 Post subject: wd5000lpcx P-list error
PostPosted: May 8th, 2016, 1:12
in WDmarv 2.3 or 9b beta
HDD: wd5000lpcx , Detected shows partitions but can't access any partitions and data
I m getting the following error while trying to edit P-List
Error reading the P-list, state - RSC_ALLOCATION_NO_CONTI_BUFFER
but both copies of 33.mod can be read and write.
i need to recover data
pls advice
 Post subject: Re: wd5000lpcx P-list error
PostPosted: May 8th, 2016, 4:00
I've no idea about your tool.
But, as it shows partitions, the problem is elsewhere.
You seems don't have proper tools to deal it. let it deal by somewhere who has access to the proper tools and know how
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: May 8th, 2016, 8:02
Disk management image attached with Active File recovery Partition info
I can't access any partitions data
I can read and write all modules & attached here also both heads are good (WDR)
Modules-00.7z [4.07 MiB]
Downloaded 449 times
PostPosted: May 10th, 2016, 1:09
Let me know what is module 6F ?
it is invalid when check the module by wdmarve 9b beta
PostPosted: May 10th, 2016, 2:10
Module 6F often has a bad checksum even in good drives.
The problem appears to be logical, not physical. You need to examine the drive wih a disc editor, eg DMDE. Can you show us the contents of sectors 0, 1, and 2?
PostPosted: May 10th, 2016, 3:08
Added First 5 Sectors (HxD)
PostPosted: May 10th, 2016, 3:18
Its looks like hdd is ok.
Must be a Logical problem.
does this disk belongs to dvr?
PostPosted: May 10th, 2016, 3:30
No it is from Dell laptop
PostPosted: May 10th, 2016, 10:43
The GPT partition data appear intact. They match what Disk Management is reporting.
    start       end              partition
   sector      sector    size      type
    0x0800    0x0FA7FF  500MiB  EFI System Partition
  0x0FA800    0x10E7FF   40MiB  Basic data partition
  0x10E800    0x14E7FF  128MiB  Microsoft reserved partition
  0x14E800    0x2C57FF  750MiB  Basic data partition
  0x2C5800  0x1CC597FF  229GiB  Basic data partition
0x1CC59800  0x25ED57FF   73GiB  Basic data partition
0x25ED5800  0x2F1517FF   73GiB  Basic data partition
0x2F151800  0x39339FFF   81GiB  Basic data partition
0x3933A800  0x3A38582F    8GiB  Microsoft recovery partition
I would examine the first and last sectors of each "Basic data partition". You should see NTFS boot sectors (except for the first FAT32 partition).
Can you show us DMDE's Partitions window?
PostPosted: May 11th, 2016, 12:04
PostPosted: May 11th, 2016, 12:50
GPS ,
For Professional Data Recovery Business As You Are Doing These Days in India ,Get Some Sensible Proper Tool ,You Are Trying Stunts And All These Guys Are Helping And Mind You Its The Clients Data You Are Playing And Messing With [In Virtually All Your Posts ] .Stop This India Jugaar Funda And Buy A Tool On Installments ,You Have No Idea Of The Tool Come To My Office In Chandigarh And Take a Days Free Tour Of The Tools Then Buy What You Like
PostPosted: May 11th, 2016, 15:00
The 246GB / 229GiB "Basic data partition" has an empty boot sector but the other boot sectors appear to be OK. Therefore it seems strange to me that DMDE did not identify the boot sectors with a "B" in the Indicators column.
I would select each of the Basic partitions and perform an NTFS Search. This will look for MFT records, etc. Then Open Volume to examine any file/folder structures that DMDE finds. You can stop the search (and resume it at a later time) by saving the search results to a log file. Before beginning each search, I would scroll through the volume to make sure that it has not been zeroed, particularly the one with the empty boot sector.
