working with a copy of files
PostPosted: April 25th, 2016, 14:25
Banned User
Brother can help me decipher virus .crypt
thanks
Banned for spamming
PostPosted: April 26th, 2016, 2:43
Go for Raw recovery first.. see if you can open the office and pdf files..
PostPosted: May 20th, 2016, 18:05
Banned User
I was full encryption of documents in the hard disk drive
I've used the Launch Data Recovery
Results failed
Banned for spamming
PostPosted: May 20th, 2016, 20:10
Banned User
Spildit wrote:
Please read here :
http://www.hddoracle.com/viewtopic.php?f=150&t=1583
And try the attached tool.
I've used this tool but can not decipher
Banned for spamming
PostPosted: May 20th, 2016, 23:08
datahdd116 wrote:
Spildit wrote:
Please read here :
yes it can.
steps to reproduce:
1. Extract tool to c:\TeslaDecoder
2. Make folder "encrypted" in that folder and put encrypted files in there (c:\TeslaDecoder\encrypted\)
3. add the file extension ".xxx" to all files.
4. run TeslaDecoder.exe.
5. Click "Set Key" and choose ".xxx, .ttt, .micro, .mp3" and click "set key"
6. Click "Decrypt Folder" and choose your c:\TeslaDecoder\encrypted\" folder, then say "no" to deleting your original files.
7. Do the happy dance!
You owe me AU$400! :-)~
PostPosted: May 21st, 2016, 1:44
Banned User
HaQue wrote:
datahdd116 wrote:
Spildit wrote:
Please read here :
yes it can.
steps to reproduce:
before I am using the old version not get the key.
I downloaded the new update 18/5 fine.
thanks
I invite you to whisky :D :D
Banned for spamming
Users browsing this forum: Bing [Bot] and 86 guests