PostPosted: May 11th, 2016, 16:41
I would examine the MFT sectors.
    start       end           size               MFT       partition
   sector      sector    bytes / sectors        sector       type
  0x2C5800  0x1CC597FF  229GiB / 0x1C994000    0x8C5800  Basic data partition
0x1CC59800  0x25ED57FF   73GiB / 0x927C000   0x1D259800  Basic data partition
0x25ED5800  0x2F1517FF   73GiB / 0x927C000   0x264D5800  Basic data partition
0x2F151800  0x39339FFF   81GiB / 0xA1E8800   0x2F751800  Basic data partition
They should look something like this:
Offset(h)  00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
858E1FC00  46 49 4C 45 30 00 03 00 BD 4F B0 03 00 00 00 00  FILE0...½O°.....
858E1FC10  01 00 01 00 38 00 01 00 98 01 00 00 00 04 00 00  ....8...˜.......
858E1FC20  00 00 00 00 00 00 00 00 06 00 00 00 00 00 00 00  ................
858E1FC30  45 00 00 00 00 00 00 00 10 00 00 00 60 00 00 00  E...........`...
858E1FC40  00 00 18 00 00 00 00 00 48 00 00 00 18 00 00 00  ........H.......
858E1FC50  E0 89 72 37 92 97 D0 01 E0 89 72 37 92 97 D0 01  à‰r7’—Ð.à‰r7’—Ð.
858E1FC60  E0 89 72 37 92 97 D0 01 E0 89 72 37 92 97 D0 01  à‰r7’—Ð.à‰r7’—Ð.
858E1FC70  06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
858E1FC80  00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00  ................
858E1FC90  00 00 00 00 00 00 00 00 30 00 00 00 68 00 00 00  ........0...h...
858E1FCA0  00 00 18 00 00 00 03 00 4A 00 00 00 18 00 01 00  ........J.......
858E1FCB0  05 00 00 00 00 00 05 00 E0 89 72 37 92 97 D0 01  ........à‰r7’—Ð.
858E1FCC0  E0 89 72 37 92 97 D0 01 E0 89 72 37 92 97 D0 01  à‰r7’—Ð.à‰r7’—Ð.
858E1FCD0  E0 89 72 37 92 97 D0 01 00 40 00 00 00 00 00 00  à‰r7’—Ð..@......
858E1FCE0  00 40 00 00 00 00 00 00 06 00 00 00 00 00 00 00  .@..............
858E1FCF0  04 03 24 00 4D 00 46 00 54 00 00 00 00 00 00 00  ..$.M.F.T.......
858E1FD00  80 00 00 00 48 00 00 00 01 00 40 00 00 00 01 00  €...H.....@.....
858E1FD10  00 00 00 00 00 00 00 00 2F 0C 00 00 00 00 00 00  ......../.......
858E1FD20  40 00 00 00 00 00 00 00 00 00 C3 00 00 00 00 00  @.........Ã.....
858E1FD30  00 00 C3 00 00 00 00 00 00 00 C3 00 00 00 00 00  ..Ã.......Ã.....
858E1FD40  32 30 0C 00 00 0C 00 00 B0 00 00 00 48 00 00 00  20......°...H...
858E1FD50  01 00 40 00 00 00 05 00 00 00 00 00 00 00 00 00  ..@.............
858E1FD60  00 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00  ........@.......
858E1FD70  00 10 00 00 00 00 00 00 18 06 00 00 00 00 00 00  ................
858E1FD80  18 06 00 00 00 00 00 00 31 01 FF FF 0B 00 00 00  ........1.ÿÿ....
858E1FD90  FF FF FF FF 00 00 00 00 00 80 00 00 00 00 00 00  ÿÿÿÿ.....€......
858E1FDA0  00 80 00 00 00 00 00 00 31 08 00 00 0C 00 01 00  .€......1.......
858E1FDB0  B0 00 00 00 48 00 00 00 01 00 40 00 00 00 05 00  °...H.....@.....
858E1FDC0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
858E1FDD0  40 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00  @...............
858E1FDE0  08 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00  ................
858E1FDF0  31 01 FF FF 0B 00 00 00 FF FF FF FF 00 00 45 00  1.ÿÿ....ÿÿÿÿ..E.
Users browsing this forum: No registered users and 40 guests
